Netduino plus 1 and I2C
I2C Netduino plus 1
No replies to this topic
#1 w3n
w3n
  • 4 posts
Posted 29 December 2014 - 02:31 AM
Hi guys I need some help with I2C and Netduino plus 1.
Actually I'm using the A4-A5 Pins to try to communicate with an Adafruit servo shield but just noticied something that's getting me totally confused -I have to say I'm totally new on this but.. seems no sense-
Actually the Shield should be at the address 0x40 as documentation says.
Running the following test code I got confusing outputs:
namespace NetduinoPlusApplication2
        static I2CDevice.Configuration _i2cdevice;
                try
                    Debug.Print("Trying addr: " + 0x38+ "------------------------------------");
                    _i2cdevice = new I2CDevice.Configuration(0x38, 400);
                    I2CDevice MyI2C = new I2CDevice(_i2cdevice);
                    I2CDevice.I2CTransaction[] xActions = new I2CDevice.I2CTransaction[2];
                    byte[] RegisterNum = new byte[1] { 2 };
                    xActions[0] = I2CDevice.CreateWriteTransaction(RegisterNum);
                    byte[] RegisterValue = new byte[1];
                    xActions[1] = I2CDevice.CreateReadTransaction(RegisterValue);
                    if (MyI2C.Execute(xActions, 1000) == 0)
                        Debug.Print("Failed to perform I2C transaction");
                    else
                        Debug.Print("Register value: " + RegisterValue[0].ToString());
                catch
                    Debug.Print("EXCEPTION  "  );
Notice I'm trying to setup it wrong, I2CDevice.Configuration(0x38, 400); ..but the output:
Trying addr: 56------------------------------------
Register value: 0
The thread '<No Name>' (0x1) has exited with code 0 (0x0).
Done.
Ok, Trying the 0x40 (64)
Trying addr: 64------------------------------------
Register value: 0
Done.
and here comes the fun...I unplug the a4 and a5 and ..
First time I try: -It should say it failed as it does, so I guess this is right -
Done.
Ok ..now let's try again -nothing is plugged-
Register value: 0
Done.
How's this possible? first it reads something for an non present address, second time it reads from the 0x40, when it's unplugged it says it failed as expected the first time, but the second time says it was fine... I'm totally confused
Any idea on this? Thank you very much in advance
