Reading Value from potentiometer
Netduino Plus 2 Visual Studio 2013 4.3.1.0 Potentiometer
1 reply to this topic
#1 Spammy786
Spammy786
  • 26 posts
Posted 13 November 2014 - 02:49 PM
Hi Guys
I am trying to read the values from my potentiometer. I got it working but the output is not really what I was expecting.
Firstly I dont understand the concept of the channels.
Like for example, you physically connect something to PIN 0, but instead of choosing PIN 0, you have to select Cpu.AnalogChannel.ANALOG_0.
Is there any user friendly documentation on this, but anyways back to my problem.
I was using some snippnets from 1 of the posts I found in the netduino forums, basically the guy was just reading values from the potentiometer. I would like to do the same. heres the potentiometer I have
http://netram.co.za/...entiometer.html
But this guy was setting a range in his example. (pot.setrange(0,100)) I dont have those options. and I just want round numbers and not decimals. I just want to read values from 0-100 also in my example. Heres my code. I does output the values but it starts like 1 2 3 then back to 1 2 3 and then if you turn it slightly, it jumps all the way to 202.
Only options I have for the AnalogInput is the following and what do they mean ? I have no clue.
Offset
Pin
Presicion (read only)
Read
ReadRaw
Scale
It basically needs to be refine and optimized. Any ideas
using System.Net;
using System.Net.Sockets;
namespace NetduinoPotTester
            AnalogInput pot = new AnalogInput(Cpu.AnalogChannel.ANALOG_0);
                int potValue = 0;
                potValue = pot.ReadRaw();
                Debug.Print(potValue.ToString());
Thanks guys.
#2 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 19 November 2014 - 08:29 AM
Hi
How about this, it returns a value between 0 & 100.
PrecisionInBits = -1  maximum
Offset = 0 so values will start from 0.0
Scale = 100 so result will be between 0.0 & 100.0
If you wanted say -50 to + 50
Offset = -50
Scale = 100
      AnalogInput rotaryAngleSensor = new AnalogInput(Cpu.AnalogChannel.ANALOG_0, 100, 0, -1);
         Debug.Print("Angle " + rotaryAngleSensor.Read().ToString("F1"));
         Thread.Sleep(250);
Bryn
blog.devmobile.co.nz
Also tagged with one or more of these keywords: Netduino Plus 2, Visual Studio 2013, 4.3.1.0, Potentiometer
