They can be found in my recently founded codeplex project: http://netmftoolbox.codeplex.com/
A small list of code samples available for Visual Basic at this time:
- 7-Segment counter: Counting from 0 to 9 with a 7-segment display and 74HC595 IC
- Basic Speaker: An easy way to drive a PC-speaker and output monophonic sounds
- BitBang Buzzer: When all PWM-pins are occupied and you want to add a buzzer, check this!
- Dangershield: Have got the shield? Here's a sample code for NETMF
- DFRobot Motorshield: A sample for the L298N and L293 DFRobot motorshields
- Joystick Shield: A sample for the famous joystick shield
- Matrix KeyPad: Using a matrix keypad
- Micro Serial Servo Controller: Using the pololu serial servo controller with a .NET Microcontroller
- Multiplexing GPIOs: Expanding the amount of GPIO ports by adding 74HC595 and/or 74HC165 IC's
- Rdm630 RFID Reader: Reading RFID tags with a Rdm630 breakout board
- RGB Led: Using 'HTML-like' hex-numbers to drive an RGB-led
- Sharp GP2Y0A02YK Proximity Sensor: A cheap sensor to measure distance, not very accurate
- SN754410 Motor Driver: Driving two DC motors using a H-bridge DC motordriver
- Thumb joystick: A simple piece of code for the popular Sparkfun Thumb Joystick
- TMP36 Temperature sensor: A temperature sensor in celcius, fahrenheit and kelvin
I shall keep maintaining this codeplex project and I will create VB-samples for every driver I add to the respository. Hopefully this will help the VB-community a bit.
Edited by Stefan, 27 September 2011 - 07:57 PM.
Added the last additions to this post as well ;-)
