Netduino Plus maximum input voltage
Posted 31 August 2011 - 10:26 AM
Posted 31 August 2011 - 10:30 AM
Posted 31 August 2011 - 12:01 PM
Posted 31 August 2011 - 12:24 PM
Hmm, good thought. We've been looking at this circuitry recently, so I'll chat with our electric engineers about it. We haven't seen any issues when testing with 12VDC power supplies--but you are correct that the 7.5VDC-10VDC range is best (especially since most AC-DC power supplies are in a word, unregulated).Chris, when the Vin rises over 10-11V, the inverting input of the comparator (VIN_COMP) is getting higher than +5V. BTW the comp specs recommend to limit the input pins within the V+..V- range.
Did you perform any test?
Is it worthwhile to add a 4.7V Zener?
Posted 31 August 2011 - 12:28 PM
Posted 31 August 2011 - 02:38 PM
I would perform the test up to +15V, which is above the car supply range. It would be useful to connect directly to the car outlet.
I second this! I was wondering the same thing... when it says limit to 12 Volts, but cars routinely show 14+ volts when charging.
IF I understand you Chris... The issue is not the voltage (up to 20 V), but a matter of what I'm driving off the Netduino pins and thus trying to pull through the voltage regulator(s) on the Netduino board. As long as I'm using small, low current stuff, I should be ok on a car's voltage system?????? Or am I overly simplifying things too much?
If so, I'm guessing there should be some upper limit of current... would that be the 200 mA on the specs... or something less? And No! I wouldn't hold you to it... if I fry a Netduino by putting it on a car, its totally my fault.
If my message helped you... how 'bout giving me a
www.MessingWithReality.com
Posted 31 August 2011 - 03:41 PM
I've powered it through a car USB adapter that was rated at 5V 2.1A for iPad charging. The Netduino worked great, but it would be interesting to know if I was courting disaster. I know that I have experienced some instability in power coming from my car outlets before, though the car I am driving now seems to have better isolation than others I have tried. I can think of a few neat ideas for using a Netduino in my car, so it would be good to know that it would be safe to do so.
So far, this thing has been incredibly tough. I stayed away from hardware because I always ended up frying electronics when I touched them in the past, but the Netduino has performed admirably considering how many times I thought I must have killed it.
Posted 31 August 2011 - 03:44 PM
where I the current flowing. Assuming I=80mA (Netduino Plus without anything else), when Vin is 15V, then power is:P = (Vin - 5) * I
The regulator specs say that the thermal-resistance (junction-ambient) is Zja=92'C/W. Since the regulator is solded on the PCB, we may assume that all the heat will be dissipated by the PCB itself.P = 0.8W
What is the "thermal-resistance"? Is the "ability" to conduct the heating from the junction (where the heat is originated), to the ambient (heating sink).
At this point:
where: Ta=25'C is the ambient (PCB) temperature, and Tj is the internal regulator (junction) temperature.Tj = Ta + Zja*P = 25 + 92*0.8 = 98.6 'C
Since the reg specs say that the max Tj is 150'C, the chip is still within the safe range.
However, that's much like an optimistic depict. The PCB will be warmer than 25'C, and the ambiental temperature could be higher as well.
Old school: an easy and good test is to put your finger on the regulator: if you can leave it without frying it, the chip is *surely* safe!
PS: I am sorry for using the temp in 'C instead of 'F.
Posted 09 January 2012 - 01:06 AM
Posted 06 July 2012 - 06:12 PM
Posted 06 July 2012 - 07:58 PM
Posted 06 July 2012 - 08:22 PM
