Netduino Plus Firmware v4.1.1 ALPHA 7
Posted 14 February 2011 - 07:43 AM
Posted 14 February 2011 - 05:22 PM
Posted 14 February 2011 - 09:27 PM
Upgraded from alpha6 to alpha7 and all ok, booting code does not hang in vs deployment so no need for build3 any longer.
Alan
Cool. Thanks for testing this, Alan.
Posted 14 February 2011 - 10:27 PM
.EnableDhcp()kind of work, I have to restart NetduinoPlus to get a IP from my router, then it works fine every time I start the board. If I just run the code I still get 0.0.0.0
/Ken
Posted 14 February 2011 - 11:44 PM
Thanks, Ken. So we're getting closer, but are not quite there. Let's see if we can get this problem fully solved over the next few weeks before 4.1.1 goes gold.
Posted 16 February 2011 - 06:00 PM
Alan
Confirmed. My fingers can take a break from pulling out and plugging in the USB cable
Posted 18 February 2011 - 07:15 PM
Posted 18 February 2011 - 10:05 PM
Installed the latest version of the firmware on my Netduino Plus so I could use the updates to the i2c interface. I'm trying to interface to an MD22 motor controller from My link. When I run my test project I get the an exception, please see attached screen shot. The exception occurs when I call the i2c execute method. I have also attached by VS2010 project to help.
Any idea what I'm doing wrong?
Posted 19 February 2011 - 12:08 AM
Hi ScubaBoy,Hi,
Do you have a diagram of how the MD22 motor controller is attached to your Netduino? Does it have integrated pull-up resistors? And if not, have you added them to your I2C data and clock lines?
Posted 19 February 2011 - 12:09 AM
I upgraded my N+ and lost USB connection. My PC doesn't recognize Netduino.
Hi madartsoft,
Were you using serial deployment or USB deployment before you upgraded your Netduino Plus?
If you hold down the pushbutton on your Netduino Plus while plugging it into your computer, can you immediately PING it from MFDeploy?
[Worst case scenario, you can always erase your Netduino Plus completely and reflash it...but really, firmware upgrades should go off without a hitch.]
Posted 19 February 2011 - 08:07 AM
Hi ScubaBoy,
I have got pull up resistors attached to the data and clock lines (MD22 doesn't have integrated ones), the MD22 motor controller is connected to analogue pins 4&5 for i2c side of things and gets +5v and 0v from the Netduino.
Posted 19 February 2011 - 08:37 AM
In all likelihood, there is a problem with the device address - the current I2C implementation supports only 7-bit addressing, so 0xB0 is out of range.Any idea what I'm doing wrong?
Posted 19 February 2011 - 08:54 AM
Hi madartsoft,
I use USB deployment as serial was never worked for me. I had to restart my PC then it seems that everything is ok.
Posted 19 February 2011 - 10:48 AM
Thanks for pointing that out, a little shift to the right and it's working
Posted 19 February 2011 - 01:39 PM
Posted 19 February 2011 - 01:44 PM
Is the source code of the latest alpha firmware available somewhere?
I can send you the diff files if you'd like, Corey. With v4.1.2, we'll also check in the betas online--but for now we just post the final versions. CodePlex should make it much less time consuming to package source updates and we can make it part of the workflow...
Posted 19 February 2011 - 01:53 PM
Sure, that would be great! The only place I know to get source is here, and I assume that's rather out of date by now, and I don't know where else to go. Thanks!
Posted 20 February 2011 - 06:13 PM
#19
Posted 20 February 2011 - 06:27 PM
Will CW2's OneWire function be in the firmware?
The current plan is to integrate CW2's OneWire into v4.1.2 using runtime native code interop.
Posted 20 February 2011 - 07:21 PM
That sounds great, when do you think 4.1.2 is released (any betas before with OneWire?)
