Just a small info (yet another) to those who wants to compile the Netduino source.
- Start compiling with the CodeSourcery (GCC 4.2) compiler, which is supported by Microsoft.
- To make it compile, you most likely need to edit the memory layout. This is due to changing and different compiler outputs.
- The files are:
C:\MicroFrameworkPK_v4_1\Solutions\Netduino\TinyCLR\scatterfile_tinyclr_gcc.xml
C:\MicroFrameworkPK_v4_1\Solutions\Netduino\DeviceCode\Blockstorage\Sam7X_blockstorage\Sam7x_Bl_Config.cpp
In the sam7x file you'll find this:
const BlockRange g_SAM7X_BS_BlockRange[] = { { BlockRange::BLOCKTYPE_BOOTSTRAP , 0, 5 }, { MEMORY_BLOCKTYPE_GCC_SPECIAL_BOOTSTRAP, 6, 14 }, { BlockRange::BLOCKTYPE_CODE , 15, 44 }, { MEMORY_BLOCKTYPE_GCC_SPECIAL_CODE , 45, 46 }, { BlockRange::BLOCKTYPE_DEPLOYMENT , 47, 60 }, { BlockRange::BLOCKTYPE_STORAGE_A , 61, 61 }, { BlockRange::BLOCKTYPE_STORAGE_B , 62, 62 }, { BlockRange::BLOCKTYPE_CONFIG , 63, 63 } };Which doesn't fit when using GCC4.2. If you look at it it will tell you, that the BootLoader will take up either 6 blocks (RVDS) or 15 blocks (GCC). This is mostly correct. However depending on what you're trying to do, the BootLoader might not be of interest to you. The TinyCLR is. Which means that you can keep your SecretLabs compiled RVDS BootLoader (much smaller) and combine it with your own TinyCLR.
I've therefor changed my setup to this:
const BlockRange g_SAM7X_BS_BlockRange[] = { // { BlockRange::BLOCKTYPE_BOOTSTRAP , 0, 5 }, // ~50k (RVDS BootLoader) { BlockRange::BLOCKTYPE_CODE , 6, 49 }, // ~360k = 0x0C000 { BlockRange::BLOCKTYPE_DEPLOYMENT , 50, 62 }, // ~106k = 0x64000 { BlockRange::BLOCKTYPE_CONFIG , 63, 63 } };Depending on the size on your TinyCLR you might have to alter the CODE and DEPLOYMENT addresses.
Yes, I've removed the STORAGE_A and B. They're official areas in the netmf, but they're not currently in use by the Netduino.
When you've made this change, you also need to adjust the scatterfile. This is what I use:
<Set Name="Heap_Begin" Value="0x00010000"/> <Set Name="Heap_End" Value="0x00017FF8"/> <Set Name="Stack_Bottom" Value="0x00018000"/> <Set Name="Stack_Top" Value="0x0001FFF8"/> <If Name="TARGETLOCATION" In="FLASH"> <Set Name="Code_BaseAddress" Value="0x0010C000"/> <!-- This is start TinyCLR --> <Set Name="Deploy_BaseAddress" Value="0x00164000"/> <!-- This is start app code --> <Set Name="Code_Size" Value="%Deploy_BaseAddress - Code_BaseAddress%"/> <Set Name="Config_BaseAddress" Value="0x0017E000"/> <Set Name="Config_Size" Value="0x00002000"/> <Set Name="Valid" Value="true"/> </If>
Notice that the Heap and Stack is only using half of the ram? Yeah ... fancy that.
If you make it compile then just open up your MFDeploy and flash your own ER_FLASH and ER_CONFIG. They're placed in:
C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\FLASH\release\Netduino\bin\tinyclr.hex\
