Nevyn's SimpleWebServer Translated to VB
Posted 21 August 2011 - 05:46 AM
Posted 21 August 2011 - 01:48 PM
Thanks for the note - I'll make a modification to the C# implementation to take this into consideration.The second problem was related to a spurious request by IE9 for GET /favicon.ico HTTP/1.1 even though I issued, http://192.168.0.111....html?SayHello. Apparently, this is a tiny icon placed in the address bar. In any case, the program needed some code to ignore it.
I always have a rule that I don't write code which does not fit on one screen width - I've been working on full HD monitors for the last three years so one screen is a lot of code.This is a nice program; thank you Nevyn, but I do hate deeply nested curly brackets when porting code.
Glad you found it useful - I'll drop a link to your code from my blog.
Posted 11 September 2011 - 09:00 AM
I'm adding this project to Codeplex - am I OK to add the VB code to the project? I going to try and bring the web server code and the Silverlight code together in one place.I am attaching a VB version of the Simple Web Server referenced here,
Alternatively, if you want I can add you as a contributor if you have a Codeplex ID. PM me your details if interested.
Posted 11 September 2011 - 01:39 PM
Posted 11 September 2011 - 06:39 PM
Posted 14 December 2011 - 02:33 PM
Posted 14 December 2011 - 04:22 PM
To put files on the SD card you have two alternatives, one is to remove the SD card and put it in a PC and write to it from the PC. The second alternative is to modify the web server to allow files to be written to the SD card by the web server code itself. It is trivial to do just be aware of the implications.1. I noticed in the webserver code that the SD is not mounted anywhere. Does System.IO.File.Exists(fullPath) automatically know to check an SD card?
2. How do I write files to the SD? Does it show up as a removable drive when installed or do I need to attach it to my PC, load files and then attach it to the NetDuino?
I never had to make any modifications to the system to make File.Exists check the SD card.
Hope this helps,
Posted 14 December 2011 - 04:48 PM
Thanks Mark. What are the implications of doing it in code? Just bloat?
Posted 14 December 2011 - 05:37 PM
I was thinking more about security.Thanks Mark. What are the implications of doing it in code? Just bloat?
Posted 14 December 2011 - 06:46 PM
Understood Mark.
I just installed an SD card and put a "Default.htm" file into a www directory.
The code throws an error when looking to see if the file exists.
Step into: Stepping over non-user code 'System.IO.File.Exists'
A first chance exception of type 'System.IO.IOException' occurred in Microsoft.SPOT.IO.dll
Any Ideas?
Posted 14 December 2011 - 07:03 PM
Posted 14 December 2011 - 07:37 PM
Just wondering about the card / capacity. If memory serves 4GB are supported with some larger cards in the later version of the framework. What card make, capacity and format are you using?I just noticed that I get about 50 errors whenever I try System.IO.File.Exists.
The errors happen regardless of having the SD card in or not.
I tried a simple program where System.IO.File.Exists('@\SD\www\Default.htm') was the only line and I get the errors.
Have you tried a simple program to read or write a file?
Posted 14 December 2011 - 07:46 PM
Hi Mark.
I moved the question to a new thread because I didn't want this one to lose focus on the webserver... I will put all the SD card info there.
Thanks again,
terry
Posted 15 December 2011 - 12:55 AM
Hi Nevyn,
Post it wherever you want; It's your code. I have added some further command functionality:
(1) NIST Daytime protocol client class to get and set the clock through the browser and,
(2) SD card file manager class (volume info, list files/folders on card, make/delete subdirectory, read/write files, clean SD, etc)
I will post these to the forum within the next a few days.
Baxter
Hi Baxter. Can you post your code for setting the time through the browser?
Thanks!
Terry
Posted 15 December 2011 - 05:12 PM
Posted 16 December 2011 - 05:30 AM
Sure, I will post the code, but first I need to do some cleanup. I haven't had too much time to work on this project lately. The code is in the "first make it work" state. Basically what I set out to do was build a manager for the Netduino with enhanced functionality for the web server. I got sick of unplugging the SD card to transfer a file so I put together a PC client that issues url-encoded commands through the VB web browser control. It uploads and downloads files and data using the WebClient class. So then I had to write a more robust request parser for the web server and so on ...
I don't know anything about an event driven web server, but there is a lot of good VB socket programming stuff here,
http://vbex.ru/index.../Socket_Network
Back to your question, this is not the full project code, but the daytime server will fit into Nevyn's original process command method by simply adding an entry into the ProcessCommand Select Case structure.
