SimpleNGen 1.0
22 replies to this topic
#1 Corey Kosak
Corey Kosak
  • 276 posts
  • LocationHoboken, NJ
Posted 03 April 2011 - 05:32 AM
The purpose of this project is to provide a new way to do native-side programming that is more friendly than reflashing the firmware (and also more friendly than my previous attempt, the so-called Fluent Interop). In this version, the language you write in is C# (though a very restricted subset of it). This code is first compiled by the C# compiler, and then the resulting MSIL opcodes are recompiled by my system into ARM machine language.
I have been working on a prototype for a little while and, although it is still in the early stages, I've just gotten it to do something useful and so I wanted to share my results.
Here is a Saleae screenshot of an implementation of BitBanger sending the bytes 'Hello' (if you look closely at the screenshot, just under the time axis, you can actually see the Saleae UI showing the ASCII characters)
I'm sending 40 bits in 16.6667 microseconds for a rate of 2.4 megabits/second. Not bad!
What follows is a walkthrough of how I think the system ought to work. The items in black text are working now; the items in red text are not working yet (and so one must work around them, e.g. by doing a bunch of laborious cutting and pasting). In a future version things will work more smoothly. The steps are somewhat involved, so I will try to go over them in detail.
These instructions are meant to show how the system will eventually work. The instructions are included here for completeness, but it is probably too early for you to try them on your system unless you are a glutton for punishment.
  • Flash your Netduino with an interop-capable version of the firmware. Chris Walker has graciously built a custom version of the firmware which is based on v4.1.1 beta 1 but which includes the needed entry point. I have attached the firmware to this post.
  • Download and build my SimpleNgen "compiler". This is a full-framework program meant to be run on your PC.
  • Make a new C# project (that is, a Netduino project, not a full-framework project) which references my SimpleInterop library. Set the build options to "allow unsafe code" and "optimize code". The latter is not necessary but will probably make for better ARM output
  • In the IDE, under "Add Class", make two new files: BitBanger.cs and BitBanger.Designer.cs
  • The first file is the one into which you will write your code. [The second file will be written to by my compiler]
  • Write your code conforming to the limitations outlined in the next section.
  • [Configure a "post-build step" in your project to invoke my compiler. The result of this post-build step will be to write an array representing compiled code to BitBanger.Designer.cs]
  • Compile your code once [if successful, it will invoke the post-build step and rewrite BitBanger.Designer.cs]. Then compile it a second time to include the compiled code in your solution.
Here is the source code I wrote for BitBanger.cs which appears in the attached NGgenSandbox.sln:
namespace NgenSandbox {
  public unsafe static partial class BitBanger {
    private const int data=(int)Pins.GPIO_PIN_D0;
    private const int clock=(int)Pins.GPIO_PIN_D1;
    private const int enable=(int)Pins.GPIO_PIN_D2;
    public static int Bang(int length, int dummy1, int dummy2, int dummy3, byte *buffer) {
      //set up the three pins I need for SPI: MOSI, CLOCK, and ENABLE
      var dataPio=(int*)(Pio.BankBase+((data&0x20)<<4));
      const int dataBitmask=1<<(data&0x1f);
      var clockPio=(int*)(Pio.BankBase+((clock&0x20)<<4));
      const int clockBitmask=1<<(clock&0x1f);
      var enablePio=(int*)(Pio.BankBase+((enable&0x20)<<4));
      const int enableBitmask=1<<(enable&0x1f);
      //initialize the hardware registers
      dataPio[Pio.PER]=dataBitmask; //enable data pin
      dataPio[Pio.OER]=dataBitmask; //configure data for output
      //don't care about the initial state of the data pin
      clockPio[Pio.PER]=clockBitmask; //enable clock pin
      clockPio[Pio.OER]=clockBitmask; //configure clock pin for output
      clockPio[Pio.CODR]=clockBitmask; //set clock initially low
      enablePio[Pio.PER]=enableBitmask; //enable SPI 'enable' pin
      enablePio[Pio.OER]=enableBitmask; //configure 'enable' pin for output
      enablePio[Pio.CODR]=enableBitmask; //set enable pin low to begin transaction
      //loop over my buffer
      for(var i=0; i<length; ++i) {
        var nextByte=buffer[i];
        //loop over the bits in my byte
        for(var bitmask=0x80; bitmask!=0; bitmask>>=1) {
          clockPio[Pio.SODR]=clockBitmask; //set clock high
          if((nextByte&(bitmask))!=0) {
            dataPio[Pio.SODR]=dataBitmask; //set data
          } else {
            dataPio[Pio.CODR]=dataBitmask; //clear data
          clockPio[Pio.CODR]=clockBitmask; //set clock low
      enablePio[Pio.SODR]=enableBitmask; //set enable pin high to end transaction
      return 0;
  public static class Pio {
    public const uint BankBase=0xfffff400;
    public const int PER=0;
    public const int OER=4;
    public const int ODR=5;
    public const int SODR=12;
    public const int CODR=13;
    public const int PDSR=15;
There are several things to note here:
  • Most importantly, this is all written in C# (though admittedly making heavy use of unsafe constructs like pointers)
  • The routine to be compiled is called "Bang" (in this case). The interop entry point requires a return type of int, and the following types (or some prefix of it) as the arguments: (int, int, int, int, Array, Array, Array, Array)
  • Those of you old-timers who recall my 17-element Unicode argument list are probably breathing a sigh of relief
  • For the Array items, you can mix-and-match any simple-type arrays you like (e.g. byte[], short[], int[]), so long as the caller and callee agree. There's no type-checking at this level, so take care to get the types right.
