Getting Started with the Internet of Things by Cuno Pfister
Posted 22 June 2011 - 09:16 AM
Posted 22 June 2011 - 07:28 PM
Posted 27 June 2011 - 06:41 PM
Simon,
could you please post the result of MFDeploy's Device Capabilities command? That might be helpful.
Of course, I would also like to hear of others who tried out the server examples. Yaler traffic indicates that some readers successfully use servers based on the book examples, but I don't know much more than that.
Cuno
Thanks for the pointer Cuno.
Here it is...
HalSystemInfo.halVersion: 4.1.2821.0
HalSystemInfo.halVendorInfo: Netduino Plus by Secret Labs LLC
HalSystemInfo.oemCode: 34
HalSystemInfo.modelCode: 177
HalSystemInfo.skuCode: 4097
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Netduino Plus by Secret Labs LLC
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.0.6
SolutionReleaseInfo.solutionVendorInfo: Netduino Plus by Secret Labs LLC
SoftwareVersion.BuildDate: Feb 14 2011
SoftwareVersion.CompilerVersion: 400902
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 0
LCD.Height: 0
LCD.BitsPerPixel: 0
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
Posted 27 June 2011 - 11:05 PM
Posted 27 June 2011 - 11:12 PM
Posted 29 June 2011 - 08:55 AM
Posted 30 June 2011 - 11:54 AM
I've provided a small diagnostics program (GsiotDiagnostics) at my book Web site http://www.gsiot.info/download/. Could you please run it?
And as Simon indicated, did you try HelloWeb with the RelayDomain and RelaySecretKey properties removed (e.g., commented out)?
Best regards
Cuno
Posted 30 June 2011 - 11:57 AM
please replace the Gsiot.Server directory in your Visual Studio Projects directory with a test version of Gsiot.Server that I provide at my book Web site http://www.gsiot.info/download/. It gives more debug output.
Thanks and best regards
Cuno
Posted 01 July 2011 - 11:47 AM
- TechnoGuy likes this
Posted 01 July 2011 - 09:07 PM
Posted 02 July 2011 - 08:50 AM
Posted 09 July 2011 - 05:10 PM
Posted 10 July 2011 - 08:42 PM
http://try.yaler.net...XXXX-XXXX/hello
After many attempts, I came across Simon's suggestion and applied it. It worked! Now, I can continue to the book's next example "HelloWebHtml".
Congratulations to Cuno Pfister for his excellent, very well explained, book!
Regards
Posted 05 September 2011 - 05:43 AM
Posted 05 September 2011 - 07:47 AM
Hi Tim,I am having trouble getting the 'HelloPatchube' example in chapter 6 to compile. I am using Visual C# 2010 Express, I have downloaded and installed the 'Gsiot.Server+V20110630+test+version' zip file into the visual studio\projects directory in MyDocuments, added in the reference to the dll
thanks for reading my book! The project Gsiot.Server only contains support for Web servers, not for Web clients. "HelloPachube" is a client program and needs the project "Gsiot.PachubeClient". The project is contained in this zip file.
Hope that helps!
Best regards
Cuno
Posted 05 September 2011 - 11:55 AM
Hi Tim,
Hope that helps!
Best regards
Cuno
Cuno
Thanks for the help, much appreciated, I will try it out now.
I think I must have got myself confused somewhere along the way.
Great book by the way, good explanations and fantastic approach.
Well done.
Tim
Posted 05 September 2011 - 12:05 PM
Cuno
Well done.
Tim
Cuno
My build issue is all sorted now, many thanks.
I was definitely looking at it way too long and could not see what was staring at me.
Now to add my apiKey and feedId .....
Tim
#19
Posted 20 September 2011 - 08:41 PM
#20
Posted 21 September 2011 - 12:31 PM
I just received a Netduino Plus today and have been following the examples in the GSIOT book. I have been trying to get the board to work on my local network with no success. It is connected through a swich to the router. The PC is connected to the same switch and is working OK. When I run the HelloWeb app with the RelayDomain lines commented out I see this in the Output window:
DHCP enabled: True
MAC address: 5C-86-4A-00-1E-33
Device address: 192.168.5.100
Gateway address: 192.168.5.1
Primary DNS address: 208.67.222.222
Base Uri: http://192.168.5.100/
My DHCP is set to a range of 192.168.1.100 and up. If I look at the router's DHCP table all my devices are there but the Netduino.
Explorer will not connect to the Base URI (http://192.168.5.100/hello).
I ran the GSIOTDiagnostics program and it crashed after a nullrangeexception for s and a socketexception of 10060. So it appears to not be connected to my network. I tried a different Enet cable on the port that the PC was working on with no success.
Suggestions?
Phil
Phil, I ran mine using the free relay site, yaler, and it worked pretty much first go. I have not tried a local only version just yet. If I get a chance I will try it out and let you know. I have a similar networking setup at home myself. I did give the NetDuino Plus a static ip address outside the dynamic range my router can use.
Did you have any issues running the "C:\Program Files\Microsoft .NET Micro Framework\v4.1\Tools\
MFDeploy.exe" tool ?
