Best Answer Chris Walker, 27 May 2011 - 03:56 PM
Hi João,
You can use Keil with Netduino.Is possible to use Keil with netduino?
If you want to compile the .NET Micro Framework firmware with the Keil MDK, that should be supported by the .NET Micro Framework Platform Kit. See instructions in the "C:\MicroFrameworkPK_v4_1\Documentation\RCLPort.chm" file.
If you want to write C++ code for your Netduino and compile with Keil, you can erase the Netduino's .NET Micro Framework firmware. Just connect a jumper wire between the 3.3V header and the ERASE pad (gold pad underneath digital pin 0). Then depower/repower and use Atmel SAM-BA to deploy your Keil-compiled code. You can use the Atmel SAM7X reference sample as a starting point.
Chris Go to the full post