  • The only types allowed in Bang are int, byte, int*, and byte*. I might support short if I get around to it. In particular there's certainly no support for any reference type, so forget about calling new here or using strings. You can't even use arrays (a reference type); you have to use pointer types. This latter concern is what forces you to mark the class with the unsafe keyword. In this case, a completely apt keyword.
  • The class is also marked with the partial keyword. [This is because the compiler will write its output to another part of the partial class defined in BitBanger.Designer.cs]
  • Notice I can reference other classes (as I did here with the Pio class) but only in a very limited way: to pull in constant values and enumeration values.
  • I have hardcoded the pin numbers at compile time (not necessary but they make the code run fast)
  • I'm directly accessing the I/O registers for fast throughput
Once you compile the above program in Visual Studio, the C# compiler will write out the MSIL (".NET") opcodes to the DLL/EXE/wherever it puts them. In the final system, the SimpleNgen compiler would at this point automatically be invoked to read those opcodes and translate them into ARM. In the current system that doesn't exist yet. So what we have to do instead is this extremely laborious and time-intensive process.
  • Run ildasm
  • Copy the opcodes to the clipboard
  • Paste them into the source code of the compiler, and rewrite them to the compiler's taste
  • Run the compiler
  • Paste its output back into BitBanger.Designer.cs
  • Finally, run your program on the Netduino
Again, in the real system most of the above would be automated
Here is the output of ildasm on the above program:
.method public hidebysig static int32  Bang(int32 length,
                                            int32 dummy1,
                                            int32 dummy2,
                                            int32 dummy3,
                                            uint8* buffer) cil managed
  // Code size       185 (0xb9)
  .maxstack  2
  .locals init ([0] int32* dataPio,
           [1] int32* clockPio,
           [2] int32* enablePio,
           [3] int32 i,
           [4] uint8 nextByte,
           [5] int32 bitmask)
  IL_0000:  ldc.i4     0xfffff400
  IL_0005:  conv.u
  IL_0006:  stloc.0
  IL_0007:  ldc.i4     0xfffff400
  IL_000c:  conv.u
  IL_000d:  stloc.1
  IL_000e:  ldc.i4     0xfffff400
  IL_0013:  conv.u
  IL_0014:  stloc.2
  IL_0015:  ldloc.0
  IL_0016:  ldc.i4     0x8000000
  IL_001b:  stind.i4
  IL_001c:  ldloc.0
  IL_001d:  ldc.i4.s   16
  IL_001f:  conv.i
  IL_0020:  add
  IL_0021:  ldc.i4     0x8000000
  IL_0026:  stind.i4
  IL_0027:  ldloc.1
  IL_0028:  ldc.i4     0x10000000
  IL_002d:  stind.i4
  IL_002e:  ldloc.1
  IL_002f:  ldc.i4.s   16
  IL_0031:  conv.i
  IL_0032:  add
  IL_0033:  ldc.i4     0x10000000
  IL_0038:  stind.i4
  IL_0039:  ldloc.1
  IL_003a:  ldc.i4.s   52
  IL_003c:  conv.i
  IL_003d:  add
  IL_003e:  ldc.i4     0x10000000
  IL_0043:  stind.i4
  IL_0044:  ldloc.2
  IL_0045:  ldc.i4.1
  IL_0046:  stind.i4
  IL_0047:  ldloc.2
  IL_0048:  ldc.i4.s   16
  IL_004a:  conv.i
  IL_004b:  add
  IL_004c:  ldc.i4.1
  IL_004d:  stind.i4
  IL_004e:  ldloc.2
  IL_004f:  ldc.i4.s   52
  IL_0051:  conv.i
  IL_0052:  add
  IL_0053:  ldc.i4.1
  IL_0054:  stind.i4
  IL_0055:  ldc.i4.0
  IL_0056:  stloc.3
  IL_0057:  br.s       IL_00ac
  IL_0059:  ldarg.s    buffer
  IL_005b:  ldloc.3
  IL_005c:  add
  IL_005d:  ldind.u1
  IL_005e:  stloc.s    nextByte
  IL_0060:  ldc.i4     0x80
  IL_0065:  stloc.s    bitmask
  IL_0067:  br.s       IL_00a4
  IL_0069:  ldloc.1
  IL_006a:  ldc.i4.s   48
  IL_006c:  conv.i
  IL_006d:  add
  IL_006e:  ldc.i4     0x10000000
  IL_0073:  stind.i4
  IL_0074:  ldloc.s    nextByte
  IL_0076:  ldloc.s    bitmask
  IL_0078:  and
  IL_0079:  brfalse.s  IL_0088
  IL_007b:  ldloc.0
  IL_007c:  ldc.i4.s   48
  IL_007e:  conv.i
  IL_007f:  add
  IL_0080:  ldc.i4     0x8000000
