Nut/OS (RTOS)
Posted 27 January 2011 - 04:26 PM
Posted 28 January 2011 - 04:38 AM
Posted 28 January 2011 - 08:05 AM
Posted 28 January 2011 - 02:53 PM
And, if I change MCU to AT91SAM7X512 from config, reirq.c(or similar) file failed to compile.
I will try to get SD and LED task work tonight.
The lastest YAGARTO won't compile due to the rename. Eg. arm-elf-gcc has become arm-none-eabi-gcc.
Or did you manage to adjust the setup? (I didn't bother seaching that much.)
Posted 07 August 2011 - 06:54 AM
Posted 24 June 2012 - 07:13 AM
Good Day,
Thanks a lot for the above info.
I am very new with nut/OS (and very hopeful), and I need a bit of help.
Basically I went through the whole install process (used Yagarto 4.4.1 and nutos 4.8.9 ). No worries.
All good until I flash the Netduino and restart the board.
Upon reboot, I get this "USB not recognized" error.
I tried another time and Verified the following points :
- Enable flash access - OK
- Boot from flash - OK
- Compared both files - OK
Do we need to do something specific about the USB stack in the configurator to get the serial link enabled ?
Thanks in advance.
HI were you able to get it working? WHere to start about to implement RTOS on netduino?
nishant@winacro.com
www.winacro.com
