What happened
Was trying out some simple led code and accidentally hit my USB hub while debugging. That caused my computer to blue screen and after reconnecting everything I couldn't connect to my netduino anymore. The netduino would appear in Visual Studio and MFDeploy, but everytime you tried to deploy or ping it would disconnect halfway through.
What I tried
I tried reflashing the firmware through the upgrade process on this post http://forums.netdui...-v432-update-1/but it doesn't seem to work.
I erased the netduino using STDFU Tester. Then disconnected USB, held the button, connected USB and ran the upgrade process in NetduinoUpdate.
After upgrading the led on the netduino stays on and the netduino disappeared from the upgrade list, then reappeared.
If I reset the netduino after updating, the led stays on temporarily and then goes off. From my understanding as long as the light goes off after booting its not hosed.
The netduino currently appears as Unkown Device in Device Manager. See http://imgur.com/h4aEfjV
Any idea why this isn't working and how to get it back so I can see it in VS?