  IL_0085:  stind.i4
  IL_0086:  br.s       IL_0093
  IL_0088:  ldloc.0
  IL_0089:  ldc.i4.s   52
  IL_008b:  conv.i
  IL_008c:  add
  IL_008d:  ldc.i4     0x8000000
  IL_0092:  stind.i4
  IL_0093:  ldloc.1
  IL_0094:  ldc.i4.s   52
  IL_0096:  conv.i
  IL_0097:  add
  IL_0098:  ldc.i4     0x10000000
  IL_009d:  stind.i4
  IL_009e:  ldloc.s    bitmask
  IL_00a0:  ldc.i4.1
  IL_00a1:  shr
  IL_00a2:  stloc.s    bitmask
  IL_00a4:  ldloc.s    bitmask
  IL_00a6:  brtrue.s   IL_0069
  IL_00a8:  ldloc.3
  IL_00a9:  ldc.i4.1
  IL_00aa:  add
  IL_00ab:  stloc.3
  IL_00ac:  ldloc.3
  IL_00ad:  ldarg.0
  IL_00ae:  blt.s      IL_0059
  IL_00b0:  ldloc.2
  IL_00b1:  ldc.i4.s   48
  IL_00b3:  conv.i
  IL_00b4:  add
  IL_00b5:  ldc.i4.1
  IL_00b6:  stind.i4
  IL_00b7:  ldc.i4.0
  IL_00b8:  ret
} // end of method BitBanger::Bang
And now, for the sake of completeness/sadism, here is that code after being "pasted"/"translated" into what the compiler currently needs (again, this will be much improved in future versions). Again, you should think of this as simply a giant crutch that I need to use in order to get the system to do something. In the real version you will not have to do any of this. This code appears in SimpleNGen.sln in the file testCases/BitBanger.cs
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Kosak.SimpleNGen.compiler;
namespace Kosak.SimpleNGen.testCases {
  public static class BitBanger {
    public static void Doit() {
      //      .method public hidebysig static int32  BitBanger(int32 length,
      //                                                 int32 dummy1,
      //                                                 int32 dummy2,
      //                                                 int32 dummy3,
      //                                                 uint8* buffer) cil managed
      var args=new[] { typeof(int), typeof(int), typeof(int), typeof(int), typeof(byte*) };
      //  .maxstack  2
      //  .locals init ([0] int32* dataPio,
      //           [1] int32* clockPio,
      //           [2] int32* enablePio,
      //           [3] int32 i,
      //           [4] uint8 nextByte,
      //           [5] int32 bitmask)
      var locals=new[] { typeof(int*), typeof(int*), typeof(int*), typeof(int), typeof(byte), typeof(int) };
      var mb=new TinyMethodBuilder(args, locals);
      //  IL_0000:  ldc.i4     0xfffff400
      mb.Emit.Ldc_I4(unchecked((int)0xfffff400));
      //  IL_0005:  conv.u
      mb.Emit.Conv_U();
      //  IL_0006:  stloc.0
      mb.Emit.Stloc(0);
      //  IL_0007:  ldc.i4     0xfffff400
      //  IL_000c:  conv.u
      mb.Emit.Conv_U();
      //  IL_000d:  stloc.1
      mb.Emit.Stloc(1);
      //  IL_000e:  ldc.i4     0xfffff400
      //  IL_0013:  conv.u
      mb.Emit.Conv_U();
      //  IL_0014:  stloc.2
      mb.Emit.Stloc(2);
      //  IL_0015:  ldloc.0
      mb.Emit.Ldloc(0);
      //  IL_0016:  ldc.i4     0x8000000
      mb.Emit.Ldc_I4(0x8000000);
      //  IL_001b:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_001c:  ldloc.0
      mb.Emit.Ldloc(0);
      //  IL_001d:  ldc.i4.s   16
      mb.Emit.Ldc_I4(16);
      //  IL_001f:  conv.i
      mb.Emit.Conv_I();
      //  IL_0020:  add
      mb.Emit.Add();
      //  IL_0021:  ldc.i4     0x8000000
      //  IL_0026:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0027:  ldloc.1
      mb.Emit.Ldloc(1);
      //  IL_0028:  ldc.i4     0x10000000
      mb.Emit.Ldc_I4(0x10000000);
      //  IL_002d:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_002e:  ldloc.1
      mb.Emit.Ldloc(1);
      //  IL_002f:  ldc.i4.s   16
      mb.Emit.Ldc_I4(16);
      //  IL_0031:  conv.i
      mb.Emit.Conv_I();
      //  IL_0032:  add
      mb.Emit.Add();
      //  IL_0033:  ldc.i4     0x10000000
      //  IL_0038:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0039:  ldloc.1
      mb.Emit.Ldloc(1);
      //  IL_003a:  ldc.i4.s   52
      mb.Emit.Ldc_I4(52);
      //  IL_003c:  conv.i
      mb.Emit.Conv_I();
