problem with sd card
24 replies to this topic
#1 laik777
laik777
  • 12 posts
Posted 08 August 2011 - 09:41 AM
I have problems with sd card.
I am using NetduinoFirmware_v4.1.1.0_Beta1
Micro sd:
1GB
sd-C01G TAIWAN
My References in Visual Studio:
Microsoft.SPOT.Hardware
Microsoft.SPOT.IO
Microsoft.SPOT.Native
mscorlib
SecretLabs.NETMF.Hardware
SecretLabs.NETMF.Hardware.Netduino
SecretLabs.NETMF.Hardware.NetduinoPlus
SecretLabs.NETMF.IO
System
System.IO
Look i tried with this code:
using System.IO;
using SecretLabs.NETMF.IO;
using Microsoft.SPOT.IO;
namespace SDTest
DirectoryInfo rootDirectory = new DirectoryInfo(@"\\SD\\");
RecurseFolders(rootDirectory);
private static void RecurseFolders(DirectoryInfo directory)
if (directory.Exists)
Debug.Print(directory.FullName);
foreach (FileInfo file in directory.GetFiles())
Debug.Print(file.FullName);
foreach (DirectoryInfo subDirectory in directory.GetDirectories())
RecurseFolders(subDirectory);
and in output window i receive this:
There were deployment errors.
Device not found or cannot be opened-USB:NetduinoPlus
Please if someone could help me .
Thanks in advance
Edited by Stefan, 08 August 2011 - 09:47 AM.
Added [code] tags
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 08 August 2011 - 09:47 AM
Appairently Visual Studio can't find the Netduino. Could you try to go to your project Properties and look into the .NET Micro Framework-tab? There should be two pulldowns, you should be able to select the correct device there.
#3 laik777
laik777
  • 12 posts
Posted 08 August 2011 - 11:57 AM
When is debugging ask me: There were deployment errors.continue? i choose no. And then i receive in output window An error has occurred:please check your hardware. any suggestion?
#4 laik777
laik777
  • 12 posts
Posted 08 August 2011 - 12:05 PM
I have now deleted from references: SecretLabs.NETMF.IO And debugging is successufully. Output window: ************************* #### Exception System.IO.IOException - CLR_E_INVALID_DRIVER (1) #### #### Message: #### Microsoft.SPOT.IO.NativeIO::GetAttributes [IP: 0000] #### #### System.IO.Directory::Exists [IP: 0015] #### #### System.IO.DirectoryInfo::get_Exists [IP: 0007] #### #### SDTest.Program::RecurseFolders [IP: 0005] #### #### SDTest.Program::Main [IP: 000c] #### A first chance exception of type 'System.IO.IOException' occurred in Microsoft.SPOT.IO.dll The thread '<No Name>' (0x1) has exited with code 0 (0x0). Done. Waiting for debug commands... The program '[16] Micro Framework application: Managed' has exited with code 0 (0x0). ********************************************* Any idea?
#5 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 08 August 2011 - 12:22 PM
Have you tried changing the base location of the SD card? The above line is looking for a directory \\SD\\ and I think it should be \SD\
Hope this helps,
Edited - IE munged the post :)
Edited by Nevyn, 08 August 2011 - 12:23 PM.
#6 laik777
laik777
  • 12 posts
Posted 08 August 2011 - 12:53 PM
I have tested with DirectoryInfo rootDirectory = new DirectoryInfo(@"\SD\"); still not working.....
#7 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 08 August 2011 - 01:34 PM
I have tested with
Could you create a zip file of your project and upload it here? Perhaps it gives a better view of the actual problem.
#8 Chris Walker
Posted 08 August 2011 - 07:14 PM
Also, please check to make sure that your reference to SecretLabs.NETMF.IO is v4.1 instead of v4.2. Chris
#9 laik777
laik777
  • 12 posts
Posted 09 August 2011 - 06:36 AM
I have firmware version: SolutionReleaseInfo.solutionVendorInfo: Netduino (v4.1.1.0 b1) by Secret Labs LLC And my Reference is SecretLabs.NETMF.IO_BETA1 Here is all program........
#10 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 09 August 2011 - 06:54 AM
Your project also has references to: Blinq.Netduino and SecretLabs.NETMF.Hardware.Netduino Try removing both, don't remove SecretLabs.NETMF.Hardware.NetduinoPlus though :)
#11 laik777
laik777
  • 12 posts
Posted 09 August 2011 - 06:57 AM
On your netduinoplus work my program?
#12 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 09 August 2011 - 07:45 AM
I had to remove those dependencies and configured it as a 4.2 project (my Plus has the 4.2 firmware) but it worked :)
#13 laik777
laik777
  • 12 posts
Posted 09 August 2011 - 08:27 AM
Thanks man for help. Where did you download this firmvare v2? And you are using my References?
