Hi.
I have got this DS3231 AT24C32 IIC module precision Real time clock module and I am trying to get it working with Netduino 3.
1. Size: 38mm (length) * 22mm (W) * 14mm (height)
2. Weight: 8g
3. Operating voltage :3.3 - 5 .5 V
4. Clock chip: high-precision clock chip DS3231
5. Clock Accuracy :0-40 ? range, the accuracy 2ppm, the error was about 1 minute
6. Calendar alarm clock with two
7. Programmable square-wave output
8. Real time clock generator seconds, minutes, hours, day, date, month and year timing and provide valid until the year 2100 leap year compensation
9. Chip temperature sensor comes with an accuracy of ± 3 ?
10. Memory chips: AT24C32 (storage capacity 32K)
11. IIC bus interface, the maximum transmission speed of 400KHz (working voltage of 5V)
12. Can be cascaded with other IIC device, 24C32 addresses can be shorted A0/A1/A2 modify default address is 0x57
13. With rechargeable battery LIR2032, to ensure the system after power failure, the clock move any natural normal
14. Packing: single anti-static packaging
Wiring instructions (with Arduino uno r3 for example):
SCL ? A5
SDA ? A4
VCC ? 5V
GND ? GND
I wired 5v and GND and Analog 4 and 5 and trying to use DS1307 code that seems to be doing the work that DS3231 would need but when trying to access the property CurrentDateTime, clock.Execute always returns 0.
Could someone please help me with figuring out what I am doing wrong?
Is there a way of figuring out if Netduino can actually "see" the analog device?
What is the best way to start?
Thanks!