      //  IL_003d:  add
      mb.Emit.Add();
      //  IL_003e:  ldc.i4     0x10000000
      //  IL_0043:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0044:  ldloc.2
      mb.Emit.Ldloc(2);
      //  IL_0045:  ldc.i4.1
      mb.Emit.Ldc_I4(1);
      //  IL_0046:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0047:  ldloc.2
      mb.Emit.Ldloc(2);
      //  IL_0048:  ldc.i4.s   16
      mb.Emit.Ldc_I4(16);
      //  IL_004a:  conv.i
      mb.Emit.Conv_I();
      //  IL_004b:  add
      mb.Emit.Add();
      //  IL_004c:  ldc.i4.1
      mb.Emit.Ldc_I4(1);
      //  IL_004d:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_004e:  ldloc.2
      mb.Emit.Ldloc(2);
      //  IL_004f:  ldc.i4.s   52
      mb.Emit.Ldc_I4(52);
      //  IL_0051:  conv.i
      mb.Emit.Conv_I();
      //  IL_0052:  add
      mb.Emit.Add();
      //  IL_0053:  ldc.i4.1
      mb.Emit.Ldc_I4(1);
      //  IL_0054:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0055:  ldc.i4.0
      mb.Emit.Ldc_I4(0);
      //  IL_0056:  stloc.3
      mb.Emit.Stloc(3);
      //  IL_0057:  br.s       IL_00ac
      mb.Emit.Br("IL_00ac");
      //  IL_0059:  ldarg.s    buffer
      mb.Label("IL_0059").Emit.Ldarg(4);
      //  IL_005b:  ldloc.3
      mb.Emit.Ldloc(3);
      //  IL_005c:  add
      mb.Emit.Add();
      //  IL_005d:  ldind.u1
      mb.Emit.Ldind_U1();
      //  IL_005e:  stloc.s    nextByte
      mb.Emit.Stloc(4);
      //  IL_0060:  ldc.i4     0x80
      mb.Emit.Ldc_I4(0x80);
      //  IL_0065:  stloc.s    bitmask
      mb.Emit.Stloc(5);
      //  IL_0067:  br.s       IL_00a4
      mb.Emit.Br("IL_00a4");
      //  IL_0069:  ldloc.1
      mb.Label("IL_0069").Emit.Ldloc(1);
      //  IL_006a:  ldc.i4.s   48
      mb.Emit.Ldc_I4(48);
      //  IL_006c:  conv.i
      mb.Emit.Conv_I();
      //  IL_006d:  add
      mb.Emit.Add();
      //  IL_006e:  ldc.i4     0x10000000
      //  IL_0073:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0074:  ldloc.s    nextByte
      mb.Emit.Ldloc(4);
      //  IL_0076:  ldloc.s    bitmask
      mb.Emit.Ldloc(5);
      //  IL_0078:  and
      mb.Emit.And();
      //  IL_0079:  brfalse.s  IL_0088
      mb.Emit.Brfalse("IL_0088");
      //  IL_007b:  ldloc.0
      mb.Emit.Ldloc(0);
      //  IL_007c:  ldc.i4.s   48
      mb.Emit.Ldc_I4(48);
      //  IL_007e:  conv.i
      mb.Emit.Conv_I();
      //  IL_007f:  add
      mb.Emit.Add();
      //  IL_0080:  ldc.i4     0x8000000
      //  IL_0085:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0086:  br.s       IL_0093
      mb.Emit.Br("IL_0093");
      //  IL_0088:  ldloc.0
      mb.Label("IL_0088").Emit.Ldloc(0);
      //  IL_0089:  ldc.i4.s   52
      mb.Emit.Ldc_I4(52);
      //  IL_008b:  conv.i
      mb.Emit.Conv_I();
      //  IL_008c:  add
      mb.Emit.Add();
      //  IL_008d:  ldc.i4     0x8000000
      //  IL_0092:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_0093:  ldloc.1
      mb.Label("IL_0093").Emit.Ldloc(1);
      //  IL_0094:  ldc.i4.s   52
      mb.Emit.Ldc_I4(52);
      //  IL_0096:  conv.i
      mb.Emit.Conv_I();
      //  IL_0097:  add
      mb.Emit.Add();
      //  IL_0098:  ldc.i4     0x10000000
      //  IL_009d:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_009e:  ldloc.s    bitmask
      mb.Emit.Ldloc(5);
      //  IL_00a0:  ldc.i4.1
      mb.Emit.Ldc_I4(1);
      //  IL_00a1:  shr
      mb.Emit.Shr();
      //  IL_00a2:  stloc.s    bitmask
      mb.Emit.Stloc(5);
      //  IL_00a4:  ldloc.s    bitmask
      mb.Label("IL_00a4").Emit.Ldloc(5);
      //  IL_00a6:  brtrue.s   IL_0069
      mb.Emit.Brtrue("IL_0069");
      //  IL_00a8:  ldloc.3
      mb.Emit.Ldloc(3);
      //  IL_00a9:  ldc.i4.1
      mb.Emit.Ldc_I4(1);
      //  IL_00aa:  add
      mb.Emit.Add();
      //  IL_00ab:  stloc.3
      mb.Emit.Stloc(3);
      //  IL_00ac:  ldloc.3
      mb.Label("IL_00ac").Emit.Ldloc(3);
      //  IL_00ad:  ldarg.0
      mb.Emit.Ldarg(0);
      //  IL_00ae:  blt.s      IL_0059
      mb.Emit.Blt("IL_0059");