#14 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 09 August 2011 - 08:37 AM
http://forums.netdui...mware-v420-rc1/ but it's not a final release
yep, except the two mentioned in my previous post :)
#15 laik777
laik777
  • 12 posts
Posted 10 August 2011 - 07:06 AM
I am getting little closer to goal. I have now : NetduinoPlusFirmware_v4.2.0.0_RC1 Microsoft .Net micro framework Framework 4.2 My outputwindow: ******************************************** Attaching file. Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0) (184 RAM - 440 ROM - 166 METADATA) Loading Deployment Assemblies. Attaching deployed file. Assembly: NetduinoPlusApplication1 (1.0.0.0) (220 RAM - 572 ROM - 251 METADATA) Attaching deployed file. Assembly: SecretLabs.NETMF.IO (4.1.0.0) (236 RAM - 564 ROM - 279 METADATA) Attaching deployed file. Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.2.0.0) (272 RAM - 816 ROM - 423 METADATA) Resolving. Link failure: some assembly references cannot be resolved!! Assembly: SecretLabs.NETMF.IO (4.1.0.0) needs assembly 'mscorlib' (4.1.2821.0) Assembly: SecretLabs.NETMF.IO (4.1.0.0) needs assembly 'Microsoft.SPOT.Hardware' (4.1.2821.0) Error: a3000000 Waiting for debug commands... The program '[6] Micro Framework application: Managed' has exited with code 0 (0x0). ******************************** Do you know where is a problem?
#16 Chris Walker
Posted 10 August 2011 - 07:07 AM
Hi laik777, Remove the SecretLabs.* references from your project. Then add the same files--but from the .NET MF 4.2 SDK directory: C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2 That should get you up and running... Chris
#17 laik777
laik777
  • 12 posts
Posted 10 August 2011 - 08:11 AM
It works :) Thanks all for help.!!!!!!!
#18 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 10 August 2011 - 09:37 AM
It works :)
Glad to see that. Enjoy your Netduino Plus! :D
#19 netduinoNoob
netduinoNoob
Posted 20 September 2011 - 05:50 AM
Help please! I'm getting this error: ------ Build started: Project: SDcardApp, Configuration: Debug Any CPU ------ Build started 9/20/2011 12:48:47 AM. CoreCompile: C:\Windows\Microsoft.NET\Framework\v4.0.30319\Csc.exe /noconfig /nowarn:1701,1702 /nostdlib+ /errorreport:prompt /warn:4 /define:DEBUG;TRACE;MF_FRAMEWORK_VERSION_V4_2 /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll" /reference:"C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.dll" /reference:"C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.NetduinoPlus.dll" /reference:"C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.IO.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll" /debug+ /debug:full /nowin32manifest /optimize- /out:obj\Debug\SDcardApp.exe /target:exe Properties\AssemblyInfo.cs Program.cs EnsureEndianAwareDirectories: Creating directory "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\le". Creating directory "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\be". Creating directory "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\le". Creating directory "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\be". CopyExeToEndian: Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\SDcardApp.exe" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\le\SDcardApp.exe". Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\SDcardApp.exe" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\be\SDcardApp.exe". Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\SDcardApp.pdb" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\le\SDcardApp.pdb". Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\SDcardApp.pdb" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\be\SDcardApp.pdb". MetaDataProcessorBE: C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Tools\MetaDataProcessor.exe -loadHints Microsoft.SPOT.Hardware "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll" -loadHints Microsoft.SPOT.IO "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll" -loadHints Microsoft.SPOT.Native "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll" -loadHints Microsoft.SPOT.Net "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll" -loadHints mscorlib "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll" -loadHints SecretLabs.NETMF.Hardware "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.dll" -loadHints SecretLabs.NETMF.Hardware.NetduinoPlus "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.NetduinoPlus.dll" -loadHints SecretLabs.NETMF.IO "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.IO.dll" -loadHints System "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll" -loadHints System.IO "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll" -endian be -parse "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\be\SDcardApp.exe" -minimize -compile "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\be\SDcardApp.pe" MetaDataProcessor: C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Tools\MetaDataProcessor.exe -loadHints Microsoft.SPOT.Hardware "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll" -loadHints Microsoft.SPOT.IO "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll" -loadHints Microsoft.SPOT.Native "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll" -loadHints Microsoft.SPOT.Net "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll" -loadHints mscorlib "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll" -loadHints SecretLabs.NETMF.Hardware "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.dll" -loadHints SecretLabs.NETMF.Hardware.NetduinoPlus "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.NetduinoPlus.dll" -loadHints SecretLabs.NETMF.IO "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.IO.dll" -loadHints System "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll" -loadHints System.IO "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll" -endian le -parse "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\le\SDcardApp.exe" -minimize -compile "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\le\SDcardApp.pe" _CopyFilesMarkedCopyLocal: Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.dll" to "bin\Debug\SecretLabs.NETMF.Hardware.dll". