Netduino 2 can't run N1(+ or not) code.
Posted 11 December 2014 - 05:02 AM
Posted 12 December 2014 - 06:25 AM
Actually! Help please!
Posted 13 December 2014 - 04:47 PM
Hi david,
Netduino 2 runs .NET MF 4.2 or newer. Once you open the project, go to the Project Properties for each project in the solution and change your target framework version to .NET MF 4.2.
If the project is using pre-compiled assemblies, make sure they're compiled for .NET MF 4.2 as well. Or pull in their source as separate projects, change their target framework version to .NET MF 4.2, make sure you're now referencing those helper projects from your main project, and recompile. Once everything is on 4.2 you should be able to deploy.
If any of the older projects were using the old AnalogInput and PWM classes you'll want to import SecretLabs.NETMF.Hardware.AnalogInput.dll and/or SecretLabs.NETMF.Hardware.PWM.dll to those projects as well.
Posted 13 December 2014 - 06:07 PM
hi Chris
I cant use ST7735 chip with Fabienroyer code.
Is this possible with Neduino2+
Posted 13 December 2014 - 06:39 PM
Now working. It now grabs errors from the netduino helpers project like:
AnalogInput is between SecretLabs.NETMF.HARDWARE and Microsoft.SPOT.Hardware.AnalogInput
This older syntax? I set it to 4.2.
Posted 14 December 2014 - 01:43 AM
Hi david,
What is this suppose to mean?
OPCODE conv.ovf.i
It's there like 5 times.
