Compiling Firmware with Keil evaluation. - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
firmware keil mdk
#1 stotech
stotech
  • 143 posts
  • LocationAustralia
Posted 25 May 2015 - 04:58 AM
Hi everyone. I’ve got keil installed and I’ve challenged myself to compile the firmware for the NP2. From there I’ll try and make the changes needed to get it working on an STM32F407IGT6
Here is what I’ve done so far.
Prerequisites:
How to build the firmware with Keil;
·         Install Keil eval (you need to email them to arrange a trial). Mine installed to C:\keil_v5
·         Install .NET Micro Framework Porting Kit 4.3 QFE1 (C:\MicroFrameworkPK_v4_3)
·         Make a folder C:\Porting
·         Copy C:\MicroFrameworkPK_v4_3 to C:\Porting\PK_v4_3
·         Extract Netduino 2 Firmware v4.3.1 source to C:\Porting\NP2_v4_3
·         Make a folder C:\Porting\Mixed
·         Copy “C:\Porting\PK_v4_3” to “C:\Porting\Mixed” overwrite all.
·         Copy “C:\Porting\NP2_v4_3” to “C:\Porting\Mixed” overwrite all.
·         Navigate to C:\Porting\Mixed\Solutions\NetduinoPlus2\TinyBooter and make a copy of scatterfile_bootloader_rvds.xml. Rename it to scatterfile_bootloader_mdk.xml. (We might have to make some changes to this later???)
·         Launch cmd.exe (note: I can’t use Msbuild in cmd.exe. For some reason I need to launch C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Visual Studio 2012\Visual Studio Tools\ VS2012 x86 Native Tools Command Prompt) I don’t know why?
·         Use these commands
cd porting\mixed
setenv_base.cmd MDK5.14 PORT C:\keil_v5
Msbuild Solutions\NetduinoPlus2\dotnetmf.proj /T:rebuild /p:flavor=release;tcp_ip_stack=lwip /filelogger
And this is where I’m up to.
Only 2 Errors, (see attached file) I’m appealing to the community to help me finish this guide.
Thanks in advance.
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 25 May 2015 - 08:28 AM
The Visual Studio command prompt adds some extra bits to the path, most notably the location of MSBuild.
#3 stotech
stotech
  • 143 posts
  • LocationAustralia
Posted 26 May 2015 - 05:15 AM
OK. I thought i had the solution
https://www.ghielect.../topic?id=15600
by changing the command from
to
setenv_mdk.cmd 5.14 C:\keil_v5
Turns out that produces 115 errors???
Also tagged with one or more of these keywords: firmware, keil, mdk
