Servo control in VB.NET
Posted 10 September 2011 - 01:40 PM
Posted 11 September 2011 - 01:33 PM
Posted 11 September 2011 - 02:41 PM
Try thisHi all,
First post.
I just got going with my netduino in VB.NET.
Does anyone have a simple servo control example?
Thankx
Imports Microsoft.SPOT Imports Microsoft.SPOT.Hardware Imports SecretLabs.NETMF.Hardware Imports SecretLabs.NETMF.Hardware.Netduino Module Module1 Sub Main() Dim MoveServo As PWM = New PWM(Pins.GPIO_PIN_D5) Dim led As OutputPort = New OutputPort(Pins.ONBOARD_LED, False) Do MoveServo.SetPulse(20000, 2250) led.Write(True) Thread.Sleep(1000) MoveServo.SetPulse(20000, 500) led.Write(False) Thread.Sleep(1000) Loop End Sub End Module
Posted 08 May 2012 - 05:43 PM
The original can be found here: Netduino Servo Class
It probably needs to be optimized and tweaked, I will be working with the code for a while so I'll update if I make any fixes.
Start by creating a new class in your VB project called "Servo_API"
' ' ' * Servo NETMF Driver ' ' * Coded by Chris Seto August 2010 ' ' * <chris@chrisseto.com> ' ' * ' ' * Use this code for whatveer you want. Modify it, redistribute it, I don't care. ' * I do ask that you please keep this header intact, however. ' ' * If you modfy the driver, please include your contribution below: ' ' * ' ' * Chris Seto: Inital release (1.0) ' ' * Chris Seto: Netduino port (1.0 -> Netduino branch) ' ' * Chris Seto: bool pin state fix (1.1 -> Netduino branch) ' ' * Fileark: 2012-05-08 Converted to VB (http://filear.com) ' ' * ' ' * ' Imports Microsoft.SPOT.Hardware Imports SecretLabs.NETMF.Hardware Namespace Servo_API Public Class Servo Implements IDisposable ' PWM handle' Private servo As PWM ' Timings range' Private range As Long() = New Long(1) {} ' Set servo inversion' Public inverted As Boolean = False ' Create the PWM pin, set it low and configure timings' Public Sub New(pin As Cpu.Pin) ' Init the PWM pin' servo = New PWM(DirectCast(pin, Cpu.Pin)) servo.SetDutyCycle(0) ' Typical settings' range(0) = 800 range(1) = 3200 End Sub Public Sub Dispose() Implements IDisposable.Dispose disengage() servo.Dispose() End Sub ' Allow the user to set cutom timings' Public Sub setRange(fullLeft As Long, fullRight As Long) range(1) = fullLeft range(0) = fullRight End Sub ' Disengage the servo. ' ' The servo motor will stop trying to maintain an angle' Public Sub disengage() servo.SetDutyCycle(0) End Sub ' Set the servo degree' Public WriteOnly Property Degree() As Double Set(value As Double) ' Range checks' If value > 180 Then value = 180 End If If value < 0 Then value = 0 End If ' Are we inverted?' If inverted Then value = 180 - value End If ' Set the pulse' servo.SetPulse(20000, CUInt(map(CLng(Math.Truncate(value)), 0, 180, range(0), range(1)))) End Set End Property ' Used internally to map a value of one scale to another' Private Function map(x As Long, in_min As Long, in_max As Long, out_min As Long, out_max As Long) As Long Return (x - in_min) * (out_max - out_min) \ (in_max - in_min) + out_min End Function End Class End Namespace
Then your main module should look something like this.
Imports Microsoft.SPOT Imports Microsoft.SPOT.Hardware Imports SecretLabs.NETMF.Hardware Imports SecretLabs.NETMF.Hardware.Netduino Module Module1 Sub Main() Dim servo As New Servo_API.Servo(Pins.GPIO_PIN_D9) Dim i As Integer = 0 Do While True Do While i < 100 'Loop to fade from off to full on' servo.Degree = i 'wait for 15 milliseconds' Thread.Sleep(10) i = i + 1 Loop i = 100 Do While i > 0 'Loop to fade from full on to off' servo.Degree = i 'wait for 15 milliseconds' Thread.Sleep(10) i = i - 1 Loop Loop End Sub End Module
Posted 11 May 2012 - 11:27 AM
Posted 07 September 2013 - 08:23 AM
Hi
Although I just started playing with the NEtDuino Plus 2 I do have a few years of .NET VB under the belt.
I'm trying to get the Servo-API code to work on a ND+2
I'm[font="arial, helvetica, sans-serif;"] using VS[/font] 2010 Premium SP1
Microsoft .NET Micro Framework SDK v4.2 Version 4.2.0.0 and
Netduino SDK v4.2.2.0 (64-bit)
On the line: servo = New PWM(DirectCast(pin, Cpu.Pin))
[font="arial, helvetica, sans-serif;"]I get the message: "[/font][font="arial, helvetica, sans-serif;"]Overload resolution failed because no accessible 'New" accepts this number of statements"[/font]
[font="arial, helvetica, sans-serif;"]In the first overload it expects: servo = New PWM(Channel,Frequency,DutyCycle,Invert)[/font]
The second Overload expects even more parameters
[font="arial, helvetica, sans-serif;"]Then on the line: servo.SetDutyCycle(0)[/font]
[font="arial, helvetica, sans-serif;"][font="arial, helvetica, sans-serif;"]I get the message: "[/font][/font]'SetDutyCycle' is not a member of 'Microsoft.SPOT.Hardware.PWM'"
The intelisense only shows 'DutyCycle' and it have to be use as: servo.DutyCycle = 0
[font="arial, helvetica, sans-serif;"] [/font]
[font="arial, helvetica, sans-serif;"]and the same with: servo.SetPulse(20000, CUInt(map(CLng(Math.Truncate(value)), 0, 180, range(0), range(1))))[/font]
[font="arial, helvetica, sans-serif;"][font="arial, helvetica, sans-serif;"]I get the message: "[/font][/font]'SetPulse' is not a member of 'Microsoft.SPOT.Hardware.PWM'"
there is no equivalent shown for 'SetPulse'
Did something in the PWM libraries change? How do we implement servo control now? Or am I missing something?
[font="arial, helvetica, sans-serif;"]Cheers[/font]
[font="arial, helvetica, sans-serif;"]Deon[/font]
