// Communication problem with Netduino 3 WiFi //Failed allocation for 5 blocks
Posted 19 May 2015 - 02:29 PM
Devices:
Windows 8.1 // VisualStudio Express 2013 // Netduino 3 WiFi
Hello,
I hope somebody can help me. I was working with the Netdino 3 WIFI Board without any problem for some days. But during debbuging the message in VS2013 “An error has occurred. Plase check hardware” end the debbugin mode. Befor (in the debug window) following message come up.
Waiting for debug commands...
The program '[2] Micro Framework application: Managed' has exited with code 0 (0x0).
Failed allocation for 5 blocks, 60 bytes
I try to update the Netduino but the updater do not work. (No devices are in the sekect list)
With the MFDeploy I got following message (Target-Device Capabilities)
Pinging... TinyCLR
HalSystemInfo.halVersion: 4.3.1.0
HalSystemInfo.halVendorInfo: Netduino 3 Wi-Fi (v4.3.2.0) by Secret Labs LLC
HalSystemInfo.oemCode: 34
HalSystemInfo.modelCode: 177
HalSystemInfo.skuCode: 4105
ClrInfo.clrVersion: 4.3.1.0
ClrInfo.clrVendorInfo: Netduino 3 Wi-Fi (v4.3.2.0) by Secret Labs LLC
ClrInfo.targetFrameworkVersion: 4.3.1.0
SolutionReleaseInfo.solutionVersion: 4.3.2.0
SolutionReleaseInfo.solutionVendorInfo: Netduino 3 Wi-Fi (v4.3.2.0) by Secret Labs LLC
SoftwareVersion.BuildDate: Apr 27 2015
SoftwareVersion.CompilerVersion: 410894
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 0
screenshort-netduino3.pdf 121.1KB 2 downloads
General: Sorry for my bad English, but I hope you can understood my problem and give me some help.
Werner
Posted 19 May 2015 - 05:09 PM
"Failed allocation for 5 blocks, 60 bytes" is a message from the garbage collector, letting us know that something is trying to eat up all the memory on your board. My guess is that the current app is blocking out the debugger.
No worries. Press and hold the pushbutton on your Netduino while powering it up via your computer's USB port. Then open Netduino Update (where your board should now appear, since it's now in bootloader mode).
Go into device options and on the right-most tab you'll find an "erase app" button. Erase your app and then detach/reattach your board. You should be all back to normal.
Does that get you on the right path?
Posted 19 May 2015 - 06:27 PM Best Answer
woooooow, it works!
