If I am not wrong, I don't need any more on the hardware side. Once I plugged it, I get the lcd on. The easiest test I want to try first is to turn on/off the lcd. According to the manual, to turn off the lcd I need to do an i2c.write(0xFE42) without parameters.
As far as I know there are two posssibilities to write into specific address:
Note : this is just a small sanpshot of the whole class:
public void Write(I2CDevice.Configuration config, byte[] writeBuffer, int transactionTimeout)
// Set i2c device configuration.
I2CDevice.Configuration _slaveConfig = new I2CDevice.Configuration(0x50, 100);
// create an i2c write transaction to be sent to the device.
I2CDevice.I2CTransaction[] writeXAction = new I2CDevice.I2CTransaction[] { I2CDevice.CreateWriteTransaction(writeBuffer) };
lock(_slaveDevice)
// the i2c data is sent here to the device.
int transferred = _slaveDevice.Execute(writeXAction, transactionTimeout);
// make sure the data was sent.
if (transferred != writeBuffer.Length)
throw new Exception("Could not write to device.");
public void WriteSomethingToSpecificRegister()
I2CBus.GetInstance().WriteRegister(_slaveConfig, 0x3C, new byte[2] { 0xF4, 0x2E }, TransactionTimeout);
I think I have to use the method WriteSomethingToSpecificRegister() but I can't address a 2byte address like OxFE41, Just a 1 byte address.
By using both methods I get nothing. The lcd does not turn off...what am I doing wrong?
Asaak,
If you can please post a small project which shows the issue you're having, we can help a bit more. Right now, I'm not totally clear on the error you're getting.
Have you tried using the Write method to send your 2 bytes as a byte array?
I'm fiddling with 12c (for a HMC6352 compass module) and finding it awkward to work with compared to serial or SPI. I notice the display you have can be used with both of these protocols - I might be less frustrating to try with one of those if your project allows for it.
I would attach a project example but I wasn't allowed to by the webform.Instead, I have put all the classes I use.
According to the pdf, to turn off the lcd I need to send a 0xFE 0x62 without parameters. In the example, I show a method to do so but the problem is that "address" is a byte, not a double byte like 0xFE 0x62 so I can not use that...and if I use the write method nothing happens as well...I must be doing something wrong but I can't figure out what...
Thanks for the help!
namespace example
// write your code here
LCD lcd = new LCD(0x50);
byte[] address = { 0xFE, 0x42};
byte data = null;
lcd.WriteSomethingToSpecificRegister(address, data); // here is the problem
namespace example
class LCD
private I2CDevice.Configuration _slaveConfig;
private const int TransactionTimeout = 1000; // ms
private const byte ClockRateKHz = 100;
public byte Address { get; private set; }
/// <summary>
/// Example sensor constructor
/// </summary>
/// <param name="address">I2C device address of the example sensor</param>
public LCD(byte address)
Address = address;
_slaveConfig = new Microsoft.SPOT.Hardware.I2CDevice.Configuration(address, ClockRateKHz);
public byte[] ReadSomething()
// write register address
I2CBus.GetInstance().Write(_slaveConfig, new byte[] { 0xF2 }, TransactionTimeout);
// get MSB and LSB result
byte[] data = new byte[2];
I2CBus.GetInstance().Read(_slaveConfig, data, TransactionTimeout);
return data;
public void WriteSomething(byte[] data)
I2CBus.GetInstance().Write(_slaveConfig, data, TransactionTimeout);
public byte[] ReadSomethingFromSpecificRegister()
I2CBus.GetInstance().ReadRegister(_slaveConfig, 0xF1, data, TransactionTimeout);
return data;
public void WriteSomethingToSpecificRegister(byte register, byte[] data)
I2CBus.GetInstance().WriteRegister(_slaveConfig, register, data, TransactionTimeout);
namespace example
public class I2CBus : IDisposable
private static I2CBus _instance = null;
private static readonly object LockObject = new object();
public static I2CBus GetInstance()
lock (LockObject)
if (_instance == null)
_instance = new I2CBus();
return _instance;
private I2CDevice _slaveDevice;
private I2CBus()
//this._slaveDevice = new I2CDevice(new I2CDevice.Configuration(0x50, 100));
this._slaveDevice = new I2CDevice(new I2CDevice.Configuration(0, 0));
public void Dispose()
this._slaveDevice.Dispose();
/// <summary>
/// Generic write operation to I2C slave device.
