Hi I recently bought a Netduino and its been working fine for a while but for some reason it no longer works. Whenever I use visual studio to try to deploy the device it hangs and gives me the message "Preparing to deploy assemblies to the device". I tried a ping and erase using the Deployment Tool but it just hangs the application. All I did was run my application previously that was reading in analog values. I'm really stuck on this and any help would be really appreciated.
Thanks!
Cannot deploy
Started by Petezah, Aug 30 2010 09:50 PM
1 reply to this topic
Posted 30 August 2010 - 09:50 PM
Posted 30 August 2010 - 09:55 PM
Hi Petezah,
There was a bug in the early firmware related to AnalogInputs. Sorry about that.
To erase your current Netduino app (so that it works well again):
1. Unplug your Netduino from your computer (and unplug any attached accessories, shields, etc.)
2. Open up MFDeploy on your computer, select USB transport
3. Hold down the pushbutton on your Netduino and plug it into your PC; this will put it in "bootloader" mode
4. WITHIN FIVE SECONDS, press the PING button in MFDeploy. If should respond "TinyBooter." Then, press ERASE within ten seconds.
You can update your Netduino to the newest firmware here:
http://forums.netdui...e-v410-patch-2/
That should fix your AnalogInput woes. Please be sure to let us know how it works for you...