      //  IL_00b0:  ldloc.2
      mb.Emit.Ldloc(2);
      //  IL_00b1:  ldc.i4.s   48
      mb.Emit.Ldc_I4(48);
      //  IL_00b3:  conv.i
      mb.Emit.Conv_I();
      //  IL_00b4:  add
      mb.Emit.Add();
      //  IL_00b5:  ldc.i4.1
      mb.Emit.Ldc_I4(1);
      //  IL_00b6:  stind.i4
      mb.Emit.Stind_I4();
      //  IL_00b7:  ldc.i4.0
      mb.Emit.Ldc_I4(0);
      //  IL_00b8:  ret
      mb.Emit.Ret();
      TinyMethodCompiler.Compile(mb.Finish());
If you've read this far without wanting to end your own life, then I am very impressed and wish to reward you with the output of the compiler (which you will also see if you run the attached SimpleNgen.sln on your computer):
*** Final Output ***
0000: E92D07F0 enter     STMDB SP!,{R4-R10}                                 1110|100|1|0|0|1|0|1101|0000011111110000
0004: E1A07000 PRO0      MOV R7,R0                                          1110|00|0|1101|0|0000|0111|00000|00|0|0000
0008: E59D501C PRO4      LDR R5,[SP,#0x1C]                                  1110|01|0|1|1|0|0|1|1101|0101|000000011100
000C: E59F9080 L0.1      LDR R9,[PC,const(FFFFF400)]                        1110|01|0|1|1|0|0|1|1111|1001|000010000000
0010: E3A03302 L10.1     MOV R3,#0x8000000                                  1110|00|1|1101|0|0000|0011|0011|00000010
0014: E5893000 L11       STR R3,[R9,#0x0]                                   1110|01|0|1|1|0|0|0|1001|0011|000000000000
0018: E5893010 L17       STR R3,[R9,#0x10]                                  1110|01|0|1|1|0|0|0|1001|0011|000000010000
001C: E3A04201 L19.1     MOV R4,#0x10000000                                 1110|00|1|1101|0|0000|0100|0010|00000001
0020: E5894000 L20       STR R4,[R9,#0x0]                                   1110|01|0|1|1|0|0|0|1001|0100|000000000000
0024: E5894010 L26       STR R4,[R9,#0x10]                                  1110|01|0|1|1|0|0|0|1001|0100|000000010000
0028: E5894034 L32       STR R4,[R9,#0x34]                                  1110|01|0|1|1|0|0|0|1001|0100|000000110100
002C: E3A08001 L34.1     MOV R8,#0x1                                        1110|00|1|1101|0|0000|1000|0000|00000001
0030: E5898000 L35       STR R8,[R9,#0x0]                                   1110|01|0|1|1|0|0|0|1001|1000|000000000000
0034: E5898010 L41       STR R8,[R9,#0x10]                                  1110|01|0|1|1|0|0|0|1001|1000|000000010000
0038: E5898034 L47       STR R8,[R9,#0x34]                                  1110|01|0|1|1|0|0|0|1001|1000|000000110100
003C: E3A0A000 L48.1     MOV R10,#0x0                                       1110|00|1|1101|0|0000|1010|0000|00000000
0040: E3A06000 L49       MOV R6,#0x0                                        1110|00|1|1101|0|0000|0110|0000|00000000
0044: EA00000C L50       B L94                                              1110|101|0|000000000000000000001100
0048: E7D51006 L53       LDRB R1,[R5,R6]                                    1110|01|1|1|1|1|0|1|0101|0001|00000|00|0|0110
004C: E3A02080 L56       MOV R2,#0x80                                       1110|00|1|1101|0|0000|0010|0000|10000000
0050: EA000006 L57       B L88.2                                            1110|101|0|000000000000000000000110
0054: E5894030 L62       STR R4,[R9,#0x30]                                  1110|01|0|1|1|0|0|0|1001|0100|000000110000
0058: E0010002 L65       AND R0,R1,R2                                       1110|00|0|0000|0|0001|0000|00000|00|0|0010
005C: E3500000 L66.2     CMPS R0,#0x0                                       1110|00|1|1010|1|0000|0000|0000|00000000
0060: 15893030 L72       STRNE R3,[R9,#0x30]                                0001|01|0|1|1|0|0|0|1001|0011|000000110000
0064: 05893034 L78       STREQ R3,[R9,#0x34]                                0000|01|0|1|1|0|0|0|1001|0011|000000110100
0068: E5894034 L83       STR R4,[R9,#0x34]                                  1110|01|0|1|1|0|0|0|1001|0100|000000110100
006C: E1A02852 L86       MOV R2,R2 ASR R8                                   1110|00|0|1101|0|0000|0010|1000|0|10|1|0010
