Relay board with RFID
Posted 26 February 2011 - 07:46 AM
I made a mistake when doing the layout which is why you see the red jumper wire going to the 5V pin on the Netduino+. I verified everything twice, except the physical spacing between the two 8 pin headers and the two 6 pin headers. Draught!
There are two 6 pin headers in the lower left. One goes to the RFID board (ID-20, plus LED) which isn't milled yet. The other 6 pin header goes to the actual door lock/unlock mechanism, with two of the pins being used for a reed switch.
- AlexW likes this
Posted 26 February 2011 - 08:31 AM
Posted 26 February 2011 - 02:48 PM
Track the Box
Posted 26 February 2011 - 07:09 PM
Hi Dan,
Very nice. Is this designed for personal use only...or do you have any plans to make the shield available to others as well?
Could be the seed for a cool built-it-yourself kit too!
I honestly hadn't through about doing it up as a kit. There is less than $10 in components (as pictured), but my fear is the board cost will put it out of reach. Batch PCB wants $2.50 sq in and milling these up one off isn't cheap either. I will gladly release the schematic, BOM and board layout though once I get the layout issue w/ the lower 6 pin headers fixed.
Posted 26 February 2011 - 07:23 PM
Very cool. RFID was something I planned to explore down the road and I love how (generally) few components it took to make the relay interface. If you don't plan to make it available as a kit like Chris suggested would love to see a wiring diagram.
The schematic is pretty easy honestly. I used the relay schematic from the arduino site, added a pull-down resistor to keep it from floating high on power up.
I've got to work on the board layout a bit to correct the issues with the two bottom pin headers, but after that I'll release it.
