Spi prblems with vl1053 (mp3 decoder) - SOLVED
Posted 28 February 2011 - 02:48 PM
Posted 28 February 2011 - 03:30 PM
Posted 28 February 2011 - 03:41 PM
Posted 28 February 2011 - 09:33 PM
Worked like a charm!Hi hanzibal,
Have you upgraded your Netduino Mini to the v4.1.0.6 RC2 or v4.1.1 a7 firmware? There are a number of SPI bugfixes there.
Infact, immediately after rebooting from reprogramming the device, an annoyingly loud sine wave came from my earphones. This was somewhat of a surprise since I (as suspected) had configured the spi port the wrong way around in terms of idle clock state and sampling edge.
Anyway, I changed the spi config (low idle clock and rising edge) and my vl1053b now passes the sine test. SPI now seems totally reliable.
Many thanks to you Chris!
Btw, I noticed that I was the first to download then TTL version of v4.1.0.6 RC2, could that really be true?
Posted 01 March 2011 - 02:08 AM
Could be. RC2 is more or less identical to RC1 (just "updated" to match the Netduino firmware).
Posted 01 March 2011 - 03:17 AM
Posted 01 March 2011 - 04:42 AM
Now my mini plays mp3, no sd yet so Im just looping a tiny 8 kHz file but it works. The vl1053 is a small wonder in it self. Almost pulled an all-nighter again, its too hard to stop when you're having this much fun :-)
That's awesome.
Posted 09 March 2011 - 12:06 AM
Thanks, I added an sd card reader today sharing the spi bus with the vs1053. After updating firmware, it kind of works, but sound is pretty chopped up, at least when playing 192 kbps mp3 files. Problems could be related to sharing the bus, bad programming on my behalf or simply insufficient speed causing buffer underflow.That's awesome.
When talking to the vs1053, I run the spi bus at about 10 MHz using manual cs control not involving pin 13.
What is the spi clock speed used when reading the sd card using the new built in sd card functions, i.e. after card detection?
Posted 15 March 2011 - 12:41 AM
Posted 19 September 2011 - 11:12 PM
All problems solved, re-wrote chip select functions using built in instead of manual control. Now, music flows and life is good
Thanks for all the help!
Hanzibal,
I got the MP3 shield with the SD card. I am trying get the audio to play with the VS1053. I cannot seem to get audio to output. What is you VS1053 setup (MODE, CLOCK, etc...)
I am able to open a file and stream the data via SPI but the audio is not coming out. I just ordered another MP3 shield (just in case I have a bad one).
Please help. Thank you.
Richard
Posted 14 December 2011 - 01:29 PM
Sorry for taking so long to reply - are you still interested in the setup code?What is you VS1053 setup (MODE, CLOCK, etc...)
Posted 15 December 2011 - 04:08 AM
I'd love to get this code if possible.
Posted 15 December 2011 - 12:33 PM
Below is a class that implements initialization of the vs1053b, good luck with it.I'd love to get this code if possible.
using System; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoMini; using System.IO; class vs1053b { private SPI.Configuration spi_sci; private SPI.Configuration spi_sdi; private SPI spip; private InputPort dreq; private OutputPort reset; private byte[] wr_buff = { 0, 0, 0, 0 }; private byte[] rd_buff = { 0, 0 }; public vs1053b(bool allowTests) { reset = new OutputPort(Pins.GPIO_PIN_7, true); // vs1053 reset pin dreq = new InputPort(Pins.GPIO_PIN_5, false, Port.ResistorMode.Disabled); // vs1053 dreq pin // serial interface for commands spi_sci = new SPI.Configuration(Pins.GPIO_PIN_8, // xcs on vs1053 (command chip select) false, // cs active high/low 0, // CS Setup time 0, // CS Hold time false, // Clock idle high/low true, // Data is sampled on rising/falling edge of clock 1000, // Clock rate in kHz SPI_Devices.SPI1); /// serial interface for music data (to decoder) spi_sdi = new SPI.Configuration(Pins.GPIO_PIN_6, // xdcs (bsync) on vs1053 (data chip select) false, // cs active high/low 0, // CS Setup time 0, // CS Hold time false, // Clock idle high/low true, // Data is sampled on rising/falling edge of clock 1000, // Clock rate in kHz SPI_Devices.SPI1); // start with sci spip = new SPI(spi_sci); Reset(); // mute WriteRegister(0x0B, 0xffff); // analogue drivers off (hw mute) Thread.Sleep(1); // write to SCI_MODE register @ 0x00 to set SM_SDINEW|SM_LAYER12 