/// </summary>
/// <param name="config">I2C slave device configuration.</param>
/// <param name="writeBuffer">The array of bytes that will be sent to the device.</param>
/// <param name="transactionTimeout">The amount of time the system will wait before resuming execution of the transaction.</param>
_slaveDevice.Config = config;
lock (_slaveDevice)
/// <summary>
/// Generic read operation from I2C slave device.
/// </summary>
/// <param name="readBuffer">The array of bytes that will contain the data read from the device.</param>
public void Read(I2CDevice.Configuration config, byte[] readBuffer, int transactionTimeout)
// create an i2c read transaction to be sent to the device.
I2CDevice.I2CTransaction[] readXAction = new I2CDevice.I2CTransaction[] { I2CDevice.CreateReadTransaction(readBuffer) };
lock (_slaveDevice)
// the i2c data is received here from the device.
int transferred = _slaveDevice.Execute(readXAction, transactionTimeout);
// make sure the data was received.
if (transferred != readBuffer.Length)
throw new Exception("Could not read from device.");
/// <summary>
/// Read array of bytes at specific register from the I2C slave device.
/// </summary>
/// <param name="register">The register to read bytes from.</param>
public void ReadRegister(I2CDevice.Configuration config, byte register, byte[] readBuffer, int transactionTimeout)
byte[] registerBuffer = { register };
Write(config, registerBuffer, transactionTimeout);
Read(config, readBuffer, transactionTimeout);
/// <summary>
/// Write array of bytes value to a specific register on the I2C slave device.
/// </summary>
/// <param name="register">The register to send bytes to.</param>
public void WriteRegister(I2CDevice.Configuration config, byte register, byte[] writeBuffer, int transactionTimeout)
Write(config, writeBuffer, transactionTimeout);
/// <summary>
/// Write a byte value to a specific register on the I2C slave device.
/// </summary>
/// <param name="value">The byte that will be sent to the device.</param>
public void WriteRegister(I2CDevice.Configuration config, byte register, byte value, int transactionTimeout)
byte[] writeBuffer = { register, value };
public void provaMeva(I2CDevice.Configuration config, int transactionTimeout)
byte[] writeBuffer = { 0xFE, 0x72 };
Asaak,
Does the I2C device require a "repeated start bit" between the address and the request for data? If so, you'll want to update to the latest v4.1.1 alpha/beta firmware and use its "internaladdress" feature.
If all else fails, maybe we can get one of the devices here and play...
Thanks Chris for the answer. Well...I don't know. Where can I find this? I attach the LCD pdf and I will reproduce the page regarding to communication to see if you could tell me yes or no to your question:
Communication Information
This display uses a built‐in PIC 16F690 for serial communication.
I2C protocol:
To enter the I2C mode, place a jumper on R1.
SDA and SDK have pull‐up resistors (10K Ohm) on R7 and R8.
The default I2C address is 80 (50 hex). The I2C address can be changed to any 8‐bit value by command function, with
the exception that the LSB (least significant bit) must always be ‘0’. Once the I2C address has been changed, it will be
saved in the system memory, and it will revert back to the default address if either RS232 or SPI protocol is selected.
The I2C interface is capable of receiving data at up to 100KHz‐clock rate.
SPI protocol:
To enter the SPI mode, place a jumper on R2.
SPI mode has a normally high level idle clock. When Slave Select is LOW, data is sampled on the rising edge of the
Clock.
The SPI interface is capable of receiving data at up to 100KHz‐clock rate.
RS232 protocol:
To enter the RS232 mode, both R1 and R2 should be open.
The RS232 signal must be 5V TTL compatible. Communication format is 8‐bit data, 1 Stop bit, no parity, no handshaking.
Default BAUD rate is 9600, and is changeable with a command function. Once the BAUD rate has been
changed, it will be saved in the system memory, and it will revert back to the default address if either I2C or SPI
ASCII TEXT
To display normal text, just enter its ASCII number. A number from 0x00 to 0x07 displays the user
defined custom character, 0x20 to 0x7F displays the standard set of characters, 0xA0 to 0xFD display
characters and symbols that are factory‐masked on the SPLC780D controller. 0xFE is reserved.
