I'm probably doing something utterly stupid.
Using the micro framework...
The System.Math.ABS will only take a type int...it seems to have only that one overload.
Same with System.Math.Round... will take a double, but not a second parameter to specify the number of places to round to.
Anyone else seen this?
System.Math problem
Started by PawleysPlayr, Jun 01 2011 04:33 PM
Posted 01 June 2011 - 04:33 PM
Posted 02 June 2011 - 07:05 AM
The math is something that the MF guys decided to cut enough (IMHO).
Integers are obviously limited for the math, but doubles are too heavy for the MF.
I suggest to use floats unless strictly necessary.
The Abs is straightforward:
public static float Abs(float value) { return (value >= 0) ? value : -value; }To round a value by a certain number of decimals, you may use this function:
private static float[] PowersOfTen = new float[] { 1.0f, 10.0f, 100.0f, 1000.0f, 10000.0f, 100000.0f, 1000000.0f, // etc. } public static float Round(float value, int digits) { var power = PowersOfTen[digits]; return power * (long)(value / power); }NOTE: I used an explicit cast to a long, because it does exactly what I need and it is very fast. However a long is much limited in range respect to a float.
Posted 02 June 2011 - 11:39 AM
Thanks Mario!
