hardware interrupt
#1 skywalker
skywalker
  • 4 posts
Posted 28 January 2011 - 03:35 PM
Get Error "no overload for port_OnInterrupt matches delegate 'Microsoft.Spot.Hardware.NativeEventHandler
using System.Text;
using System.IO.Ports;
namespace Netduinoser
    public class Program{
        private static SerialPort s1;
        private static string s;
            InterruptPort port = new InterruptPort(Cpu.Pin.GPIO_Pin10, false, Port.ResistorMode.PullUp,
                                                  Port.InterruptMode.InterruptEdgeLow);
            port.OnInterrupt += new NativeEventHandler(port_OnInterrupt);
            s1 = new SerialPort("COM1", 115200, Parity.None,8,StopBits.One);
            s1.DataReceived += new SerialDataReceivedEventHandler(s1_DataReceived);
            s1.Open ();
            byte[] OutBuf=Encoding.UTF8.GetBytes("All right?\r");
            byte[] InBuf=new byte[2];
            byte[] temp2 = new byte[] { 0xFE, 0x01 };//clrs
            while(true)
                s1.Write(OutBuf, 0, OutBuf.Length);
               Thread.Sleep(500);
               // s1.Write (temp2, 0, temp2.Length);
               // Debug.Print("OK");
Edited by Chris Walker, 29 January 2011 - 06:48 PM.
moderator added [code][/code] tags
#2 Jim Davies
Jim Davies
  • 48 posts
  • LocationBrighton & Hove, UK
Posted 28 January 2011 - 05:06 PM
Hi 'Sky',
You can just define your interrupt method like this:
protected void MyInterrupt(uint data1, uint data2, DateTime time)
                // do stuff...
and use:
port.OnInterrupt += MyInterrupt;
HTH
Jim
#3 Miha Markic
Miha Markic
  • 74 posts
  • LocationNova Gorica, Slovenia
Posted 29 January 2011 - 11:37 AM
using System.Text;
s1.Open ();
while(true)
Thread.Sleep(500);
port_OnInterrupt should have exactly these arguments (like Jim wrote):
It doesn't matter whether you write
or
port.OnInterrupt += port_OnInterrupt;
becaue they are equivalent.
Miha Markic, Microsoft MVP C#
Righthand .net consulting and software development
http://blog.rthand.com/
#4 Chris Walker
Posted 29 January 2011 - 06:50 PM
skywalker, What does your port_OnInterrupt method look like? Do you have the three parameters in it? If you can attach the project in a zip file, we can look at it really quick to help diagnose. Chris