Case "gettime" Send(client, "Time from Netduino: " & DateTime.Now.ToString) Case "settime" Using NIST_Time As DaytimeNIST = New DaytimeNIST("wwv.nist.gov", -8) NIST_Time.getTimeNIST() Dim newTime As String = DateTime.Now.ToString Send(client, "<html><body><p>" & "Set Time " & newTime & "</p></body></html>") End Using ------------------------------------------------------------------ Imports Microsoft.SPOT Imports Microsoft.SPOT.Hardware Imports SecretLabs.NETMF.Hardware Imports SecretLabs.NETMF.Hardware.NetduinoPlus Imports System.Threading Imports System.Net Imports System.Text Imports System.Net.Sockets Imports Microsoft.SPOT.Net.NetworkInformation ''' <summary> ''' Set Netduino Plus time using NIST Daytime Protocol ''' Upon return from getTimeNIST, the clock is running ''' with the correct correction for daylight savings or ''' standard time and the input UTC offset. ''' </summary> ''' <remarks></remarks> Public Class DaytimeNIST Implements IDisposable 'Private disposed As Boolean = False 'these servers are always reliable for Daytime protocol Private servers() As String = {"wwv.nist.gov", "utcnist2.colorado.edu", "utcnist.colorado.edu"} Private sIndex As Integer = 0 'server index Private buffer(51) As Byte 'Size of Daytime Protocol response Public Sub New() Me.TimeServer = servers(sIndex) sIndex += 1 End Sub Public Sub New(ByVal tServer As String, ByVal offsetUTC As Integer) Me.TimeServer = tServer.Trim Me.UTC_offset = offsetUTC End Sub Public Property TimeServer As String Public Property UTC_offset As Integer = -8 'Default: Pacific Time (US & Canada) Public Property successful As Boolean = False Public Property networkDateTime As String Public Sub getTimeNIST() 'format of Daytime string: JJJJJ YR-MO-DA HH:MM:SS TT L H msADV UTC(NIST) OTM Dim nBytes As Integer = 0 Dim count As Integer = 0 Dim stdTime As Integer = 0 Dim s1() As String = {} Dim s2() As String = {} Dim s3() As String = {} Dim success As Boolean = False ' Connect to timeserver Do While (nBytes = 0) count += 1 Using s As Socket = New Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp) Dim ep As IPEndPoint = New IPEndPoint(Dns.GetHostEntry(Me.TimeServer).AddressList(0), 13) s.Connect(ep) nBytes = s.Receive(buffer) s.Close() End Using If (nBytes <> 0) Then Dim resp As String = Encoding.UTF8.GetChars(buffer) s1 = resp.Split(" "c) s2 = s1(1).Split("-"c) 'yr, mo, day s3 = s1(2).Split(":"c) 'hr, min, sec Dim dst As Integer = CInt(s1(3)) 'Set the correct daylight or standard time If (dst = 0 Or dst > 51) Then 'on standard time stdTime = 0 ElseIf (dst <= 50 And dst > 1) Then stdTime = 1 End If Dim dt As DateTime = New DateTime(2000 + CInt(s2(0)), CInt(s2(1)), CInt(s2(2)), CInt(s3(0)), CInt(s3(1)), CInt(s3(2))).AddHours(Me.UTC_offset + stdTime) Utility.SetLocalTime(dt) Me.networkDateTime = resp Me.successful = True Exit Do End If Debug.Print("count = " & count.ToString) If (count = 3) Then If (sIndex <= 2) Then Me.TimeServer = servers(sIndex) sIndex += 1 'point to next server Debug.Print("Trying a different server : " & Me.TimeServer) count = 0 Else Debug.Print("tried 3 servers something is wrong") Exit Do End If End If Thread.Sleep(5000) 'per NIST instructions do not query more than once every 4 sec Loop End Sub #Region "IDisposable Support" Private disposedValue As Boolean ' To detect redundant calls ' IDisposable Protected Overridable Sub Dispose(disposing As Boolean) If Not Me.disposedValue Then If disposing Then ' TODO: dispose managed state (managed objects). Debug.Print("disposing Daytime Client ") Debug.Print("GC: " & Debug.GC(True).ToString) End If ' TODO: free unmanaged resources (unmanaged objects) and override Finalize() below. ' TODO: set large fields to null. End If Me.disposedValue = True End Sub ' TODO: override Finalize() only if Dispose(ByVal disposing As Boolean) above has code to free unmanaged resources. 'Protected Overrides Sub Finalize() ' ' Do not change this code. Put cleanup code in Dispose(ByVal disposing As Boolean) above. ' Dispose(False) ' MyBase.Finalize() 'End Sub ' This code added by Visual Basic to correctly implement the disposable pattern. Public Sub Dispose() Implements IDisposable.Dispose ' Do not change this code. Put cleanup code in Dispose(ByVal disposing As Boolean) above. Dispose(True) GC.SuppressFinalize(Me) End Sub #End Region End ClassBaxter
Posted 16 December 2011 - 02:19 PM
Posted 16 December 2011 - 03:34 PM
_MyTimerReset = New Timer(AddressOf MyTimerReset_Tick, Nothing, 1000 * 60 * 10, 1000 * 60 * 10)
Private Sub MyTimerReset_Tick(O As Object) PowerState.RebootDevice(False) End Sub
I found out the hard way that if you have 0 for the timer 'due time' (third variable in the new statement) -- you will brick the netduino since it is continually trying to reboot! The good news is that this forced me to update the TinyBootDecompressor
#19
Posted 16 December 2011 - 08:13 PM
When I first started with this server it would go down because of spurious requests. One in particular was the favicon that was coming from IE Explorer. Other times a request would be just nothing which I think was coming from the router. I had some network problems so I started switching out routers and then I started getting requests like:
GET /HNAP1/ HTTP/1.1
GET /TEADevInfo/ HTTP/1.1
I finally tracked this down to get the following information.
Quote:
"HNAP = Home Network Administration Protocol
TEADevInfo = a firmware file on DLink routers
The source of the requests is a program called "Network Magic" which is bundled with DLink routers. Apparently, this program scans all IP addresses on the LAN, looking for DLink routers."
N.B. I think this also happens with Cisco software. Search for HNAP Protocol
I kept adding traps in the While-Listen loop, but then it dawned on me to add a try-catch block within the Listen loop and eat the exception.
While (True) Try Using client As Socket = _socket.Accept() ---- ---- End Using Catch ex As SocketException Debug.Print(ex.StackTrace) End Try End While
This seemed to solve the problem of the server going down because of bad requests. YMMV
Baxter
#20
Posted 16 December 2011 - 09:18 PM
Hi Terry,
Baxter
Great Idea. I just added the TRY/CATCH.
