Best Answer Maximilian, 20 January 2015 - 07:16 PM
Ok I solve the problem.
If someone needs the answer just comment to this post and ill write a manual how to fix the problem.
Go to the full post  | ||||||||||||||
CLR_E_OUT_OF_RANGE Error when Debugging
Started by Maximilian, Jan 12 2015 08:16 PM
debugging error CLR_E_OUT CLR available storage
Ok I solve the problem. If someone needs the answer just comment to this post and ill write a manual how to fix the problem. Go to the full post
#1Posted 12 January 2015 - 08:16 PM Hi All,
I recently bought a netduino Plus 2 to realize a new project with the BLE112 Bluetooth module. I found a libary released by jrowberg ( i think someone from BlueGiga Dev Team), who published the BGLib, which contains the main functions to communicate with the BLE112. I did some changes at source code but i cant compress the code that much, because i just dont really know which functions i really need. After edititng the Lib, i tried upload it to the Netduino, but VS2013 gave me an error, which is: "CLR_E_OUT_OF_RANGE". Obviuosly i looked up in google and in this forum for some resolutions, but i couldnt find any useful.
I would really appreciate if you could help me with my problem and give me a response asap.
Greetings, Maximilian M.
Here my BLELib:
#2Posted 19 January 2015 - 06:12 PM Small Addition:
- I read that the error is caused by too big Assemblies. - They said its possible to split the Project in small Assemblies...
I made a couple of Cs files.... i think i understood it wrong.... how do you exactly split Assemblies ? #4Posted 19 February 2015 - 11:33 AM Hello Maximilian, I'm glad you solved this problem because I have the same problem.
I try to create more Cs files but I didn't solve.
Please, can you help me? How did you solve the problem? how do you exactly split Assemblies ?
I'm waiting for your answer,
Thanks and Best Regards!
Skynet 0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
