Internet access without a router
Posted 09 April 2011 - 08:49 AM
Posted 09 April 2011 - 10:54 AM
Would it be possible to connect the board to the laptop I'm using to program it, and somehow get access to the internet + valid IP address? If so, what are the configuration steps? Or do I need to get one of those wifi bridges/hotspots that bridge Ethernet to wifi (like the ASUS WL530g, to name a cheap one)?
Assuming you're talking Windows, I'd be thinking cross over cable to connect the N+ to the PC and set up the PC to allow internet connection sharing.
Broadly speaking the steps are:
Use MFDeploy to check the network configuration on the N+. I'd probably start with static IP first as some people have had problems with DHCP. That way if you hit problems you won't be troubleshooting DHCP issues.
Configure the network port (not the WiFi port) on the laptop to use a similar IP address and the same subnet mask. The N+ and the PC should now be able to talk over the cross over cable.
Configure the PC to allow internet connection sharing - the method for doing tis varies depending upon the OS you are using. Google should be your friend there.
Hope this helps,
Posted 09 April 2011 - 05:07 PM
Posted 09 April 2011 - 11:03 PM
Posted 13 April 2011 - 08:08 PM
Posted 13 May 2011 - 11:07 PM
The ASUS router is good. I am using a Fonera router. Both can run off 5V. I have an Energizer XP8000 battery pack powering the netduino and fonera. Everything is Velcroed together.
May I ask where did you get the Fonera? Been looking all over for them...
