Netduino servo class
56 replies to this topic
#41 Chris Seto
Chris Seto
  • 405 posts
Posted 10 April 2012 - 04:30 AM
Wow, a year later at least and people are still getting a bunch of use out of this thing. :rolleyes:
#42 DForce
DForce
  • 3 posts
Posted 24 June 2012 - 10:02 AM
So am I :) I was going to make my own, but then I was searching for the PWM specs I just saw your post for controlling servo's. Thanks! Going to make much use of it!
Btw. Might it be handy to make some sort of reference for servo's which maximum setRange to use?
I've got a Robbe FS100 here and the settings for this are 250 for left and 2350 for right. It might vary sometimes but this could be a good indicator?
#43 DForce
DForce
  • 3 posts
Posted 24 June 2012 - 10:14 AM
I've tested another Servo the :"Multiplex MS-X6" and the setRange i'm using is (550,2300) As for a question that came up while testing servo's, the value for the left rotation is actually for the right. Then I've got to set the inverted boolean, while actually everything is connected the normal way. Am I the only one with this problem? Greetzz, Matthijs
#44 Cole Prince
Cole Prince
  • 8 posts
  • LocationJonesboro, AR, USA
Posted 27 June 2012 - 03:48 AM
Hopefully this thread is not completely dead. I have tried to use the class from both Chris Seto and the one that OZ modified and I am having the same issue on both. I have created the Servo_API.dll and I have added it is a reference to my project. I am receiving no errors from the code (all references to 'servo' show to be working. However, when I try to debug the application it gives me a error with a description of "0xfd000000". When I click on the error a popup appears that says "This document cannot be opened. It has been renamed, deleted, or moved." If I remove the Servo_API references (and all comment out my code of course) I have no issues whatsoever in loading my project to my Netduino Plus. If I add it back, the problem comes back. I am sure that there is something obvious that I am overlooking. I appreciate any help that you can give.
#45 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 27 June 2012 - 06:18 AM
Try removing the underscore in the namespace. Class Libraries have way stricter naming rules.
#46 Pak0loko
Pak0loko
Posted 26 September 2012 - 07:05 PM
Hi Guys.
I´m new on this kind of thigs like programing using netduino and even on the use of c# :S.
I´ve been trying a lot to make this code works on firmware 4.2, you know the PWM changes and some other things.
Can anyone of you please help me on this?
I´ll appreciate it a lot.
Thanks in Advance.
This is a class I use on my other NETMF hardware to run my RC car based robot. It took very little effort to port to the Netduino, hopefully someone find it useful :)
 * Servo NETMF Driver
 *	Coded by Chris Seto August 2010
 *	<chris@chrisseto.com>
 * Use this code for whatveer you want. Modify it, redistribute it, I don't care.
 * I do ask that you please keep this header intact, however.
 * If you modfy the driver, please include your contribution below:
 * Chris Seto: Inital release (1.0)
 * Chris Seto: Netduino port (1.0 -> Netduino branch)
 * Chris Seto: bool pin state fix (1.1 -> Netduino branch)
namespace Servo_API
	public class Servo : IDisposable
		/// <summary>
		/// PWM handle
		/// </summary>
		private PWM servo;
		/// <summary>
		/// Timings range
		/// </summary>
		private int[] range = new int[2];
		/// <summary>
		/// Set servo inversion
		/// </summary>
		public bool inverted = false;
		/// <summary>
		/// Create the PWM pin, set it low and configure timings
		/// </summary>
		/// <param name="pin"></param>
		public Servo(Cpu.Pin pin)
			// Init the PWM pin
			servo = new PWM((Cpu.Pin)pin);
			servo.SetDutyCycle(0);
			// Typical settings
			range[0] = 1000;
			range[1] = 2000;
		public void Dispose()
			disengage();
			servo.Dispose();
		/// <summary>
		/// Allow the user to set cutom timings
		/// </summary>
		/// <param name="fullLeft"></param>
		/// <param name="fullRight"></param>
		public void setRange(int fullLeft, int fullRight)
			range[1] = fullLeft;
			range[0] = fullRight;
		/// <summary>
		/// Disengage the servo.
		/// The servo motor will stop trying to maintain an angle
		/// </summary>
		public void disengage()
			// See what the Netduino team say about this...