0070: E3520000 L88.2     CMPS R2,#0x0                                       1110|00|1|1010|1|0010|0000|0000|00000000
0074: 1AFFFFF6 L88.2.1   BNE L62                                            0001|101|0|111111111111111111110110
0078: E2866001 L91       ADD R6,R6,#0x1                                     1110|00|1|0100|0|0110|0110|0000|00000001
007C: E1560007 L94       CMPS R6,R7                                         1110|00|0|1010|1|0110|0000|00000|00|0|0111
0080: BAFFFFF0 L94.1     BLT L53                                            1011|101|0|111111111111111111110000
0084: E5898030 L100      STR R8,[R9,#0x30]                                  1110|01|0|1|1|0|0|0|1001|1000|000000110000
0088: E1A0000A L102      MOV R0,R10                                         1110|00|0|1101|0|0000|0000|00000|00|0|1010
008C: E8BD07F0 leave     LDMUA SP!,{R4-R10}                                 1110|100|0|1|0|1|1|1101|0000011111110000
0090: E12FFF1E leave.1   BX LR                                              1110|000100101111111111110001|1110
0094: FFFFF400 const(FFFFF400)WORD 0xFFFFF400                               11111111111111111111010000000000
*** C# Representation ***
var code=new uint[] {
  0xE92D07F0,0xE1A07000,0xE59D501C,0xE59F9080,0xE3A03302,0xE5893000,0xE5893010,0xE3A04201,
  0xE5894000,0xE5894010,0xE5894034,0xE3A08001,0xE5898000,0xE5898010,0xE5898034,0xE3A0A000,
  0xE3A06000,0xEA00000C,0xE7D51006,0xE3A02080,0xEA000006,0xE5894030,0xE0010002,0xE3500000,
  0x15893030,0x05893034,0xE5894034,0xE1A02852,0xE3520000,0x1AFFFFF6,0xE2866001,0xE1560007,
  0xBAFFFFF0,0xE5898030,0xE1A0000A,0xE8BD07F0,0xE12FFF1E,0xFFFFF400
It is just this little array at the end (the thing starting with "var code=new uint[]...") which the SimpleNgen compiler will eventually paste into BitBanger.Designer.cs. Until then, we will paste it manually.
Fans of assembly language will notice that I am generating ARM opcodes rather than Thumb as I did in Fluent. The reason for this is that (a) I wanted to get some experience generating a different set of opcodes, and (b ) I wanted easy access to more registers (this code uses 11 registers though if you read closely you can find a couple of places where my "optimizer" went a little crazy).
The bulk of the work in SimpleNgen is due to these optimizations. It's actually relatively easy to do a naive mapping from MSIL opcodes to ARM, but the resultant code would be a lot slower. My own optimizations are kind of hit and miss. In some cases I'm doing something awesome (notice I was able to use the conditional prefixes to do a branch-free if-then-else at lines 0060 and 0064) but in other cases I'm doing something wasteful (like the compare against zero in line 005C.
Anyway, back to the plot. [Once the compiler has written the code into BitBanger.Designer.cs] or you've hand-pasted it there, the invocation looks like this (this is in NGenSandbox.sln in Program.cs)
using Kosak.SimpleInterop;
  public class Program {
    public static void Main() {
      var data=new [] {(byte)'H', (byte)'e', (byte)'l', (byte)'l', (byte)'o'};
      NativeInterface.Execute(BitBanger.Bang_compiled, data.Length, 0, 0, 0, data, null, null, null);
The arguments for this Execute method are, first, the reference to the compiled code, and then the four ints and four arrays as I mentioned above (this is why the length appears in the first int position and the data appears in the first array position). If it helps, this is the prototype to NativeInterface.Execute:
    [MethodImpl(MethodImplOptions.InternalCall)]
    public static extern int Execute(uint[] code,
      int i0, int i1, int i2, int i3,
      Array a0, Array a1, Array a2, Array a3);
(The entry point compiled into the firmware turns the four array references into four pointers, though as I mentioned there is no type checking)
Thank you for reading and I hope you'll let me know what you think! I'll attach all the referenced files to my next post.