Here, if I try this example doing lcd.test(), I don't get a communication error but simply it does nothing.
public void test()
string hola = "hellow";
System.Text.UTF8Encoding encoder = new System.Text.UTF8Encoding();
byte[] bytesToSend = encoder.GetBytes(hola);
byte[] command = new byte[2];
//command to turn off the display
command[0] = 0xFE;
command[1] = 0x42;
byte[] prefix = new byte[1];
prefix[0] = 0x42;
//0xFE 0x47 turn on cursor
I2CBus.GetInstance().Write(_slaveConfig, command, TransactionTimeout);
I2CBus.GetInstance().Write(_slaveConfig, bytesToSend, TransactionTimeout);
WriteSomethingToSpecificRegister(0xFE, prefix);
I have tried to unplug scl/sda and I noticed that if I try to write with scl unplugged then I get a communication error impossible to write to device. If I do the same with sda, no error is shown.
In the same pdf, there is an example of a serial communication. Here it is:
Serial_LCD_Test.c
Program for writing to Newhaven Display Serial LCDs
(c)2010 Curt Lagerstam - Newhaven Display International, LLC.
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
#include "e:\2321_tester\tester_init.h"
* MAIN PROGRAM *
void main(void)
OSCCON |= 0x73; // internal RC, 8MHz
PORTA = 0x00;
TRISA = 0xFF; // B'1111 1111'
PORTB = 0x00;
TRISB = 0xFF; // B'1111 1111'
PORTC = 0x75; // B'0111 0101'
TRISC = 0x00; // B'0000 0000'
GIE = 0;
INTCON = 0x00; // disable all interrupt
INTCON2 = 0x00; // enable port B pull-up
INTCON3 = 0x00;
set up adc for analog inputs
ADC clock = Fosc/8 (1 uSecond), adc off,
AN0 is contrast input, AN1 is backlight brightness input
ADCON0 = 0x00;
ADCON1 = 0x0D; // RA0, RA1 are analog inputs
ADCON2 = 0x15; // left just, 4TAD, Fosc/16, 0001 0101
set up timer 0 for 10 millisecond interrupt
timer 0 is a general purpose timer
T0CON = 0x46; // timer 0 control register
T1CON = 0xB0; // timer 1 off
spi_ss = 1;
if (!i2c_sel) {
com_mode = 3; // I2C
init_i2c();
else {
if (!spi_sel) {
com_mode = 2; // SPI
init_spi();
else {
com_mode = 1; // RS232
init_rs232();
/* END OF SPECIAL REGISTER INITIALIZATION */
tick_100m = 9; // 100 millisceond counter
tick_1s = 9; // 1 second counter
TMR0L = 100; // initialize to 100 counts
TMR0ON = 1;
TMR0IF = 0;
TMR0IE = 1;
contrast = 0;
contrast_f = 0;
bright = 0;
bright_f = 0;
serial_busy = 0;
TXREG = 0;
PEIE = 1;
GIE = 1; // enable global interrupt
delay_ms(100); // waiting for LCD to initialize
lcd_clear();
// Set Contrast
tx_packet[0] = 0xFE;
tx_packet[1] = 0x52;
tx_packet[2] = 40; // contrast 1 - 50
send_packet(3);
// Set Backlight Level
tx_packet[1] = 0x53;
tx_packet[2] = 15; // backlight 1 - 15
send_packet(3);
tx_packet[1] = 0x48; // underline cursor off
send_packet(2);
delay_ms(1000);
for (i = 0; i < 16; i++) { // "NewHaven Display"
tx_packet[i] = text6[i];
send_packet(16);
lcd_cursor(0x40);
delay_ms(100);
for (i = 0; i < 16; i++) { //"Serial LCD Demo"
tx_packet[i] = text7[i];
send_packet(16);
temp = 0;
for (;;) {
// Contrast Control
if (contrast_f && !serial_busy ) {
tx_packet[2] = contrast_save;
send_packet(3);
contrast_f = 0;
// Backlight Brightness
if (bright_f && !serial_busy) {
tx_packet[2] = bright_save;
send_packet(3);
bright_f = 0;
} /* end main */
send 'x' byte of the tx_packet[] to the serial port
void send_packet(unsigned int x)
unsigned int ix;
led = 1;
serial_busy = 1; // set busy flag
switch (com_mode) {
case 1: // RS232 mode
for (ix = 0; ix < x; ix++) {
while (!TXIF);
TXREG = tx_packet[ix];
while (!TRMT);
break;
case 2: // SPI
spi_ss = 0;
delay_cycles(5);
SSPBUF = tx_packet[ix];
while(!BF);
temp = SSPBUF;
delay_us(5); // reduce effective clock rate
delay_cycles(5);
spi_ss = 1;
break;
case 3: // I2C
i2c_busy(0x50); // send address
wait_sspif();
PEN = 1; // send stop bit
while (PEN == 1); // wait until stop bit finished
break;
default:
break;
led = 0;
serial_busy = 0; // clear busy flag
wait for SSPIF set routine, add a software counter to ensure the
routine does not hang.
