Disable plus network
6 replies to this topic
#1 Stephen_P
Stephen_P
  • 7 posts
Posted 18 March 2011 - 09:14 PM
Hello I'm struggling quite a bit getting the network chip to work reliably on the netduino plus, something I'm keen to try is either disabling and re-enabling it or resetting it. Are there any methods that will let me do that? Thanks Stephen
Posted 18 March 2011 - 09:29 PM
Hi Stephen, If you erase your Netduino Plus and reflash it with the "regular" Netduino firmware, it'll disable the networking and SD card. If you do this, be sure to flash both the TinyBooter bootloader and the .NET MF runtime (TinyCLR). Chris
#3 Stephen_P
Stephen_P
  • 7 posts
Posted 19 March 2011 - 10:51 AM
Hi Stephen,
Hello Chris
Thank you for your quick reply. What I was thinking of really was effectively re-setting the network chip via software. My Socket.Connect command seems to hang my netduino plus quite frequently. I've tried various different work rounds and the one that seems to work best, so far, is to connect when I get a NetworkChange_NetworkAvailabilityChanged event which currently I can only generate by plugging and un-plugging the network connector. I was thinking of booting up with network off, switch it on, get the event then connect.
Regards
Stephen
#4 Joschua
Joschua
  • 7 posts
Posted 23 March 2011 - 02:23 PM
Hi Stephen,
Hi Chris
After a reflash with the "regular" netduino FW, I try to use the sd card with the
StorageDevice.MountSD("SD", Microsoft.SPOT.Hardware.SPI.SPI_module.SPI2, (Cpu.Pin)49);
Unfortunately this wouldn't work.
Have you any idea to use the built in SD card ?
Regards
J.
#5 Chris Walker
Posted 23 March 2011 - 02:56 PM
Hi Joschua, If you erase your Netduino Plus and reflash it with the "regular" Netduino firmware, it'll disable the networking and SD card. The upcoming v4.1.1 beta will let you use the SD card on your Netduino Plus, but for now you'll need to use the Netduino Plus firmware instead. Chris
#6 Joschua
Joschua
  • 7 posts
Posted 23 March 2011 - 04:03 PM
Hi Joschua,
Hi Chris
Thanks for your answer. I flased the NetduinoPlus with the Netduino v4.1.1.0 a7 FW. So I have to wait for the a8 version ?
Regards
J.
#7 KodeDaemon
KodeDaemon
  • 63 posts
Posted 27 March 2011 - 06:37 PM
I'm not sure if you noticed yet, but 4.1.1 Beta 1 was just released which will allow you to access the SD card using the Netduino firmware.
Hi Chris
Regards
J.
