Serial Handler
Posted 17 November 2014 - 01:27 PM
Posted 19 November 2014 - 02:13 AM
hello there,
first off let's look at your datreceived event handler;
static void serial_DataReceived(object sender, SerialDataReceivedEventArgs e)
you can put a whole packet into queue.
anyhow, something for you to get started on, ask questions, have fun.
cheers
ron
Posted 23 November 2014 - 10:35 PM
Thanks Ron,
Funny, I also got a suggestion from a programmer at work that moving the data as strings would be easier. I guess that's probably the more common way to do it; something I'm going to try.
That sleep was basically only allowing the buffer to get filled once! Thanks for the advice.
The way i have been handling the data so far is parsing it out once it's in the Netduino. I have a routine that looks through the bytes[] array and basically just walks through it and uses it the comma and the carriage return delimiters to determine whether the value is a power level (first column) or delay time (second column).
I'll let you know how it goes-probably won't get back to this until after Wednesday of next week. But I'll definitely keep you posted.
Thanks again,
Miguel
