Did I break my ND3
1 reply to this topic
#1 Xcone
Xcone
Posted 16 August 2015 - 10:45 AM
I taking my first steps with the ND3 (or with any ND or similar device at all). A few weeks ago I managed to get the GoBUS potentiometer value and PWM control the onboard led with it. So I bought some led Amplifiers and led strips to do the same trick.
In the meantime I've also upgraded Windows from 8.1 to Windows 10. After which I didn't verify if my dev environment still works.
So today finally having some more time to work on it, I decided to connect the led amp to the ND3, change the code and deploy it. Which didn't work, as the ND3 doesn't respond anymore. Afterwards I noticed the pin I connected the led to was Analog In, instead of IO.
So now I'm unsure if it's not working because of Window 10, or because I used the wrong pin and perhaps broken the board because of it?
I've read some posts here, so far I did the following:
Reinstalled MF framework SDK
Reinstalled Netduino SDK
Rebooted computer
Reconnecting USB cable.
Used MFDeploy to ping
Strangely, after reconnecting the USB cable, the first ping seems to work .. for a bit.
Sometimes it logs Assembies, and sometimes it doesn't. Sometime the list is longer or shorter. The last assembly name appears to be cut-off as well. A second ping is never possible, as MF_Deploy sais there's no connection.
So I don't know what to make of it? Is my windows update the problem, or is the board broken?
Koen
#2 David Weaver
David Weaver
  • 50 posts
  • LocationBloomington IL
Posted 20 August 2015 - 12:13 AM
This may not have anything to do with your problem. However I just updated my system and had to references to three 4.2 assemblies. All the referenced assemblies should be 4.3. I hope this helps.
