Compiling firmware
#1 Mike P
Mike P
  • 41 posts
  • LocationAuckland, New Zealand
Posted 15 September 2011 - 12:55 PM
There are several really good posts buried in the forum on how to compile the Netduino firmware from source code.
I've managed to get as far as this error:
C:\GCC\bin\arm-none-eabi-ld.exe: C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\FLASH\release\Netduino\bin\tinyclr.axf section ER_FLASH will not fit in region LR_FLASH
 C:\GCC\bin\arm-none-eabi-ld.exe: region LR_FLASH overflowed by 65128 bytes
Now I have read this very helpful post by CW2:
http://forums.netdui...dpost__p__10332
And I understand that I have to adjust the blockrange for the code.
What I am stuck on is where do I find the size of the ER_FLASH file since it does not get created when the build fails.
In CW2's post he says "but our firmware is 0x50ADC bytes" but I don't know where that figure came from.
How do I find the size of the firmware so that I can know how big to make the BlockRange?
#2 CW2
Posted 15 September 2011 - 01:18 PM
The size of firmware is the size of the LR_FLASH region defined in scatterfile_tinyclr_gcc.xml plus the overflow: LR_FLASH Size = %CodeSize% = 0x0015E000 - 0x0011E000 = 0x40000, firmware size = 0x40000 + 65128 = 0x4FE68.
Edit: Fixed values for GCC (were for RVDS)
#3 CW2
Posted 15 September 2011 - 01:38 PM
Another way is to make the LR_FLASH region bigger in the scatter file (i.e. increasing the value of Deploy_BaseAddress), so the build succeeds and ER_FLASH is created. Don't forget to set the value back Posted Image
#4 Mike P
Mike P
  • 41 posts
Posted 15 September 2011 - 07:49 PM
Thanks CW2. That makes a lot of sense. Success. I compliled and uploaded firmware from source for the first time.
