Setting up environment
Started by magarcan, Sep 05 2011 03:14 PM
7 replies to this topic
Posted 05 September 2011 - 03:14 PM
I've a Netduino Plus. I'm using Visual Studio 2010 Premium and I want to set up, the development environment. As I've read, I've installed the following elements:
After open Visual Studio, I go File > New Project > Micro Framework, but I don't see Netduino Plus Application anywhere. Here a screenshot:
Do I need to install any more?
Thanks!!!
Thanks!!!
Posted 05 September 2011 - 03:20 PM
Hi and welcome to the Netduino boards!
The sequence is important. In which sequence have you installed the SDK's?
You should first install the generic SDK from Microsoft and then the Netduino SDK.
Also, sometimes the templates are a bit 'lost'. I found a topic about that which might help. Especially post #7 which contains a solution:
http://forums.netdui...ndpost__p__9986
Posted 05 September 2011 - 03:33 PM
Thanks for the answer but...
Any other idea?
- I've installed in the right order. First Microsoft .NET Micro Framework 4.1 SDK and then Netduino SDK v4.1.0 (64-bit).
- I've looked for NetduinoPlusApplication.zip in my computer and it's located at C:\Users\manuel\Documents\Visual Studio 2010\Templates\ProjectTemplates\Visual C#\Micro Framework\
Any other idea?
Posted 05 September 2011 - 03:45 PM
Ok. I've already solved. By default it is installed in \Visual Studio 2010\Templates\ProjectTemplates\Visual C#\Micro Framework\ but, the thing is that I changed the environment path to \VS2010\Templates\ProjectTemplates\Visual C#\Micro Framework\ some months ago. I've moved the files and everything is working ok.
Thanks!!
Thanks!!
Posted 05 September 2011 - 04:19 PM
I've a new problem. I'm trying to follow the Hello World tutorial, but I have some problems.
This is a screenshot form de PDF file:
Problems:
I think that it is not the same window that tutorial is saying. Can anyone help me?
Thanks!!
Problems:
- Ctrl-W, O is not working. It says that it isn't a command.
- The nearest thing I've could find is CTRL-ALT-O (View/OtherWindows/Output and then, Debug). This is what I see wich is very different to the tutorial's text:
Thanks!!
Posted 05 September 2011 - 04:30 PM
Hi againProblems:
Thanks!!
The "Ctrl-W, O" version I didn't knew of and doesn't work for me either.
But the Output Window that came with Ctrl+Alt+O is the correct one. Try this code:
Debug.Print("Hello World!");and you will see it will come in that window.
Posted 06 September 2011 - 02:34 PM
I've another problem
I'm trying to deplo de "HelloPachube" example. The problem is that mi VS are not finding WaitUntilNextPeriod() method. I've checked that I've attached every library but even so, it takes an error. Here is my code:
Can anyone help me? Thanks.
using System; using System.Net; using System.Net.Sockets; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoPlus; using Gsiot.PachubeClient;
Posted 06 September 2011 - 04:10 PM
I've just seen that I've to defined WaitUntilNextPeriod() with my own code. All is working now.
