Background:
In a mild panic, converting a C# Express NetduinoPlus project from 4.1.0.6 to 4.2 RC1..... I had to remove the 4.1.0.6 reference DLL's from the project and replace the equivalent 4.2 RC1 versions of the same thing. I got carried away and forgot to write down which ones SHOULD have put back in, and before I knew it I had added almost everything.
Symptoms:
1. on Starting debug I get the message window popup with "There were deployment errors. Continue Y/N"
2. The Debug\Output Window shows :
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 185780 bytes <<<< This is a bit big for Netduino>
Assemblies not successfully deployed to device.
Deployment to the device was not successful.
Solution:
I found I went crazy and added too many reference Dll's and once I had removed them it deployed again just fine!
Recommendation (nice to have):
If possible is there a way for the error to be changed to "Insufficient Space for download" or similar, or do a check against target capacity and show this in a popup error.
"An error has occurred. Please check your hardware"
Started by Earthed, Aug 31 2011 05:49 AM
No replies to this topic
