Hello,
So I think that I’m a little over my head here. I bought the Sparkfun RGB LED Matrix controller. It requires a 5V power supply which can be provided from the netduino plus but the SPI interface description states that it requires 5V on it CS pin for “high”. The max ouput on the netduino i/o pins is 3.3V right? What’s the best way to interface with this controller? Did I mention I’m a newb
Thanks in advance!
Serial Interface with 5V?
Started by blubblub, Jan 23 2011 06:48 PM
Posted 23 January 2011 - 06:48 PM
Posted 23 January 2011 - 07:38 PM
Hi Blub,
You need to use a logic level converter between the SPI interface and the matrix.
Sparkfun sells one with 4 channels (http://www.sparkfun.com/products/8745) but there are many others, cheaper ones, out there.
You can see an example of a level-shifter with an LCD screen here:
http://fabienroyer.wordpress.com/2011/01/18/using-a-5-volts-serial-lcd-backpack-with-a-netduino/
Cheers,
-Fabien.
Cheers,
-Fabien.
Posted 24 January 2011 - 01:41 AM
Fabien,
Thanks for the feedback.