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.NetduinoPlus.dll" to "bin\Debug\SecretLabs.NETMF.Hardware.NetduinoPlus.dll". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.IO.dll" to "bin\Debug\SecretLabs.NETMF.IO.dll". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.pdb" to "bin\Debug\SecretLabs.NETMF.Hardware.pdb". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.Hardware.NetduinoPlus.pdb" to "bin\Debug\SecretLabs.NETMF.Hardware.NetduinoPlus.pdb". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\SecretLabs.NETMF.IO.pdb" to "bin\Debug\SecretLabs.NETMF.IO.pdb". CopyFilesToOutputDirectory: Copying file from "obj\Debug\SDcardApp.exe" to "bin\Debug\SDcardApp.exe". SDcardApp -> C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\SDcardApp.exe Copying file from "obj\Debug\SDcardApp.pdb" to "bin\Debug\SDcardApp.pdb". CopyTinyCLRFiles: Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\le\SDcardApp.pe" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\le\SDcardApp.pe". Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\le\SDcardApp.pdbx" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\le\SDcardApp.pdbx". Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\be\SDcardApp.pe" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\be\SDcardApp.pe". Copying file from "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\obj\Debug\be\SDcardApp.pdbx" to "C:\Users\Kelvin\Documents\Visual Studio 2010\Projects\CS\NetduinoPlus\SDcardApp\SDcardApp\bin\Debug\be\SDcardApp.pdbx". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\LE\SecretLabs.NETMF.Hardware.pe" to "bin\Debug\LE\SecretLabs.NETMF.Hardware.pe". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\LE\SecretLabs.NETMF.Hardware.NetduinoPlus.pe" to "bin\Debug\LE\SecretLabs.NETMF.Hardware.NetduinoPlus.pe". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\LE\SecretLabs.NETMF.IO.pe" to "bin\Debug\LE\SecretLabs.NETMF.IO.pe". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\BE\SecretLabs.NETMF.Hardware.pe" to "bin\Debug\BE\SecretLabs.NETMF.Hardware.pe". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\BE\SecretLabs.NETMF.Hardware.NetduinoPlus.pe" to "bin\Debug\BE\SecretLabs.NETMF.Hardware.NetduinoPlus.pe". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\BE\SecretLabs.NETMF.IO.pe" to "bin\Debug\BE\SecretLabs.NETMF.IO.pe". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\LE\SecretLabs.NETMF.Hardware.pdbx" to "bin\Debug\LE\SecretLabs.NETMF.Hardware.pdbx". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\LE\SecretLabs.NETMF.Hardware.NetduinoPlus.pdbx" to "bin\Debug\LE\SecretLabs.NETMF.Hardware.NetduinoPlus.pdbx". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\LE\SecretLabs.NETMF.IO.pdbx" to "bin\Debug\LE\SecretLabs.NETMF.IO.pdbx". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\BE\SecretLabs.NETMF.Hardware.pdbx" to "bin\Debug\BE\SecretLabs.NETMF.Hardware.pdbx". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\BE\SecretLabs.NETMF.Hardware.NetduinoPlus.pdbx" to "bin\Debug\BE\SecretLabs.NETMF.Hardware.NetduinoPlus.pdbx". Copying file from "C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\BE\SecretLabs.NETMF.IO.pdbx" to "bin\Debug\BE\SecretLabs.NETMF.IO.pdbx". Build succeeded. Time Elapsed 00:00:01.21 ------ Deploy started: Project: SDcardApp, Configuration: Debug Any CPU ------ Cannot deploy the base assembly 'mscorlib', or any of his satellite assemblies, to device - USB:NetduinoPlus twice. Assembly 'mscorlib' on the device has version 4.1.2821.0, while the program is trying to deploy version 4.2.0.0 ========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ========== ========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========
#20 Bryan Bredehoeft
Bryan Bredehoeft
Posted 10 May 2012 - 07:31 PM
Hi, Still having trouble writing to my SD card. Tried the sample, but cannot find "SecretLabs.NETMF.IO.pe." I re-installed Netduino SDK v4.1.0 (64-bit) just now and re-launched C# Express. "C:\data\Desktop\SDCardTest\SDCardTest\SDCardTest\bin\Debug\LE\SecretLabs.NETMF.IO.pe" because it was not found. Environment: HalSystemInfo.halVersion: 4.1.2821.0 HalSystemInfo.halVendorInfo: Netduino Plus by Secret Labs LLC HalSystemInfo.oemCode: 34 HalSystemInfo.modelCode: 177 HalSystemInfo.skuCode: 4097 HalSystemInfo.moduleSerialNumber: 00000000000000000000000000000000 HalSystemInfo.systemSerialNumber: 0000000000000000 ClrInfo.clrVersion: 4.1.2821.0 ClrInfo.clrVendorInfo: Netduino Plus by Secret Labs LLC ClrInfo.targetFrameworkVersion: 4.1.2821.0 SolutionReleaseInfo.solutionVersion: 4.1.0.6 SolutionReleaseInfo.solutionVendorInfo: Netduino Plus by Secret Labs LLC SoftwareVersion.BuildDate: Feb 14 2011 SoftwareVersion.CompilerVersion: 400902 FloatingPoint: True SourceLevelDebugging: True ThreadCreateEx: True LCD.Width: 0 LCD.Height: 0 LCD.BitsPerPixel: 0 AppDomains: True ExceptionFilters: True IncrementalDeployment: True SoftReboot: True Profiling: False ProfilingAllocations: False ProfilingCalls: False IsUnknown: False
