How to reduce pin usage
Best Answer Nevyn, 23 May 2015 - 05:34 PM
There are a few options, the most common one people have used here is to use a single 74HCT595 shift register.  This will allow you to use three pins and have 8 outputs per chip.  You need the HCT version as this will allow you to use 3.3V outputs to communicate with the chip.  There's a fair amount of examples in the forums here for using these chips.
There are other chips such as the MCP23S17 which has 16 input/output pins.  This one uses SPI but there are I2C versions out there.
Hope this helps,
#1 Nicolai
Nicolai
  • 14 posts
  • LocationDenmark
Posted 23 May 2015 - 03:00 PM
Looking at something like this, it uses A LOT of pins.
Is there some way I can reduce the pin usage, on things like these?
I will run out of pins if I use things like this :(
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 23 May 2015 - 05:34 PM   Best Answer
Hope this helps,
#3 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 24 May 2015 - 07:13 AM
A nice thing about these serial to parallel chips is that all the outputs change at the same time. Individual GPIOs have to be changed one at a time.
Not always a problem, but sometimes important.
Paul
