SD shield with netduino firmware 4.1 alpha 7
Posted 17 February 2011 - 07:57 AM
I am trying to run the following sample and running into volume not found exceptions....
public static void Test()
Debug.Print("SDCardTest.Test\n");
StorageDevice.MountSD("SD1", SPI_Devices.SPI1, Pins.GPIO_PIN_D5);
string[] directories = System.IO.Directory.GetDirectories(@"\");
Debug.Print("Directory count: " + directories.Length.ToString());
for (int i = 0; i < directories.Length; i++)
Debug.Print("Directory: " + directories[i]);
string[] files = System.IO.Directory.GetFiles(@"\SD1");
Debug.Print("file count: " + files.Length.ToString());
for (int i = 0; i < files.Length; i++)
Debug.Print("filename: " + files[i]);
//FileStream fs = new FileStream(files[i], FileMode.Open, FileAccess.Read, FileShare.None, 512);
//StreamReader sr = new StreamReader(fs);
//Debug.Print("contents: " + sr.ReadToEnd());
StorageDevice.Unmount("SD1");
Thanks in advance.
Mehmet
Posted 17 February 2011 - 08:31 AM
Posted 17 February 2011 - 04:40 PM
Posted 17 February 2011 - 10:18 PM
Thank you for the information. The sample code I am using is setting the card to use D5 as chip select. I am a little confused as I am kind of new to this. Should I use D4 and short the physical pin to D10?
Hi Mehmet,
Which pin does your shield use for "chip select" of the SD card? Whichever one it uses...place a jumper wire between that pin header and D10. If it uses D10 (which many shields with SD use), you're already set.
We'll expand this capability in the beta...
Posted 18 February 2011 - 05:40 AM
I have checked out the schematic for the arduino shield and it looks like it's using #8... I went ahead and removed pin 8 of the shield and jumpered it to pin 10 so pin 10 would connect to the shields CS line. arduino micro sd shield drawing....
I still get the volume not found exception... Could it be the hex converter on the sd shield causing the problem?
Mehmet
Posted 18 February 2011 - 08:01 AM
Posted 18 February 2011 - 06:05 PM
Posted 19 February 2011 - 12:17 AM
Posted 26 February 2011 - 07:58 AM
Posted 26 February 2011 - 08:29 AM
I finally got it to work. Now my challenge is to create directories and files on the card. Are there any samples for that on here? I can't search for sd as it is a 2 letter word.
Hi Mehmet,
Good news!
Take a look at System.IO.FileStream in the .NET MF online docs. Or just search for StreamReader or FileStream on the forums amd you'll find a few...
Posted 28 February 2011 - 02:16 PM
You got it to work with the Sparkfun SD Shield with voltage converter chip? Any special actions required?
I've got a Sparkfun shield with voltage converter too any i'm a bit confused. The netduino supplies 3.3V spi signals, so you the shield doesn't actually require a voltage converter on the shield? So that was only for Arduino?
Thanks for the info.
Posted 07 March 2011 - 10:26 PM
For everybody having the same question, for 4.1.0 alpha 7: just short pin 8 and 10 for the sparkfun shield with voltage converter. Then it works with something like this:
StorageDevice.MountSD("SD", SPI.SPI_module.SPI1, Cpu.Pin.GPIO_Pin8); FileStream filestream = new FileStream(@"SD\filename.txt", FileMode.Append, FileAccess.Write, FileShare.None); StreamWriter streamWriter = new StreamWriter(filestream); streamWriter.WriteLine("WriteSomeText"); streamWriter.Close(); filestream.Close(); StorageDevice.Unmount("SD");
Posted 11 March 2011 - 07:44 PM
The weirdest thing is that the pins have other names on the back:
Any suggestion on how to connect this one?
Posted 12 March 2011 - 10:05 AM
Posted 15 March 2011 - 09:28 AM
Cheap trick: if you just want some quick and dirty onboard storage, I think you could actually just solder jumper wires directly onto most sd cards' cs, clk, di, do, vcc (3.3v) and gnd connectors. I'm gonna try this myself since I got a lot old and "small" sized (below 1 Gb) that I don't use anymore anyway. I probably need to be careful not soldering too hot for too long.Never mind, I'm a newbie... I used google and found it out: http://en.wikipedia....ower_supply_pin
VDD and VSS are other means for V+ and V-
I got it working with that shield like this:
RSV: Unused
/CS: Pin 10
DI: Pin 11
VDD: 3V3
CLK: Pin 13
VSS: Gnd
D0: Pin 12
If I solder on twin wires I can use a dummy in the other end too so that I even can stick it into a pc for occasional file management while disconnecting it from the netduino. Sure, I could even have a dipswitch and a header for easy access, but then price is getting closer to a bob
This trick should work on any sd that boots in spi mode.
Edited by hanzibal, 15 March 2011 - 09:32 AM.
Posted 15 March 2011 - 10:24 AM
Posted 15 March 2011 - 04:27 PM
Exactly, I recently purchased a full size SD bob (before I realized the above) and it was twice the price for a micro and roughly equal to the price of my vs1053 mp3 decoder chip so pricing is definately wrong somwhere.I've used a micro SD breakout board as above and that does nothing more than expose the card's pins. SPI access to the card worked just fine. I can't see why some careful soldering directly to a SD card wouldn't work, if that's your thing. SD (full size) breakout boards do seem strangely more expensive than the micro version.
Posted 17 March 2011 - 09:00 PM