void wait_sspif(void)
loop_hi = 9;
loop_lo = 0xC4;
SSPIF = 0;
while (!SSPIF && loop_hi) {
loop_lo--;
if(!loop_lo)
loop_hi--;
SSPIF = 0;
i2c_busy routine poll the ACK status bit to see if device is busy
void i2c_busy(unsigned char x)
SEN = 1; // start bit
while(SEN); // wait until start bit finished
while (1) {
SSPIF = 0;
SSPBUF = x; // send write command
wait_sspif(); // wait until command finished
if (ACKSTAT) { // check ACK, if 1, ACK not received
RSEN = 1; // then sent start bit again
while (RSEN); // wait until start bit finished
else
break;
set lcd cursor
void lcd_cursor(unsigned int x)
tx_packet[1] = 0x45;
tx_packet[2] = x;
send_packet(3);
delay_ms(10);
clear one line of display
void clear_line(unsigned int x)
unsigned int ij;
for (ij = 0; ij < x; ij++) {
tx_packet[ij] = 0x20;
send_packet(x);
lcd clear
void lcd_clear(void)
tx_packet[1] = 0x51;
send_packet(2);
delay_ms(10);
initialize for USART interface
void init_rs232(void)
TXSTA = 0x26; // rs232 transmit status register
RCSTA = 0x80; // serial port enable
BAUDCTL = 0x08; // BRG16 = 1;
SPBRG = 207;
SPBRGH = 0;
initialize for spi interface
void init_spi(void)
TRISC |= 0x10;
SSPCON1 = 0x32; // master, 125K CLK, CKP = 1
temp = SSPBUF;
SSPOV = 0;
SSPIF = 0;
initialize for i2c interface
void init_i2c(void)
TRISC |= 0x18; // RC3, RC4 as inputs
SSPSTAT = 0x00;
SSPADD = 19; // 100K Hz
SSPCON1 = 0x28; // i2c master, enable SSP
temp = SSPBUF;
SSPOV = 0;
SSPIF = 0;
SSPIE = 0; // enable I2C interrupts
ADC read routine, read the selected adc channel and put the result
in adc_result.
void adc(unsigned char n)
switch (n) {
case 0: // adc channel 0, contrast
ADCON0 = 0x03;
break;
case 1: // adc channel 1, backlight
ADCON0 = 0x07;
break;
default:
break;
while (GODONE); // wait for end of convert
adc_result = ADRESH;
if (adc_result > 250)
adc_result = 250;
/* interrupt routines */
/* timer 0 is set to interrupt at 100 Hz rate. */
#int_timer0
void timer0_isr(void) /*interrupt handler routine*/
restart_wdt(); // reset watchdog timer
TMR0L = 100;
10 millisecond functions
if (tick_wait10)
tick_wait10--;
if (tick_100m) {
tick_100m--;
100 millisecond functions
else { // 100 millisecond function
tick_100m = 9; // reload 100 millisecond timer
if (tick_wait100) // general purpose 100 mSecond timer
tick_wait100--;
adc(0); // read contrast setting
contrast = adc_result / 5;
if (!contrast)
contrast = 1;
if (contrast != contrast_save) {
contrast_save = contrast;
contrast_f = 1;
adc(1); // read backlight setting
bright = adc_result / 15;
if (!bright)
bright = 1;
if (bright != bright_save) {
bright_save = bright;
bright_f = 1;
if (tick_1s) {
tick_1s--;
1 second functions
else {
tick_1s = 9; // reload 1 second timer
} /* end of timer 0 interrupt routine */
Asaak,
It looks like the LCD has built-in pull-up resistors. So you should be fine there. Also, it looks like your I2C address defaults to 0x50 (within the 7-bit range) and I don't see any other glaring issues that could be causing problems.
