Simultaneous Outport Ports?
10 replies to this topic
#1 fluke
fluke
  • 9 posts
Posted 24 February 2011 - 04:03 PM
Is there a command that makes it possible to simultaneously access multiple output ports? I need to send a clock signal off 2 Output ports and I'd like for them to both go high and low at exactly the same time: ie: static OutputPort port1= new OutputPort(Pins.GPIO_PIN_A1, false); static OutputPort port2= new OutputPort(Pins.GPIO_PIN_A3, false); port1.Write(true); port2.Write(true); Thread.Sleep(1000); port1.Write(false); port2.Write(false); This currently results in a ~50us lag between pulses. Is there a way to eliminate/ reduce that difference?
#2 Fred
Fred
  • 302 posts
  • LocationUK
Posted 24 February 2011 - 04:16 PM
If you're after exact timing I'd be tempted to do this in hardware. I'm assuming that they aren't *always* exactly the same - otherwise you'd just use the same signal. Could you use something like an OR gate to combine the outputs? e.g. To use Pin A2 to force both outputs high: create a third OutputPort, add an OR gate to pins A1 and A2 and use this as one output, add an OR gate to pins A3 and A2 and use this as the second output.
#3 Luke Cummings
Luke Cummings
  • 38 posts
  • LocationCalgary, AB
Posted 24 February 2011 - 06:22 PM
Sounds like your problem is a hardware related issue, can you be more specific as to what you are trying to do? Currently your saying these two pins will always have the same value. If so just use one pin.
Cheap, Fast, Good... Pick two
#4 Dan Morphis
Dan Morphis
  • 188 posts
Posted 24 February 2011 - 07:58 PM
What about using the Fluent Interop stuff? That can reduce the lag your seeing. I'm honestly not sure how much though.
-dan
#5 phantomtypist
phantomtypist
  • 142 posts
Posted 24 February 2011 - 08:58 PM
Honestly, if both pins are supposed to generate the same clock at the same time simultaneously, why do you need to pins? Just use one pin to generate the clock and have whatever items are using that clock read from the same pin/wire. Unless you provide more information about the project/setup like Luke Cummings said, I'm not sure we'd be able to accurately answer your question.
#6 Chris Walker
Posted 25 February 2011 - 02:08 AM
Hi fluke, If you absolutely need two pins to raise/lower at the exact same time, the only way to do that (even in assembly code) is by using shift registers. Basically, you'd set the state of a whole set of 32 pins at once (all the port A pins or all the port B pins). You can probably do this with Corey's Fluent interop...or using native code. Or using an I2C/SPI GPIO extender which can write multiple pins simultaneously. Chris
#7 fluke
fluke
  • 9 posts
Posted 25 February 2011 - 02:27 PM
Thanks for all the help everyone. For those that are curious, I'm controlling two different camera shutters through a custom trigger card and need two separate outputs to allow for operation of one or the other or both. It's not absolutely critical for me to eliminate the 50us delay, but there's no harm in trying!
#8 Corey Kosak
Corey Kosak
  • 276 posts
  • LocationHoboken, NJ
Posted 26 February 2011 - 06:45 PM
I think I must reluctantly disagree with our esteemed moderator. Doing what you want is quite easy actually.
Inside a given bank, you can:
  • Simultaneously turn on any subset of the 32 pins, or
  • Simultaneously turn off any subset of the 32 pins
It's certainly not the case that you have to set the state of all 32 pins at once. The interpretation of the SODR register is "for each 1 bit in the bit mask, turn on the associated pin (and leave the others alone)". Likewise, the interpretation of the CODR register is "for each 1 bit in the bit mask, turn OFF the associated pin (and leave the others alone)"
I have written some sample code which:
  • turns on (D0,D1) simultaneously
  • turns on (D2,D3) simultaneously (leaving D0,D1 alone)
  • then turns (D2,D3) off
  • then turns (D2,D3) on again
  • and finally turns all four off simultaneously
By the way, it happens that digital pins 0-3 are in the same bank. The pins are in a kind of funny order so the ones you expect to be in the same bank may not be.
Here is the screenshot from Salae: Posted Image
And here is the code, written in Fluent style. It could also be compiled into the firmware, but this was more convenient for me:
using FluentInterop.CodeGeneration;
using FluentInterop.Expressions;
using FluentInterop.Fluent;
namespace FluentSandbox {
  public class Program {
    public static void Main() {
      var pins=new[] {
        Pins.GPIO_PIN_D0,
        Pins.GPIO_PIN_D1,
        Pins.GPIO_PIN_D2,
        Pins.GPIO_PIN_D3,
      //sanity check
      var firstBank=(int)pins[0]/32;
      foreach(var pin in pins) {
        var thisBank=(int)pin/32;
        if(thisBank!=firstBank) {
          throw new Exception("all pins must be in same bank");
      var code=CodeGenerator.Compile(g=> {
        g.Declare.Function("main", f => {
          var firmware=f.StandardArgs.firmwareParam16;
          var d0=f.Declare.PIOReference("bank0");
          var mask0=f.Declare.Int("mask0");
          var mask1=f.Declare.Int("mask1");
          var mask2=f.Declare.Int("mask2");
          var mask3=f.Declare.Int("mask3");
          //wasteful to write d0 four times, since by definition it will be the same every time,
          //but this is just a demo
          firmware.GetPIOAndBitmask((int)pins[0], ref d0, ref mask0);
          firmware.GetPIOAndBitmask((int)pins[1], ref d0, ref mask1);
          firmware.GetPIOAndBitmask((int)pins[2], ref d0, ref mask2);
          firmware.GetPIOAndBitmask((int)pins[3], ref d0, ref mask3);
          var mask0And1=f.Declare.Int("mask0and1", mask0|mask1);
          var mask2And3=f.Declare.Int("mask2and3", mask2|mask3);
          var allMasks=f.Declare.Int("allMasks", mask0And1|mask2And3);
          d0.PER=allMasks; //enable all 4 pins at once
          d0.CODR=allMasks; //clear all 4 pins at once
          d0.OER=allMasks; //enable output on all 4 pins at once
          d0.SODR=mask0And1; //turn 0 and 1 on
          d0.SODR=mask2And3; //turn 2 and 3 on
          d0.CODR=mask2And3; //turn 2 and 3 off
          d0.SODR=mask2And3; //turn 2 and 3 back on again
          d0.CODR=allMasks; //turn all 4 off
      code.Invoke(0);
#9 Corey Kosak
Corey Kosak
  • 276 posts
Posted 26 February 2011 - 06:54 PM
By the way, this is the justification for why I claimed here that the Netduino has the potential for huge throughput if one is using a parallel communication protocol.
#10 Chris Walker
Posted 27 February 2011 - 01:00 AM
Hey Corey, Thanks for clarifying that. You're exactly right. Shifting out all 32 bits on PORTA/PORTB at the same time--using bitmasks--is what I was meaning to say. Thank you for taking the time to say it so much clearer and more accurately :) Chris
#11 Luke Cummings
Luke Cummings
  • 38 posts
Posted 27 February 2011 - 07:03 AM
Wow Corey, I just has a "Duh" moment there... I guess some of us hardware guys have been spending a little too much time in .Net! :) Great explaination!
