InterruptPort input = new InterruptPort(Pins.GPIO_PIN_D0, true, Port.ResistorMode.PullDown, Port.InterruptMode.InterruptEdgeLow);
It doesnt like the pulldown for some reason.
Thanks!
ArgumentExecption on Port.ResistorMode.PullDown
Started by sebastianpatten, Feb 19 2011 08:28 PM
#1Posted 19 February 2011 - 08:28 PM
Why is my code throwing an ArgumentException when I use the following?
InterruptPort input = new InterruptPort(Pins.GPIO_PIN_D0, true, Port.ResistorMode.PullDown, Port.InterruptMode.InterruptEdgeLow); It doesnt like the pulldown for some reason. Thanks! #2Posted 19 February 2011 - 09:18 PM Unfortunately, the Netduino microcontroller does not have pull-down resistors, you have to use external ones. #3Posted 25 February 2011 - 02:53 AM
As CW2 mentioned... some microcontroller have integrated pull-down resistors; others have pull-up resistors; others may have both or neither.
The SAM7X microcontroller on the Netduino has pull-ups. If you need pull-down resistors, just follow CW2's advice and add an external pull-down.
#4Posted 24 February 2012 - 03:10 AM
As I recall the point of a pull-up resistor is to stop a signal line from floating by tying it to (int this case) 3.3V through a large resistance, such that a switch shorting the pin to earth will pull it low but otherwise it will be pulled to high. Is this the behaviour we can expect from the Netduino: inputs report high unless shorted to ground?
"ArgumentException" is an atrocious way to report a not-supported condition. Especially when there is a NotSupportedException. You could also say something useful like "Netduino hardware does not support PullDown mode."
Is there any literature on using the Netduino other than this forum and that IoT book?
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
