So I'm relatively new to the wonderful world of "dunios". Kudos to the netduino guys for giving a lonely .NET programmer like myself a way to get into the hobby without having to give up my VS .
I finally got the netduino board, and have been messing around with it, cool stuff. My end goal is to drive two big motors on a big robot, but for now, it's more of a proof of concept. i wanted to drive two motors (http://www.sparkfun.com/products/319). To do this I understand that I will need a motor driver shield. When I search for such an item on sparkfun, I only get arduino stuff. I've tried looking through the "compatible shields" on this forum, but didn't find a motor driver shield. Can anyone suggest a shield that is tested and true with the netduino?
Lex
Noob Motor Shield questions
Started by lex, Jan 21 2011 07:14 PM
7 replies to this topic
Posted 21 January 2011 - 07:14 PM
Posted 23 January 2011 - 03:34 AM
Hi Lex,
I would say that most of them would be OK, since the PWM pins are in the same place on Netduino and Arduino.
I used one from DFRobots at http://www.dfrobot.c...9&product_id=59 and it works fine.
Its good for about 1A, based on L293 PWM driver chip.
Good luck,
Phil
Posted 23 January 2011 - 03:38 AM
Hi Lex,
Also, please be aware that the Netduino's 32-bit ARM microcontroller only has 4 PWMs (whereas the Arduino's AVR micro has 6). DFRobot is probably a good choice. Just remember that the "outside 2 PWMs" won't be there on Netduino.
The good news: all the PWMs on the Netduino are higher-speed and higher-bit.
Posted 24 January 2011 - 05:47 PM
Thanks!
Posted 24 January 2011 - 06:32 PM
Do you think this shield will work with a Servo whose operating voltage is between 4.8-6.0v?
I guess I could always look for a servo that operates in the 3.3v-5v range and plug it directly into the netduino.
Thanks!
EDIT:
I guess I should be more specific, I'm looking to control a servo that can rotate 360 degrees. Has anyone used the Ardumoto shield before?
http://www.sparkfun.com/products/9896
I need to be able to turn the servo in small increments in both directions. This is the servo that I've located.
http://www.sparkfun.com/products/9347
Can these things work together?
Any suggestions would be greatly appreciated.
Thanks!
EDIT:
Posted 26 January 2011 - 04:00 PM
Anyone have suggestions?
Posted 26 January 2011 - 04:22 PM
hmmm, i have never used either.
1. I see no reason why that shield would not work wiht a netduino, it's just an h-bridge on a board, as far as I can tell.
2. That servo, though, is 4.8-6v, and the shield takes it's power from Vin, which I think requires 7V, so that might be an issue.
...BUT i don't think you need that shield (or an h-bridge) to drive that servo -- the servo should just take in PWM and power.
Posted 28 January 2011 - 03:20 PM
Duh, good point. Thanks for the response.
