I2C strange behavior
14 replies to this topic
#1 hareega
hareega
  • 4 posts
Posted 15 November 2015 - 02:53 AM
Greeting guys
what i'm tying to do is sort of pinging a device for a three times
and i want to know why the I2C execution return 0 in the first time but not in the rest.
            var config = new I2CDevice.Configuration(83, 100);
            var I2C_Bus = new I2CDevice(config);
            I2CDevice.I2CTransaction[] transactions;
            transactions = new I2CDevice.I2CTransaction[2];
            transactions[0] = I2CDevice.CreateWriteTransaction(new byte[1]);
            transactions[1] = I2CDevice.CreateReadTransaction(new byte[1]);
            for (var i = 0; i < 3; i++)
                int result = I2C_Bus.Execute(transactions, 1000);
                if (result > 0)
                    Debug.Print("found");
                else
                    Debug.Print("not found");
This is the debug result i get :
not found
found
found
any ideas?  :huh:
#2 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 15 November 2015 - 03:28 AM
Hi
Try strobing the SDA line just before you open the port
using (OutputPort i2cPort = new OutputPort(Pins.GPIO_PIN_SDA, true))
   i2cPort.Write(false);
   Thread.Sleep(100);
I think the earliest reference to this issue may have been
http://forums.netdui...5-barometer-i2c
@KiwiBryn
blog.devmobile.co.nz
#3 Nevyn
Nevyn
  • 1070 posts
  • LocationNorth Yorkshire, UK
Posted 15 November 2015 - 08:39 AM
Usual question with I2C - have you installed pull-up resistors if the board you are using does not already have them installed.
#4 hareega
hareega
  • 4 posts
Posted 15 November 2015 - 02:15 PM
Hi
   Thread.Sleep(100);
@KiwiBryn
that method worked thanks
i thought the board has built in pull-up resistor
so yeah that's what i missed
#5 NitinSontakke
NitinSontakke
  • 6 posts
  • LocationPune, Maharashtra, India
Posted 17 November 2015 - 05:20 PM
@hareega,
If you could care to mention the device / chip you are using, please!
I am using NP2 and NETMF 4.3 and....
I have been struggling to get i2c working with PCF8574 and PCF8575 over days now with no luck so far and any help from anyone on forum is hugely appreciated.
I using classes generously provided by NooM
The data-sheet indicates address 0x40, which i tried and also tried the default of 0x20.
Pins -> Absolutely nothing special. Pull-up registers are applied as am working on break-out board.
Please help!
#6 scardinale
scardinale
  • 27 posts
  • LocationNew York, USA
Posted 18 November 2015 - 12:32 AM
0x40 is the 8 bit I2C address. NetMF uses 7 bit addressing, so try 0x40 >> 1 as your I2C Address.
#7 NitinSontakke
NitinSontakke
  • 6 posts
Posted 18 November 2015 - 02:10 AM
Thanks! Will try and update.
#8 Nevyn
Nevyn
  • 1070 posts
Posted 18 November 2015 - 06:51 AM
If the data sheet says the peripheral address is 0x40 then shouldn't you be using this in the .NET code:
0x40 << 1
The top 7 bits are used to hold the address of the peripheral, the bottom bit indicates if it is a read or write transaction.
#9 scardinale
scardinale
  • 27 posts
Posted 18 November 2015 - 12:13 PM
That is true about the addressing but NetMF uses a 7-bit addressing scheme and automatically appends the correct bit when reading or writing internally. So all you need to do is supply the 8-bit address right shifted by one.
#10 NitinSontakke
NitinSontakke
  • 6 posts
Posted 18 November 2015 - 05:03 PM
Hello,
Right shifting 0x40 by 1 bit gives me 0x20 (decimal 32). Now it makes sense to me why this value is being used in all the code i see here. While it was step in right direction, unfortunately, it hasn't help resolve the issue.
Shown below is the code i copied from this thread, added the "magic code block" right at the beginning and changed the address to 0x20.
I commented out the "read" transaction because data-sheet mentions that this address is for "write" transaction.
The output is "not found" three times.
PCF8574 -> N2P connections are as follows:
VCC -> 5V - 10k pull-up registered applied
INT -> Nothing
SCL -> SCL
SDA -> SDA
A0, A1, A2 -> Ground
I had taken the photo of assembly but i am facing problem uploading it here.
        Thread.Sleep(100);
      I2CDevice.Configuration config = new I2CDevice.Configuration(0x20, 100);
      I2CDevice I2C_Bus = new I2CDevice(config);
      transactions = new I2CDevice.I2CTransaction[1];
      transactions[0] = I2CDevice.CreateWriteTransaction(new byte[0xff]);
      //transactions[1] = I2CDevice.CreateReadTransaction(new byte[1]);
      for (Int32 i = 0; i < 3; i++)
        Int32 result = I2C_Bus.Execute(transactions, 1000);
        if (result > 0)
        else
#11 scardinale
scardinale
  • 27 posts
Posted 18 November 2015 - 11:49 PM
Try using this example from GHI's codeshare. It will tell you what the I2C address of your device is. If you get an value back it will tell you the 8bit address and verify that your setup is correct.
https://www.ghielect...share/entry/294
#12 NitinSontakke
NitinSontakke
  • 6 posts
Posted 19 November 2015 - 05:27 PM
@scardinale, You are a STAR!
I copied and executed the I2C Scanner and it gave me Int32 address 112, which i right shifted by 1 and used and it WORKED for my other project!
Not sure how on earth one (read, novice like me!) would think of running a scanner to determine an address of a device and then use it.
Anyway, I thank you very much for taking away the biggest stumbling block in my journey towards ambitious home automation project.
Thanks, again!
#13 scardinale
scardinale
  • 27 posts
Posted 20 November 2015 - 01:48 AM
Glad to help.
#14 David Weaver
David Weaver
  • 50 posts
  • LocationBloomington IL
Posted 24 November 2015 - 02:08 PM
This may help,
http://netmftoolbox....017/Mcp23017.cs
Stefan Thoolen did a great job with the Toolbox.
#15 David Weaver
David Weaver
  • 50 posts
Posted 24 November 2015 - 02:13 PM
Here is the link to the 12c source code from stefan's Toolbox.
http://netmftoolbox....ore/MultiI2C.cs