		/// <summary>
		/// Set the servo degree
		/// </summary>
		public double Degree
			set
				/// Range checks
				if (value > 180)
					value = 180;
				if (value < 0)
					value = 0;
				// Are we inverted?
				if (inverted)
					value = 180 - value;
				// Set the pulse
				servo.SetPulse(20000, (uint)map((long)value, 0, 180, range[0], range[1]));
		/// <summary>
		/// Used internally to map a value of one scale to another
		/// </summary>
		/// <param name="x"></param>
		/// <param name="in_min"></param>
		/// <param name="in_max"></param>
		/// <param name="out_min"></param>
		/// <param name="out_max"></param>
		/// <returns></returns>
		private long map(long x, long in_min, long in_max, long out_min, long out_max)
			return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Example code:
using Servo_API;
namespace NetduinoServoDemo
			Servo servo = new Servo(Pins.GPIO_PIN_D9);
				for (int i = 0; i <= 180; i++)
					servo.Degree = i;
					Thread.Sleep(10);
				for (int i = 180; i >= 0; i--)
					servo.Degree = i;
					Thread.Sleep(10);
Pako Gomez
"Live and Let Live"
#47 BrandonW6
BrandonW6
  • 8 posts
Posted 30 September 2012 - 02:00 AM
I updated the sample for the new PWM classes in 4.2.0.1
Changes include PWM constructor code with new parameters and code to set angle.
namespace Servo_API
        /// <summary>
        /// PWM handle
        /// </summary>
        private PWM servo;
        /// <summary>
        /// Timings range
        /// </summary>
        /// <summary>
        /// </summary>
        /// <summary>
        /// Create the PWM Channel, set it low and configure timings
        /// </summary>
        public Servo(Cpu.PWMChannel channelPin)
            // Init the PWM pin
            servo = new PWM((Cpu.PWMChannel)channelPin, 20000, 1500,PWM.ScaleFactor.Microseconds, false);
            servo.DutyCycle = 0;
            // Typical settings
            range[0] = 1000;
            range[1] = 2000;
            disengage();
            servo.Dispose();
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
            servo.DutyCycle = 0; //SetDutyCycle(0);
        /// <summary>
        /// </summary>
            set
                /// Range checks
                if (value > 180)
                    value = 180;
                if (value < 0)
                    value = 0;
                // Are we inverted?
                if (inverted)
                // Set the pulse
                //servo.SetPulse(20000, (uint)map((long)value, 0, 180, range[0], range[1]));
                servo.Duration = (uint)map((long)value, 0, 180, range[0], range[1]);
        /// <summary>
        /// </summary>
using Servo_API;
namespace NetduinoApplication5
            Servo servo = new Servo(PWMChannels.PWM_PIN_D9);
            // Change 'While' to 'For' to limit how many time it repeats
            for (int j = 0; j < 3; j++)
                    servo.Degree = i;
                    Thread.Sleep(10);
                    servo.Degree = i;
                    Thread.Sleep(10);
#48 rchelicopter
rchelicopter
  • 18 posts
  • LocationSan Diego, Ca
Posted 27 December 2012 - 03:43 PM
Hello,
I've been playing around trying to get the PWM and analog Input stuff working on .netmf 4.2 and have been running into some problems.  So I thought I would post this to help someone else possibly, keep in mind I'm pretty new to this stuff.
I wasn't able to get any PWM output until I added servo.Start(); at the end of public Servo(Cpu.PWMChannel channelPin). Like Below
public Servo(Cpu.PWMChannel channelPin) { // Init the PWM pin servo = new PWM((Cpu.PWMChannel)channelPin, 20000, 1500,PWM.ScaleFactor.Microseconds, false); servo.DutyCycle = 0;
servo.Start();
// Typical settings range[0] = 1000; range[1] = 2000;
P.S.  Thank you Chris Seto for originally writing this, it has been a great deal of help to me.
#49 lancewmccarthy
lancewmccarthy
  • 9 posts
  • LocationBoston, MA USA
Posted 06 April 2013 - 01:14 PM
I'm using the NP2 and MF 4.3, have you updated the project for 4.3? I'm having problems trying to get it work. The servo is going to operate a small hatch door, I simply want to set an "open" state and a "closed" state.
Update: I didn't see the end of this thread until I posted this reply. RCHelicopter's tip fixed it.
Thanks for sharing guys!
Lance McCarthy
Microsoft MVP (Windows Platform Development)
#50 gingemonster
gingemonster
Posted 29 June 2013 - 10:04 AM
I tried the latest code for this and as far as I can see the map function is wrong? It was giving me values not in my output range? Am I imagining this or has something changed in the most updated code?