My first concern is that we're starting with a huge amount of code here. It should be possible to create a "first test" to just turn the display on and off. With about 4 lines of code. If you can get rid of the I2CBus code, etc. etc. and just boil it down to a "new I2CDevice", "CreateWriteTransaction", and "Execute" set of code...that is probably going to help a bunch here. With this much code and without a device to test against (or any logic analyzer at your location), it's going to be hard to narrow it down. We should start simple.
Here, the simpliest piece of code I think I could write for my purpose. First I send the turn off command and nothing happens, then I send a word which, according to the lcd datasheet if I send the ascii directly it will print. Again, nothing happens.
* 0x50 address of the lcd
* 100 Khz clock
I2CDevice lcd = new I2CDevice(new I2CDevice.Configuration(0x50,100));
* 0xFE 0x42 no parameters -> turn off display ( nothing happens )
I2CDevice.I2CTransaction[] writeCommandAction = new I2CDevice.I2CTransaction[] { I2CDevice.CreateWriteTransaction(new byte[] {0xFE, 0x42}) };
int transferred = lcd.Execute(writeCommandAction, 1000);
I2CDevice.I2CTransaction[] writeWordAction = new I2CDevice.I2CTransaction[] { I2CDevice.CreateWriteTransaction(bytesToSend) };
It executes fine, no errors...but nothing in the LCD. I haven't tried with the firmware you suggested. I will do it.
Asaak,
Do you have access to a logic analyzer (such as the Saleae Logic)? Unfortunately we're murking around in the dark if we can't see what's actually happening on the digital lines.
Also, can you use the display in a SPI mode? That might simplify things for you here...
[Finally, where can someone buy one of these displays?]
here where you can buy the lcd -> http://www2.mouser.c...VZ7KOwwNV%2bA==
I can work in spi mode, I just need to solder the connector of r2 resistor. why is it easier? I don't know how spi works, I need to take a look at it.
Sadly, I don't have a logic analyzer..this is why I am in the dark as you said..
The reason why I want it working using i2c is twofold: LCD supports it, and it only need two wires, and this is something very interesting because I do really want to have the rest of the pins free for other connections.
I successfully updated the firmware but now I don't know how to configure repeated start/stop bit. Any help with that?
I don't think that the display requires repeated start bit. The repeated start bit feature applies when reading data _from_ an I2C device such as an EEPROM. [I had thought that perhaps some of the commands were reading data from the display earlier...but looking at the data sheet it appears that it is write-only.]
Why do you always try to send the 'display off' as a first command in your examples? If that command works, you certainly won't see anything if the following send commands do actually work!
And 'display off' does not mean that the background lighting goes off, it just disables the LCD part. So i don't see why you are certain that the 'display off' command is not working.
I'd try the following code. And please reset the display (by unplugging it from power) before trying the code, so you can be sure it isn't in some strange state due to your other tests beforehand.
OutputPort light = new OutputPort(Pins.ONBOARD_LED, true);
I2CDevice lcd = new I2CDevice(new I2CDevice.Configuration(0x50, 50));
int bytesTransferred = 0;
string hellow = "hellow";
byte[] bytesToSend = encoder.GetBytes(hellow);
I2CDevice.I2CTransaction[] writeCommandAction = new I2CDevice.I2CTransaction[] { I2CDevice.CreateWriteTransaction(bytesToSend) };
bytesTransferred = lcd.Execute(writeCommandAction, 1000);
if (bytesTransferred != bytesToSend.Length)
light.Write(false);
nothing happens. It says it has sent all the 6 byte to transfer, even if I unplug all the LCD wires. on_board led turns off like if all the bytes have beens successfully transfered...but they are not.
I have a Newhaven display running in .NETMF, you can look a working code on http://www.fezzer.co...ial-lcd-display . While this was done FEZ Panda, the code should work on Netduino. Give it a look. I will try it with the Netduino tomorrow morning myself so I can post a demon with the Netduino
