Does anyone know the correct orientation of the 10 pin connector for the Netduino Plus 2 JTAG interface on the board. I have the 10 pin connector that I need to solder onto the board so I can interface to a ST-LINK/V2 Debugger and Programmer. If you search the web for 10 Pin JTAG interface you will find the pin assignments in relation to connector with the opening on one side. Question is does that connector opening face to the insider of the Netduino board or towards the outside. I used a volt meter to determine which pins have VCC+ but both pins on both sides have a + VCC voltage so I can not determine the orientation. Any help would be greatly appreciated. Thank you