#51 john51
john51
Posted 14 July 2014 - 12:07 AM
Hi Everyone,
  Im new to programming the netduino, but have learned a lot by pasting code and getting a few projects to work, I just got done with the Servo knob and sweep, and had very little problem getting it to work, the sweep.  But I noticed that the movement of the servo was only 90 degrees instead of the full 180+ that I should be getting with the servo.  Im using the Futaba s3003 servo, but after trying a few things with the code I still cant increase the movement range.  What part of the code determines the range of movement, and what should I do to increase it?  I will be reading up on some articles of servos while I wait for a reply. Thanks in advance for any help.
#52 perpetualKid
perpetualKid
  • 20 posts
Posted 14 July 2014 - 09:30 PM
in that code above it should be these lines defining the servo range
// Typical settings
range[0] = 1000;
range[1] = 2000;
Typically a 1500ns pulse defines the midpoint, and you may try some broader range to turn your servo the full 180 degree. I'm sure there is some spec available where you could read up the lower and upper boundaries, else just try in some steps like 950 and 2050, 900 and 2100 etc to find the full range. Some servos go as braod as 500 for the low bound (range[0]) up to 2500 for the upper bound (range[1]).
#53 john51
john51
Posted 15 July 2014 - 03:17 AM
Thanks for the info everyone, glad to have this group as a resource for problems.
#54 TareqGamal
TareqGamal
  • 19 posts
Posted 14 November 2015 - 04:52 PM
it did not work for me due Memory problem
May this program not fit with my Device ?
I have :
NetDuino3 wifi
Windows 7
VS 2013
also at compile time :
It can not make object from servo :
I Added the code as it is and referances okay :
using Servo_API;
#55 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 14 November 2015 - 08:43 PM
Hi Tareq
I think you may have go a version of the code from earlier in the thread which targets an older version of .NetMF
Below is a version of the code with the modifications suggested in the thread.
Fired up a N3 with a servo and it appears to work as expected.
@KiwiBryn
blog.devmobile.co.nz
namespace Servo_API
      /// <summary>
      /// PWM handle
      /// </summary>
      private PWM servo;
      /// <summary>
      /// Timings range
      /// </summary>
      /// <summary>
      /// </summary>
      /// <summary>
      /// </summary>
         // Init the PWM pin
         servo = new PWM((Cpu.PWMChannel)channelPin, 20000, 1500, PWM.ScaleFactor.Microseconds, false);
         // Typical settings
         range[0] = 1000;
         range[1] = 2000;
         servo.Start();
         disengage();
         servo.Dispose();
      /// <summary>
      /// </summary>
      /// <summary>
      /// </summary>
      /// <summary>
      /// </summary>
         set
            /// Range checks
            if (value > 180)
               value = 180;
            if (value < 0)
               value = 0;
            // Are we inverted?
            if (inverted)
            // Set the pulse
      /// <summary>
      /// </summary>
#56 TareqGamal
TareqGamal
  • 19 posts
Posted 15 November 2015 - 03:45 PM
Great thank you for care ,
I tried your code it gives me error in the following lines :
            // Init the PWM pin
            servo.DutyCycle = 0;  //this line
            // Typical settings
            range[0] = 1000;
            range[1] = 2000;
            servo.Start(); //this line also
 Also this line :
error :
Error 1 'SecretLabs.NETMF.Hardware.PWM' does not contain a definition for .....
also the Main class have this error in this line:
#57 KiwiDev
KiwiDev
  • 100 posts
Posted 16 November 2015 - 04:06 AM
Hi Tareq,
Issue 1 sounds like a .NetMF device and/or SDK versioning problem.  For a 4.3 project the PWM reference should be
Microsoft.SPOT.Hardware.PWM
not
If changing the references doesn't help, could you please check the following
1) What template did you use to generate your application (Universal vs. Legacy...)
2) What in NetMF version is selected in the Visual Studio in the project properties
3) Do all the references for the project match (3) as not all references get update when you change the project properties
4) The device info using the NetMF deploy tool using \Plug-in\Debug\Show device info
5) what .NetMF & Netduino SDKs do you have installed.
If sorting Issue 1 doesn't fix issue 2 then do you have the using statement below
using Servo_API;
Regards
@KiwiBryn