#2 Corey Kosak
Corey Kosak
  • 276 posts
Posted 03 April 2011 - 05:46 AM
Please see the attached for the files I referred to in my previous message. Hey Chris, can I get more quota :P
#3 Mario Vernari
Posted 03 April 2011 - 07:09 AM
Corey, your work is somewhat wonderful, but I'd rather ask a question. Instead of making all these tricks, that *anyway* add an overhead to the real code (even smaller as other solutions)... ...why don't we pre-compile the IL directly to ARM opcodes? I asked myself this question often, but I really cannot able to find a question. The only section would be (perhaps) involved is the reflection, because an hard-compiled code wouldn't allow to reflect itself...or not? I admit I'm not an expertise about low-level interop, but why don't do that? Cheers and thanks again for sharing. PS: since I'm fighting vs the N+ compilation, I imagine that would be easier to use your framework instead of learning C/C++ and compile the "big mess".
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 03 April 2011 - 09:45 AM
Gee Corey, if Netduino was a Nobel dicipline you got my vote! With seamless IDE integration in place, this will be a very conveniant and effective way of having performance critical sections of code within the otherwise fully managed environment. Congrats on a really impressive piece of work!
#5 Corey Kosak
Corey Kosak
  • 276 posts
Posted 03 April 2011 - 02:56 PM
I assume you mean a system where we are able to compile our whole program down to ARM and do away with our .NET interpreter altogether.
In principle there's no reason this can't be done other than the need to expend the required effort. For SimpleNGen I deliberately picked the lowest-hanging fruit I could find. Doing a complete job for the whole micro framework is probably, I dunno, 100x or 500x as much work.
By the way, metadata is a non-issue. The compiled code could carry around associated metadata in much the same way the MSIL code does now.
Tangent: for SimpleNgen, I probably could have saved myself a lot of work by letting GCC do the code generation. That is, we could narrow SimpleNgen's job to be that of translation from (a subset of) MSIL to C source, and then we would let GCC translate from C to ARM (or Thumb, or anything else). Perhaps I ought to have done it that way, but I wanted to play around with writing a compiler.
Like many others on this forum, I like to redefine my problems until they become "interesting" (i.e. too hard to solve :unsure: )
#6 Corey Kosak
Corey Kosak
  • 276 posts
Posted 03 April 2011 - 02:57 PM
Thank you!
#7 Mario Vernari
Posted 03 April 2011 - 03:29 PM
I mean what you say, Corey. We both are playing with these "toys" just because we feel young and because we like challenges also. I'm not 100% a software-man: I born/grew as electronic (engineer), turned to CS. I guess the feeling, but I have still an eye toward the "real" hardware. You know, by digging into low-level software is much as digging into low-level hardware. Any way I can't think that MS invested $$ on a half-way platform. Maybe they're going to see what will be the potential market of this kind of product, but I find very leaky in some sections... At the moment in my head there are many question point around NetMF (I'd say on the Compact too). What I'm seeing is a strong ad about iPhone-like graphics, effects, gadgets, super-mega services...and "excuse me, Mr. Gates, how can I write my own driver?". Bill will answer me: "Ops!...we are not still ready with a similar product. In the mean time you could arrange in some way, try ask to some friend." That is not serious at all. OK: let's change. Back to your SimpleNGen: how could you approach a driver that collect port data at a specific interval? Don't fall into details, just about an interrupt (or whatever else) being able to call a NGen code granting precise timing. Cheers
#8 Roceh
Roceh
  • 11 posts
Posted 03 April 2011 - 04:21 PM
There was a partial implementation of modding gcc to compile cil to native - the frontend part of this project:
http://gcc.gnu.org/projects/cli.html
#9 Chris Walker
Posted 03 April 2011 - 07:30 PM
Corey, one word: Wow.
#10 Corey Kosak
Corey Kosak
  • 276 posts
Posted 03 April 2011 - 08:44 PM
I don't really know, but I assumed that they stopped caring after SPOT/SideShow, until visionaries like Chris Walker showed them what cool things can be done with their system.
There are only a couple of issues I'm aware of here, and I already solved them both in Fluent:
  • how to get the array holding the interrupt handler code to stay pinned at a specific address so it can be called at interrupt time
  • how to get any associated data buffers to also stay pinned
This library generates code that is 100% compliant with the ARM calling convention (as did Fluent), so there is no problem there. In Fluent I already had demonstrated asynchronous routines that were called as part of the funky firmware scheduler (the so-called HAL_COMPLETION). These are not interrupts per se but do demonstrate that I am able to support asynchronous code.
