Measuring Angle of Attack
Posted 18 July 2011 - 02:31 PM
Question – I want to measure the angle of an object relative to the Earth. The Netduino+ and sensors will be on the object in question. I haven’t found a solution that meets all the requirements perfectly. I’m hoping someone has a better idea.
Details
• Object will be somewhere between 1 and 20 feet above a smooth floor.
• The angle relative to the Earth will be at most +/- 10 degrees
• I need the best resolution I can get… certainly less than 1 degree. 0.1 degrees would be great!
• I will need height also, but that can be separate sensors.
What I’ve Considered – I’ve ordered them to my best candidate based on my understanding of their limitations.
1. Using two of the ultrasonic sensors (http://www.sparkfun.com/products/9491) and measuring their relative height above the floor. Con: There resolution is 1 cm, so I’d need to have the two sensors over 18 feet apart to get my desired 0.1 degree resolution. I’d like to keep their distance apart less than 5 feet. Con: Expense… I’ll need about 20 of them… $900 Ouch!
2. Using two of the infrared sensors (http://www.sparkfun.com/products/242). Pro: Resolution is good enough. Con: Distance above the floor is too limited.
3. Using a gyro (http://www.sparkfun.com/products/9059). Con: It measures angular velocity and I’m under the impression that between factors like drift and the integration, I can not rely on it giving me repeatable results.
4. Using a two axis accelerometer (http://www.sparkfun.com/products/844) and calculating angle using a little Trig knowing gravity = 1.0. Con: Unfortunately the object may be accelerating up, down, forward and backward and I can’t see a way of removing those extra acceleration vectors.
If my message helped you... how 'bout giving me a
www.MessingWithReality.com
Posted 20 July 2011 - 12:09 PM
Have you considered measuring magnetic field?
You know... I had a mental block... I was thinking liquid filled compass, 2D, in the horizontal plane.
But, you're right... From a high school physics standpoint, I recall... they are just lines of force and in 3D.
THANKS! That's the out-of-the-box thinking I was hoping for!
I'll dig into it tonight.
Posted 20 July 2011 - 12:19 PM
Posted 20 July 2011 - 12:48 PM
I am sorry, but...are you meaning the angle with the Y-axis, being perpendicular to the floor?
If so, why not a simple potentiometer (maybe a precision one), then read the resistance with some (simple) circuit?
I appreciate your response... and keeping me honest!
I neglected to mention... the object is flying and I'm needing an accurate determination of its pitch angle (AOA)... hopefully in the 0.1 degree range.
Posted 24 July 2011 - 12:33 AM
I agree with Mario, just use a simple pendulum constrained to only swinging in one plane (like the pendulum on a grandfather clock). The pendulum would swing from a simple potentiometer, and like he says there are simple ways to very accurately measure resistance. If you're worried about vibrations you could make it small and encase it in a box filled with nonconducting oil to dampen the vibrations. The viscosity of the oil would dictate how much damping you get.I appreciate your response... and keeping me honest!
Posted 24 July 2011 - 04:38 PM
Auger in!
Well... unfortunately, a pendulum although simple, won't work in my case. Think of this as being a low-flying airplane...
- It will be accelerating faster and slower - thus the pendulum's inertia will give a false reading and drive the plane into the ground or stall it.
- It will have some speed say (30 knots) – thus the pendulum’s air resistance will give a false reading and drive the plane into the ground.
- Every gram counts – Weights at the end of a pendulum, oil bath, etc… and the plane will never get off the ground.
Although complex computationally, if it works as I've been reading the magnetometer sounds like a good bet so far. I’ve got to get one and see. It has the benefits of (1) no inertia, (2) no air resistance and (3) light weight. Just got to see how it works in the real world.
Posted 26 July 2011 - 11:35 AM
Hum, if the object is flying, the AOA has nothing to do with an angle with the earth, but an angle related to the relative wind. So, unless what you want to measure is NOT the AOA, the different sensors you have been talking about so far are not appropriate. Maybe you need to read, or re-read this : http://en.wikipedia....Angle_of_attack
Remember that in a banking turn, that is with the wings at 90° to the earth, an airplane is still flying and can reach a critical AOA causing a high speed stall....AND THAT is the kind of flight step where accurately measuring the AOA might help to save the plane....
From what you say, we are talking about 2 different things, so you are not talking about AOA.
Posted 26 July 2011 - 11:39 AM
Posted 26 July 2011 - 08:34 PM
Hum, if the object is flying, the AOA has nothing...
FOR MY VERY SPECIFIC SITUATION - Everything I have stated is completely accurate... including AOA and it being “possible” to calculate it using the Earth’s gravity or magnetic fields (thanks JonnyBoats) as a relative datum.
Posted 26 July 2011 - 09:04 PM
Can a potentiometer be configured such that by moving through only 10 degrees, the resulting input into the Netduino’s analog port uses its full 10bits without too much “noise” or resorting to a mechanical gear and be “fairly” linear? Would anyone be willing to suggest a circuit that might accomplish this?
Thanks!
Posted 09 October 2011 - 11:43 PM
And even though BernardG’s comments were derogatory in nature, I will try to use them constructively. I’m quite secure with my aerodynamic understanding, but my electronics knowledge is limited.
Thanks!
Bernards comments we a bit harsh, but did bare some truth. If I understood him correctly, he was saying that if a plane were in a 90 degree bank it could still measure AOA. That is true. An AOA measurement in a 90 degree bank however isnt very helpful. A critical AOA in a 90 degree bank wouldnt cause the pane to stall, to low an airspeed would and ever dropping altitude would. If you are in a perfect 90 degree bank, its virtually impossible to produce or maintain any lift unless you used the rudder as an elevator (dont think that would produce enough lift to keep that rock in the air).
From the initial post, I assume youll only need the AOA(pitch angle) when your straight and level. If this is the case, either a magnetometer or potentiometer will work.
The magnetometer would probably give the most accurate result but does require quite a mit of math and code to get it measuring correctly. If you have the know how and code space, that is the way to go.
The potentiometer would be the simplest route. It will however only measure accurately when your wings are level assuming the pot is mounted to measure the pitch axis. If the plane is fairly slow moving, a weighted lever(weight as far to the end as possible) and averaging (in the code, read the pot 5 or 10 times then take the average) should give you pretty good results.
in response to getting the full 0v to 5v or 3.3v (depending on the microprocessor used) from only 20 (+-10) degrees of movement, I would learn about op-amps. Figure out the voltage difference the pot would yield in that 20(I would go 30 to be safe) degrees of movement and figure out which op amp would amplify that range to the 5V or 3.3V that you need.
Posted 10 October 2011 - 02:23 AM
Posted 10 October 2011 - 04:27 AM
