RS485 between two Netduinos
8 replies to this topic
#1 Kenny Kerr
Kenny Kerr
  • 17 posts
Posted 24 January 2011 - 06:00 PM
Hi there,
I have a Netduino and a Netduino Plus that I’ve connected to RS485 transceivers in an attempt to test serial communication between the two. My wiring may well be wrong but I’m just trying to eliminate coding errors first.
The tranceiver requires 3 pins which map to RX, TX and RTS on the netduino I believe. I have connected these to digital pins 2, 3 and 7. I assume this maps to COM2.
The netduino plus attempts to send a few bytes when the button is pressed:
class Program
    static SerialPort m_port;
    static void Main()
        m_port = new SerialPort("COM2", 9600, Parity.None, 8, StopBits.One);
        m_port.Handshake = Handshake.RequestToSend;
        m_port.DataReceived += OnDataReceived;
        m_port.ErrorReceived += ErrorReceived;
        m_port.Open();
        InterruptPort button = new InterruptPort(Pins.ONBOARD_SW1, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth);
        button.OnInterrupt += OnButton;
    static void ErrorReceived(object sender, SerialErrorReceivedEventArgs args)
        Debug.Print("error");
    static void OnDataReceived(object sender, SerialDataReceivedEventArgs args)
        Debug.Print("data");
    static void OnButton(uint data1, uint data2, DateTime time)
        if (0 == data2)
            var bytes = Encoding.UTF8.GetBytes("hello from netduino plus");
            int count = m_port.Write(bytes, 0, bytes.Length);
            Debug.Assert(bytes.Length == count);
            m_port.Flush();
The netduino on the other end simply waits to receive data:
class Program
    static void Main()
        m_port.Open();
Although the SerialPort.Write call succeeds, data is never received on the remote SerialPort. Am I doing something obviously wrong?
Cheers,
Kenny
#2 bill.french
bill.french
  • 260 posts
  • LocationPrinceton, NJ
Posted 24 January 2011 - 06:37 PM
check this out: http://forums.netdui...ch__1#entry6890 might have to do with adding the event before the port is open?
#3 bill.french
bill.french
  • 260 posts
Posted 24 January 2011 - 06:41 PM
You could also test it without events with something like this:
while(true)
while (_COMPORT.BytesToRead > 0)
                byte[] buffer = new byte[1];
                _COMPORT.Read(buffer, 0, 1);
                Debug.Print(buffer[0].ToString());
#4 Chris Walker
Posted 24 January 2011 - 06:43 PM
Hi Kenny, What RS485 transceivers are you using? If using RTS/CTS, you generally need to wire _both_ RTS and CTS. Also, are RX and TX swapped between the two boards (RX1<->TX2 and RX2<->TX1)? Chris
#5 Kenny Kerr
Kenny Kerr
  • 17 posts
Posted 24 January 2011 - 06:50 PM
I'm using the LT1785 tranceiver. I thought I didn't need to wire up the CTS but I could be wrong.
I'm not sure what you mean. I tried to wire both board identically: DI to TX (pin 3) and R0 to RX (pin 2).
Cheers,
Kenny
#6 Mario Vernari
Posted 26 January 2011 - 08:50 AM
Kenny, the RS485 line is polarized. You should try to swap the wiring between the two LT1785 ICs. There's no damage, but it simply doesn't work. Another good step to do, is to connect a led to the RTS port, so that you've an easy way to see when the transmitter requires the line. That's *NOT* granting the data is flowing correctly, of course! I confirm that the CTS line is not envolved at all for this purpose. FYI, I'm working to do the same thing, but for connect the Netduino+ to a PC. Cheers Mario
#7 Kenny Kerr
Kenny Kerr
  • 17 posts
Posted 26 January 2011 - 05:04 PM
Thanks Mario,
Did you get it to work? From reading through the Atmel docs on their USART and looking at the Micro Framework firmware (native code) it looks like the Micro Framework hardcodes the USART to operate in “normal” mode but we require it to be switched to “rs485” mode to ensure the right RTS behavior. Unfortunately this requires a recompilation of the netduino’s firmware to flip this register value.
Cheers,
Kenny
#8 Mario Vernari
Posted 27 January 2011 - 05:33 AM
Hi Kenny. No, I didn't yet. I'd plan to achieve some result on the next week-end. At the moment I must sort out other stuffs *much* more important, because the customer's waiting for! At the moment Netduino is only experimentation in the spare time. I promise to keep you informed. Anyway, about the RTS, I'd avoid to modify the driver for the TX-enabling. I'd prefer to manage "manually" the line... We'll see. Cheers Mario
#9 Kenny Kerr
Kenny Kerr
  • 17 posts
Posted 27 January 2011 - 01:57 PM
Hi Mario,
Yes for the netduino it’s probably simplest to let the chip think it’s an RS232 and handle the RTS manually. We’re just going to use native code with our own board, so we can use the RS485 driver.
Cheers,
Kenny