The main blocker to supporting hardware interrupts is that I don't know how to do it. I haven't really gone looking for code to copy yet. If someone can point me to working examples (in C++) and/or documentation for how to
  • Set up an interrupt (either a timer, or edge interrupt on a pin)
  • post an event back to C#
...that would save me a lot of time
Wow, that's super-interesting! While it was sort of fun to think about, it would be great to hand off all this code generation to gcc, who will do a much better job than I ever could.
Wow.
#11 AlfredBr
AlfredBr
  • 138 posts
  • LocationConnecticut, USA
Posted 04 April 2011 - 12:52 AM
Corey, this is all kinds of awesome!
And the real beauty (to me) is the familiarity of the pattern. I recall doing something similar (by hand) 30 years ago on the Commodore 64. First I'd write the routine in BASIC, then rewrite it (by hand) in 6502 assembler (using Jim Butterfield's "SuperMonitor+"), convert the hex of the assembly code to base10, then (back in BASIC) POKE those values back into RAM, and then JMP to the appropriate address. And then hope you don't hang or reset the machine causing you to start all over!
Again, this sounds awesome and if you make this into a product, I'd certainly buy it.
P.S. When this takes off (and I know it will), those byte arrays look awfully shareable....
#12 Corey Kosak
Corey Kosak
  • 276 posts
Posted 04 April 2011 - 01:23 AM
Thanks! But you look too young to have worked with the C64! :P
Yeah if you're willing to flash the firmware I posted, you should be able to run just the NGenSandbox on your Netduino right now.
#13 Dan Morphis
Dan Morphis
  • 188 posts
Posted 04 April 2011 - 06:34 PM
Corey,
Great work! You've saved me from doing something like this myself :-)
Have you looked at the post-compiler stuff that MonoTouch uses? I haven't looked to see if they are keeping that closed or not. My approach was going to be build on/use MonoTouch post-compiler. I don't know how feasible it is or not.
I haven't had any time to prototype anything. More just ideas I had floating around in my head. But one of the big advantages of using their post-compiler is it understands all the .NET types (even custom types), and doesn't rely on partial classes.
Please don't take this a throwing stones, more like throwing ideas out there!
-dan
#14 Corey Kosak
Corey Kosak
  • 276 posts
Posted 04 April 2011 - 09:53 PM
I don't know anything about MonoTouch, but I will check it out! By the way, I don't have any particular reliance on partial classes; the output of my "compiler" could be stored in a number of ways, including a separate class or an embedded resource.
#15 SirPoonga
SirPoonga
  • 96 posts
Posted 05 April 2011 - 04:15 AM
Very cool, I will be trying this out soon. I was waiting for this for my LED project. I need the latest netduino plus firmware so re-flashing didn't work out well.
#16 Dan Morphis
Dan Morphis
  • 188 posts
Posted 07 April 2011 - 01:13 AM
Corey,
I messaged Miguel de Icaza (of Mono fame) today and asked him what the licensing was for the MonoTouch IL -> ARM code gen engine. He said its LGPL, or commercial. But that it would be simpler to build your own rather than trying to reuse theirs, as the MonoTouch one is to tightly integrated with the Mono VM.
I don't know what your using to pick apart the assemblies, but have you looked at Cecil?
#17 Corey Kosak
Corey Kosak
  • 276 posts
Posted 07 April 2011 - 02:38 AM
Cecil looks promising. Thanks for the info! I haven't decided what to do about picking apart the assemblies, but I will now reveal my secret shame: for the first version I was planning to just invoke ildasm and parse its output. I realize this is a funky approach (not really a good design for the long run) but for now I was going to do it because it is quick and dirty and has the advantage that I don't have to spend time getting intimate with someone else's library.
#18 Dan Morphis
Dan Morphis
  • 188 posts
Posted 07 April 2011 - 10:28 PM
Admitting you have a problem is the first step :-) I've used Cecil before and didn't find the API to be to difficult. But then again, I was just picking apart methods looking for calls to specific other methods, not picking things apart and translating them to ARM op codes.
Do you have a google code, or get site hosting the code so I can check it out?
#19 Corey Kosak
Corey Kosak
  • 276 posts
Posted 07 April 2011 - 11:49 PM
The code is attached to posting #2 on this topic so you can just get it there. I would prefer to keep a git repository somewhere public, but I don't know what the hip kids use. Is it github? I'd be happy to do whatever you guys recommend.
#20 JonnyBoats
JonnyBoats
  • 155 posts
  • LocationPhillips, ME
Posted 08 April 2011 - 12:47 AM
I like CodePlex for hosting open source projects: "CodePlex is Microsoft's open source project hosting web site."
Incidentally the .NET Micro Framework is on CodePlex.