WriteRegister(0x00, 0x0802); Thread.Sleep(1); // use the vs1053 PLL clock multiplier WriteRegister(3, 0x8800); // 3.5 x XTALI (12,288 MHz) ~ 43 MHz and max 1 extra multiplier Thread.Sleep(100); AwaitDREQ(); // we can now increase sdi speed var c = spi_sdi; spi_sdi = new SPI.Configuration(c.ChipSelect_Port, c.BusyPin_ActiveState, c.ChipSelect_SetupTime, c.ChipSelect_HoldTime, c.Clock_IdleState, c.Clock_Edge, 5000, c.SPI_mod); // 2 bytes of zero as recommended by VLSI WriteData(0, 0); // turn off bass and treble enhancers WriteRegister(0x2, 0x0000); } private void SelectCommand() { if (spip.Config != spi_sci) spip.Config = spi_sci; } private void SelectData() { if (spip.Config != spi_sdi) spip.Config = spi_sdi; } // Write to an SCI register private void WriteRegister(byte address, ushort data, bool waitForDREQ = true) { wr_buff[0] = 2; // write command wr_buff[1] = address; // register wr_buff[2] = (byte)(data >> 8); // high byte wr_buff[3] = (byte)(data & 0xff); // low byte if (waitForDREQ) AwaitDREQ(); // wait for dreq to go high SelectCommand(); // select SCI spip.Write(wr_buff); } // SCI read private ushort ReadRegister(byte address) { wr_buff[0] = 3; // read command wr_buff[1] = address; // register AwaitDREQ(); // wait for dreq to go high SelectCommand(); // select SCI spip.WriteRead(wr_buff, rd_buff, 2); ushort r = rd_buff[0]; r <<= 8; r |= rd_buff[1]; return r; } private void AwaitDREQ() { if (dreq.Read()) return; while (!dreq.Read()) ; } // SDI write private void WriteData(params byte[] bytes) { AwaitDREQ(); // wait for dreq to go high SelectData(); // select SDI spip.Write(bytes); } // hw reset private void HardwareReset() { // reset the 1053 reset.Write(false); Thread.Sleep(1); reset.Write(true); Thread.Sleep(10); } // sw reset private void SoftReset() { WriteRegister(0, 0x0804); // SM_SDINEW|SM_RESET Thread.Sleep(1); AwaitDREQ(); } public void Reset() { HardwareReset(); SoftReset(); } }
Posted 15 December 2011 - 12:50 PM
Well, great job indeed...but I'd suggest to avoid to take advantage of the SPI-config "hole". It's a good practice, that may lead to bad results.
If you take a look at the SPI driver (C#, but native as well), there's no way to release correctly the resources (i.e. ports). IMHO, the "Config" property of the SPI class should be read-only.
Rather, I'd use the proper way to open the SPI port, by its constructor. To change config, just dispose the old SPI instance, and create a new one.
Also, implement the IDisposable pattern for correctly release any IDisposable resource (i.e. ports).
Thank you
Posted 15 December 2011 - 02:47 PM
Posted 15 December 2011 - 10:15 PM
Posted 16 December 2011 - 09:19 PM
Posted 16 December 2011 - 11:50 PM
You're welcome. The device is initially muted so remember to set an appropriate volume by writing a value of say 0x60 to register 0xB.
Use the WriteData class function to send your data (mp3 or other) for the device to play.
Good luck!
Ok, I'm beginning to think I'm not terribly bright. Than you so much for the code, but I cannot seem to make it work. I have the regular Netduino and the Sparkfun Shield with SD Card on board (http://www.sparkfun.com/products/10628). I've managed to read SD cards in a separate project.
Is the board I have the board you've gotten your card to work with? I've changed the pin definitions to match the shield as opposed to the Netduino Mini, and tried several other things I can think of, but it seems to think it's playing (and in a couple of cases I've gotten static, just no sound). The partial success is what lead me to pull the SD card bits out and just try to play an embedded resource, but that did not help (I've been trying the sample files posted on the sparkfun site just since it seemed most likely that those would work).
Would it be possible for you to post a working example of your code playing a file? I'm just going a little crazy after a couple days trying to make this work.
Thanks.
#19
Posted 17 December 2011 - 12:19 AM
#20
Posted 17 December 2011 - 12:49 AM
Sorry, I don't know anything about the shield you're using. I'm using a simple vs1053 breakout board and a Netduino mini.
Maybe someone else can help you?
Thanks for all your help. I had a feeling the more I stepped through it I was using different hardware.
