Sd Card read issues
SD Card
#1 claudio.serio
claudio.serio
  • 25 posts
Posted 24 June 2015 - 02:53 PM
Hallo everyone,
Always problems with SD Card.
This is my text file on my SD:
[NET]
192.168.1.33
8080
255.255.255.0
192.168.1.1
193.206.115.20
[RS]
9600
8
0
1
0
[ACQ]
2
1
1
1
[LOG]
0
24
This is my code to read the file:
        Dim GetSet As New FileStream("\SD\Conf2.txt", FileMode.Open, FileAccess.Read)
        Dim sr As New StreamReader(GetSet)
        While Not sr.Peek <= 0
            Dim s As String = sr.ReadLine
            Debug.Print(s)
        End While
        Debug.Print("Exited from While Loop")
        While True
            Thread.Sleep(Timeout.Infinite)
        End While
.... and this is my output:
[NET]
192.168.1.33
8080
255.255.255.0
192.168.1.1
193.206.115.20
[RS]
9600
8
0
1
0
[ACQ]
2
1
1
1
[LOG]
0
24
... i don't understand why it remains in the first while loop.
Somebody could help me, please ?
I spent my last 2 hours for this, it should be simple, but .....
#2 HSven1611
HSven1611
  • 14 posts
Posted 25 June 2015 - 05:46 AM
As far as I know StreamReader.Peek "Returns the next available character but does not consume it." That is what MSDN sais.
You might want to use the EndOfStream Property. MSDN: "Gets a value that indicates whether the current stream position is at the end of the stream."
This should work (btw. I'm not really into VB so please excuse if I did not get the syntax correct)
While Not sr.EndOfStream
#3 claudio.serio
claudio.serio
  • 25 posts
Posted 25 June 2015 - 10:40 AM
No, it doesnt work.
The sr.enfofstream is true in the moment i create the stream.
This code
        Dim GetSet As New FileStream("\SD\Conf.txt", FileMode.Open, FileAccess.Read)
        Dim sr As New StreamReader("\SD\Conf.txt")
        Debug.Print(sr.EndOfStream.ToString)
give this output
TRUE
Thank you
#4 cSharper
cSharper
  • 13 posts
  • LocationOrlando, FL
Posted 31 July 2015 - 06:49 PM
This is how I read from my SD card:
        public string GetFileFromSD(string FilePath) {
            var line = "";
            using (FileStream fs2 = new FileStream(FilePath, FileMode.Open, FileAccess.Read, FileShare.None)) {
                using (StreamReader sr = new StreamReader(fs2)) {
                    Debug.Print(line);
                    line = sr.ReadToEnd();
            return line;
