I believe you, thats why I'm not going to solder anything yetSure Stefan don't believe me if not check the tech spec page. analog input is from 0 to 3.3 V at a max of 2mA per pin.
If I didn't believe you I already tried it all out and perhaps would be virtually crying now because of broken analog inputs
Already thought about modifying the board by disconnecting the +5V pin from the PCB and connect it to the +3V. Only downside would be that the led resistors will be a bit too high, although it will be hardly noticed I suppose. But it would be amazing if it worked without modifications, that's why I am asking.
