Why is this not working? V C# 2010 with Netduino 2.
#1 david98xp
david98xp
  • 57 posts
Posted 05 December 2014 - 07:16 PM
Link:http://netduinohelpe...er:AdaFruit7565
Error on the public class with this AdaFruitSSD1306 thingy here...
namespace netduino.helpers.Hardware {
    // Based on https://github.com/adafruit/ST7565-LCD
    public class AdaFruit7565 : AdaFruitSSD1306 {
        new public enum Command {
            DisplayOff = 0xAE,
            DisplayOn = 0xAF,
            DisplayStartLine = 0x40,
            PageAddress = 0xB0,
            ColumnAddressHigh = 0x10,
            ColumnAddressLow = 0x00,
            AdcSelectNormal = 0xA0, // X axis flip OFF
            AdcSelectReverse = 0xA1, // X axis flip ON
            DisplayVideoNormal = 0xA6,
            DisplayVideoReverse = 0xA7,
            AllPixelsOff = 0xA4,
            AllPixelsOn = 0xA5,
            LcdVoltageBias9 = 0xA2,
            LcdVoltageBias7 = 0xA3,
            EnterReadModifyWriteMode = 0xE0,
            ClearReadModifyWriteMode = 0xEE,
            ResetLcdModule = 0xE2,
            ShlSelectNormal = 0xC0, // Y axis flip OFF
            ShlSelectReverse = 0xC8, // Y axis flip ON
            PowerControl = 0x28,
            RegulatorResistorRatio = 0x20,
            ContrastRegister = 0x81,
            ContrastValue = 0x00,
            NoOperation = 0xE3
        public AdaFruit7565(Cpu.Pin dc, Cpu.Pin reset, Cpu.Pin chipSelect, SPI.SPI_module spiModule = SPI.SPI_module.SPI1, uint speedKHz = 10000)
            : base(dc, reset, chipSelect, spiModule, speedKHz) {
        public void Initialize() {
            resetPin.Write(false);
            Thread.Sleep(50);
            resetPin.Write(true);
            dcPin.Write(DisplayCommand);
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.LcdVoltageBias7);
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.AdcSelectNormal);
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.ShlSelectReverse);
            SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.DisplayStartLine) | 0x00));
            SendCommand((AdaFruitSSD1306.Command) ((int)(AdaFruit7565.Command.PowerControl) | 0x04)); // turn on voltage converter (VC=1, VR=0, VF=0)
            Thread.Sleep(50);
            SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.PowerControl) | 0x06)); // turn on voltage regulator (VC=1, VR=1, VF=0)
            Thread.Sleep(50);
            SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.PowerControl) | 0x07)); // turn on voltage follower (VC=1, VR=1, VF=1)
            Thread.Sleep(50);
            SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.RegulatorResistorRatio) | 0x06)); // set lcd operating voltage (regulator resistor, ref voltage resistor)
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.DisplayOn);
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.AllPixelsOff);
        public const uint ContrastHigh = 34;
        public const uint ContrastMedium = 24;
        public const uint ContrastLow = 15;
        // 0-63
        public void SetContrast(uint contrast) {
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.ContrastRegister);
            SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.ContrastValue) | (contrast & 0x3f)));
        new public void InvertDisplay(bool cmd) {
            if (cmd) {
                SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.DisplayVideoReverse);
            } else {
                SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.DisplayVideoNormal);
        public void PowerSaveMode() {
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.DisplayOff);
            SendCommand((AdaFruitSSD1306.Command)AdaFruit7565.Command.AllPixelsOn);
        protected const int StartColumnOffset = 1;
        public override void Refresh() {
            for (int page = 0; page < 8; page++) {
                SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.PageAddress) | pageReference[page]));
                SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.ColumnAddressLow) | (StartColumnOffset & 0x0F)));
                SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.ColumnAddressHigh) | 0));
                SendCommand((AdaFruitSSD1306.Command)((int)(AdaFruit7565.Command.EnterReadModifyWriteMode)));
                dcPin.Write(Data);
                Array.Copy(displayBuffer, Width * page, pageBuffer, 0, pageSize);
                Spi.Write(pageBuffer);
        protected const int pageSize = 128;
        protected int[] pageReference = new int[] { 4, 5, 6, 7, 0, 1, 2, 3 };
        protected byte[] pageBuffer = new byte[pageSize];
Posted 06 December 2014 - 12:34 AM
Hi david,
What error are you getting, exactly? Any chance you can simplify the solution down a bit and we can try to help bug hunt here...?
#3 david98xp
david98xp
  • 57 posts
Posted 06 December 2014 - 10:58 PM
Hi david,
Actually here's the problem! I own a netduino 2 and a st7565 negative GLCD. I'm now trying to run Fabien Royer's AdaFruit7565 test program. It says it won't work with 4.2 as it's written in 4.1. I went to Project Propeties>Application>Target>I changed it from 4.1 to 4.2. Now it has this "Rebooting error". As well as "an error has occured, please check your hardware."
I'm very much in a rush and I need some way to get my LCD Working.
#4 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 09 December 2014 - 09:16 AM
Could you share a cut back version of your solution which exhibits the problem (code. projects etc.) ?
Bryn
#5 david98xp
david98xp
  • 57 posts
Posted 09 December 2014 - 03:22 PM
Umm.. It's not just one part. Check out my newer post on backwards .
