TLS Crypto algorithm support questions
crypto certificates pki
6 replies to this topic
#1 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 15 July 2015 - 11:13 AM
Hi all,
I have been using the https capabilities of the new N3 over the last couple of months and they have been working really well.
Over the last week I had been playing around with an Azure gateway based on my initial proof of concept here.
I'm getting a generic exception(s) when I try to access https://myhomemonito...us.windows.net/
A first chance exception of type 'System.Exception' occurred in System.Net.Security.dll
A first chance exception of type 'System.Net.WebException' occurred in System.Http.dll
I initially though it might be due to the wildcard cert,
The cert subject is
CN = servicebus.windows.net
with SANs
DNS Name=*.servicebus.windows.net
DNS Name=servicebus.windows.net
I'm not certain the wildcard cert is the necessarily the problem because I can access other wildcard cert protected sites e.g. wordpress hosted blog sites
The cert subject is
CN = *.wordpress.com
with SANs
DNS Name=*.wordpress.com
DNS Name=wordpress.com
Using Chrome there is a subtle difference if you look at the connection details
"Your connection to myhomemonitor.windows.net" is encrypted with obselete cryptography."
I have attached sample code and screen grabs of the connection properties in Chrome.
// Baseline check with google
Debug.Print("https://www.google.co.nz");
try
   using (HttpWebRequest request = (HttpWebRequest)WebRequest.Create(@"https://www.google.co.nz"))
      request.Method = "GET";
      request.KeepAlive = false;
      request.Timeout = 5000;
      request.ReadWriteTimeout = 5000;
      using (var response = (HttpWebResponse)request.GetResponse())
        Debug.Print("HTTP Status:"+ response.StatusCode + " : " + response.StatusDescription);
catch (Exception ex)
   Debug.Print(ex.Message);
Debug.Print("https://justanotherblog.wordpress.com/");
try
   using (HttpWebRequest request = (HttpWebRequest)WebRequest.Create(@"https://justanotherblog.wordpress.com/"))
      //request.Proxy = proxy;
         Debug.Print("HTTP Status:"+response.StatusCode + " : " + response.StatusDescription);
Debug.Print(@"https://myhomemonitor.servicebus.windows.net/");
try
   using (HttpWebRequest request = (HttpWebRequest)WebRequest.Create(@"https://myhomemonitor.servicebus.windows.net/"))
         Debug.Print("HTTP Status:"+response.StatusCode + " : "+response.StatusDescription);
It's late here, so any suggestions before I dive deeper tomorrow would be greatly appreciated
@KiwiBryn
blog.devmobile.co.nz
Posted 15 July 2015 - 05:43 PM
Hey KiwiDev,
Interesting. It's possible that the CC3100 disables obsolete crypto methods by default. There are quite a few crypto options and modes that can be optionally enabled/disabled...so this may be a case where we can expose an API to do so from managed code.
This is an SNI SSL website?
Quite a few folks use Netduino 3 Wi-Fi with Azure regularly (including yourself) so we know things work well there...but it is possible that Microsoft uses different security configs in different parts of the system.
Quick question: would you have time to load debug firmware and step into System.Net.Security, to pull the actual SocketException ErrorCode (or SSL error message)?
SSL/TLS is a big beast with lots of complications--but we chose defaults on Netduino 3 that should make it super-easy to use in most circumstances (similar to navigating to a secure site through a browser). Let's figure out what's up and try to do the same for this site.
#3 KiwiDev
KiwiDev
  • 100 posts
Posted 15 July 2015 - 07:51 PM
I was intending to fire up the debugger this evening to do some more investigation. Where would be the best place to download the debug build bits from?
Odd thing is, my code used to work a few months ago (I went back and checked dates on my blog posts), but MS did update the *.servicebus.windows.net cert on 29/4/2015 which makes me wonder....
THanks
Bryn
@KiwDev
#4 KiwiDev
KiwiDev
  • 100 posts
Posted 16 July 2015 - 09:12 AM
Grabbed the source off github and fired up the debugger. Some slight issues the source may not be most recent, plus the debugger was a bit flakey but hopefully this is useful
In my C# code it started at
My cut n past call stack
public override WebResponse GetResponse()
private void SubmitRequest()
private InputNetworkStreamWrapper EstablishConnection(Uri proxyServer, Uri targetServer)
sslStream.AuthenticateAsClient(m_originalUrl.Host, null, m_caCerts, SslVerification.CertificateRequired, SslProtocols.Default);
public void AuthenticateAsClient(string targetHost, X509Certificate cert, X509Certificate[] ca, SslVerification verify, params SslProtocols[] sslProtocols)
 internal void Authenticate(bool isServer, string targetHost, X509Certificate certificate, X509Certificate[] ca, SslVerification verify, params SslProtocols[] sslProtocols)
In the debugger the parameters at this stage were
false
"myhomemonitor.servicebus.windows.net"
null
null
Verify 4
SslProtocols - 24
Then the debugger started to get quite flakey
I think the exception came from inside
_socket.GetSocketOption(SocketOptionLevel.Socket, (SocketOptionName)0x400002, addressAndHandle);
addressAndHandle contained
[0]0
[1]0
[2]1
[3]187
[4]191
[5]239
[6]64
[7]144
[8]4
[9]255
Hope this helps, anything else I can do?
Bryn
@KiwiDev
#5 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 23 July 2015 - 08:37 AM
Hi KiwiDev,
I'm big fan of AMQP instead of HTTP and today I'm able to use service bus without problems.
However, I opened the following question on CodePlex related to SSL access from .Net MF without any replies from team :
http://netmf.codeple...m/workitem/2381
What do you think about that ? It's strictly related to certificate verification and how it works on .Net MF.
Paolo.
Paolo Patierno
Microsoft MVP on Windows Embedded & IoT
Azure Advisor
Twitter : @ppatierno
Linkedin : paolopatierno
Blog : DevExperience
Blog : Embedded101
#6 KiwiDev
KiwiDev
  • 100 posts
Posted 30 July 2015 - 10:49 AM
Hi Paolo,
Been a bit mad here working on a project pitch document and my MS Ignite NZ presentation.
I think it's related to the crypto options supported/setup on the CC3100.
Will build a debug version of IP Stack and drill down into the code once presentation done.
@KiwiBryn
#7 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 02 August 2015 - 02:18 PM
I don't know if the problem is related to the crypto suites supported by CC3100 but there is a very strange behaviour in SSL handshake using .Net Micro Framework.
You HTTP based methods as last step use a Socket and SSL handshake on it. It's the same in the applications I developed that use Socket directly. On my side, as I described as an issue on Net MF interpreter repository on GitHub it seems that no validation happens.
On your side (with HTTP) it seems that a bit of validation happens and now you have the problem.
Very strange ...
Paolo.
Paolo Patierno
Azure Advisor
Blog : Embedded101
Also tagged with one or more of these keywords: crypto, certificates, pki
