I have tried 2 different approaches none of which work: using a RS232 cable and using a USB->RS232 conversion cable.
- I'm running Windows 7 (32 bit)
- The netduino mini is powered using 5 volts from a FTDI USB cable through pin 21 + GND (I also tried powering it through VIN with 9 volts)
- I'm using SAM-BA CDC 2.10
- The COM ports on the computer are configured @ 115200 / 8 / none / 1 / none
- I've tested that the serial cables are good in TeraTerm
- The RS232 cable on the computer is connected to the RS232 port on the netduino (pin 1 & 2 + ground)
Any help would be appreciated.
-Fabien.
PS: this never happens flashing a regular netduino / netduino Plus: SAM-BA always connects fine.
