Hi KiwiBryn,
First, thanks a lot for getting back to me. Please find below the requested information. I have also compared the used versions in my program and all versions are 4.3.1.0 which is the same as in the assemblies. From the MFDeploy it seems my program is running but cyclic reboot continues untill I get the error message given above.
Looking forward to a solution.
MFDeploy Device Info:
Give short pulse to light
Light is on
Light is off
Light is on
Light is off
Light is on
Give short pulse to liDeviceInfo:
ght
Light is off
HAL build info: 4.3.1.0, Netduino 3 Ethernet (v4.3.2.3) by Secret Labs LLC
Light is on
OEM Product codes (vendor, model, SKU): 34, 177, 4104
Serial Numbers (module, system):
00000000000000000000000000000000
0000000000000000
Solution Build Info: 4.3.2.2, Netduino 3 Ethernet (v4.3.2.3) by Secret Labs LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.3.1.0
Microsoft.SPOT.Native,4.3.1.0
Microsoft.SPOT.Hardware,4.3.1.0
Microsoft.SPOT.Net,4.3.1.0
Microsoft.SPOT.Net.Security,4.3.1.0
System,4.3.1.0
System.Net.Security,4.3.1.0
Microsoft.SPOT.Hardware.SerialPort,4.3.1.0
Microsoft.SPOT.IO,4.3.1.0
System.IO,4.3.1.0
Microsoft.SPOT.Hardware.PWM,4.3.1.0
Microsoft.SPOT.Hardware.Usb,4.3.1.0
Netduino.IP,1.0.1.0
Netduino.IP.Interop,1.0.0.0
Netduino.IP.LinkLayers.AX88796C,1.0.0.0
SecretLabs.NETMF.Diagnostics,4.3.1.0
GoBus,1.5.0.0
SecretLabs.NETMF.Hardware.Netduino,4.3.1.0
Microsoft.SPOT.Hardware.OneWire,4.3.1.0
Simple_Test,1.0.0.0
SecretLabs.NETMF.Hardware,4.3.1.0
Sample Code
using System.Net;
using System.Net.Sockets;
namespace Simple_Test
// write your code here
var LightPort = new OutputPort(Pins.GPIO_PIN_D0, false);
var v0Port = new OutputPort(Pins.ONBOARD_LED,false);
bool toggle = false;
toggle = !toggle;
v0Port.Write(toggle);
Thread.Sleep(5000);
Debug.Print("Give short pulse to light");
LightPort.Write(true);
Thread.Sleep(50);
LightPort.Write(false);
Debug.Print("Light is on");
Thread.Sleep(5000);
Thread.Sleep(50);
Debug.Print("Light is off");
Best Regards,
Arno
