Custom building a smaller Netduino 2
custom
5 replies to this topic
#1 Frode
Frode
  • 202 posts
  • LocationNorway
Posted 17 November 2014 - 08:15 PM
Hi guys!
I've been working on creating a smaller version of the Netduino for a while. I posted a version on the Fritzing website a few months ago, and since then I've made a new iteration. Here is a screenshot of the new version.
Attached File  2014-11-17 20.46.49.jpg   154.97KB   33 downloads
The board is 30mm x 54mm (1.18" x 2.13") and has pretty much the same functionality as the Netduino 2.
It can be powered via USB or the VIN pin.
All the same GPIO pins are there, but I've also added one more 3.3V and one more 5V output.
Compared to the original Netduino 2 it doesn't have IOREF, /RESET, the power barrel or the JTAG. The circuit on the original Netduino 2 which switches between the powerinput from USB or VIN has been replaced by a LTC4411 diode.
Attached File  2014-11-17 20.48.41.jpg   56.51KB   17 downloads
The board accepts the Netduino 2 firmware. Hold down the Firmware button while booting and run Netduino Update tool.
Thanks to Chris Walker for opensourcing the Netduino hardware! I'm including the Eagle 7.1 files if anyone wants to modify, or create their own versions.
#2 Juzzer
Juzzer
  • 135 posts
  • LocationHertfordshire, UK
Posted 17 November 2014 - 09:08 PM
Good job :)
#3 CW2
Posted 18 November 2014 - 02:45 PM
Very nice board !
Although, on the photo it seems that there are parts and traces very close to the mounting holes, maybe so close that the screw head could touch them or even cause some damage (?)
#4 Frode
Frode
  • 202 posts
  • LocationNorway
Posted 18 November 2014 - 03:08 PM
You are right, I'll have to fix that. Also, I probably need more decoupling capacitors for 5V and 3V3, I haven't included as many as the original Netduino 2.
If you see anything else that should be fixed I'm all ears. The next iteration is most likely going to be drawn in KiCad.
#5 xmen
xmen
  • 72 posts
Posted 06 June 2016 - 03:50 AM
How did you upload firmware in it ?
#6 Frode
Frode
  • 202 posts
  • LocationNorway
Posted 30 June 2016 - 01:56 PM
Hmm, it's been a while, but I believe you do it the exact same way as on a regular Netduino. Did you make one of my boards?
Edit: See the comment in the original post; "The board accepts the Netduino 2 firmware. Hold down the Firmware button while booting and run Netduino Update tool."
Also tagged with one or more of these keywords: custom
